Avionics Wiring - Advanced Flight Systems
jim(at)CombsFive.Com
PostPosted: Wed Apr 22, 2009 4:49 am    Post subject: Avionics Wiring - Advanced Flight Systems Reply with quote
I am installing the AP from Advanced Flight Systems. I have updated the spreadsheet for my avionics harness.Current configuration:AF3500EEGTX327ARINCSL30GNS430WDII VSGV (Advanced Flight Systems Version)PS8000BIt may be of value to someone else. Print it out to get the full affect of the connections. I tended to use 2 and 3 wire shielded for most connections. I am not aware of any wiring errors. Thanks, Jim CN312F - Flying.
Avionics_Interconnect_Wiring_-ARINC-W430-AP.xls
 Filename:  Avionics_Interconnect_Wiring_-ARINC-W430-AP.xls
 Filesize:  119 KB
 Downloaded:  324 Time(s)
msausen
PostPosted: Wed Apr 22, 2009 6:19 am    Post subject: Avionics Wiring - Advanced Flight Systems Reply with quote
Jim,
Are you running a beta of the AFS AP software? I understand it’s not available yet.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com
Sent: Wednesday, April 22, 2009 7:46 AM
Subject: Avionics Wiring - Advanced Flight Systems
AF3500EE
GTX327
ARINC
SL30
GNS430W
PS8000B
Thanks, Jim C
N312F - Flying.
PostPosted: Wed Apr 22, 2009 6:45 am    Post subject: Avionics Wiring - Advanced Flight Systems Reply with quote
I talked to Rob. He sent me an "Current" set of code (Not yet posted). Quite a few changes (Read that as --> lots of new additions).The EFIS is running with the new code and I am just now getting the AP hardware installed.The AP control head is logo'ed with AFS logo (Shipped from TruTrak). The AP requires the ARINC adapter (RS-422) interface. They are into the Sun-N-Fun event at the moment so there are not a lot of folks in Oregon.Jim CN312FJim, Are you running a beta of the AFS AP software? I understand it's notavailable yet.MichaelFrom: owner-rv10-list-server(at)matronics.com[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Ofjim(at)CombsFive.ComSent: Wednesday, April 22, 2009 7:46 AMTo: rv10-list(at)matronics.comSubject: Avionics Wiring - Advanced Flight SystemsI am installing the AP from Advanced Flight Systems. I have updated thespreadsheet for my avionics harness.Current configuration:AF3500EEGTX327ARINCSL30GNS430WDII VSGV (Advanced Flight Systems Version)PS8000BIt may be of value to someone else. Print it out to get the full affectof the connections. I tended to use 2 and 3 wire shielded for mostconnections. I am not aware of any wiring errors.Thanks, Jim CN312F - Flying. [quote][b]
