W&B update
dlm46007(at)cox.net
PostPosted: Thu Apr 23, 2009 6:37 pm    Post subject: W&B update Reply with quote
Just completed the first annual and re weighed after installing the extra battery. The new weight is 1666 and a cg of 108.13. installing the 680 on the firewall moved the CG about an inch forward. I won't feel any anxiety loading 100 pounds in the baggage area (35 pounds of tools and 65 pounds of family things). Based on a previous weight I calculate the battery at 15 and the paint at 21.
cjay
PostPosted: Sun May 03, 2009 11:36 am    Post subject: Re: W&B update Reply with quote
[quote="dlm46007(at)cox.net"]Just completed the first annual and re weighed after installing the extra battery. The new weight is 1666 and a cg of 108.13. installing the 680 on the firewall moved the CG about an inch forward. I won't feel any anxiety loading 100 pounds in the baggage area (35 pounds of tools and 65 pounds of family things). Based on a previous weight I calculate the battery at 15 and the paint at 21.
Can you show us where you placed the 680 in the front?
dlm46007(at)cox.net
PostPosted: Sun May 03, 2009 12:34 pm    Post subject: W&B update Reply with quote
Exterior and interior views
 Filesize:  319.46 KB
 Viewed:  2910 Time(s)
 Filesize:  386.56 KB
 Filesize:  308.45 KB
