Charging system trouble shooting
Goto page 1, 2  Next
WurlyBird
PostPosted: Mon Apr 20, 2009 8:21 pm    Post subject: Charging system trouble shooting Reply with quote
Looking for a few ideas of where to start with an issue I am having with the electrical system. Here is the run down;
I bought my KF used and the prior owner kept it on a trickle charger when not flying and seemingly never flew it for more then an hour at a time. Running only a radio, an intercom, and a strobe the battery got so low in just 2 hours that in coming transmissions were unintelligible and the strobe could be observed working on the voltmeter.
I installed a Key West voltage regulator with the understanding that it was able to route excess power from the mags to the battery to help charge it. Installation was SEEMINGLY simple, red, yellow, yellow, black. Everything runs great.
Since then my Hobbs has only ticked off 1/10 of an hour (about 12 hours of flight time has elapsed) and the duration of my battery has gotten worse if anything. I had to reroute in flight during a cross country because I had to turn off my radio and strobe and so could not contact any towers.
I suspect the battery is going bad or is just too small but my smart charger indicates that it is still good and holding 100%. The only real clue I have for any wiring issues is the Hobbs but I am not sure what could have been wired wrong, nor do I have any of the original wiring diagrams. Do the 2 yellows have a specific position on the Key West regulator?
Since the regulator I have also installed push-to-intercom switches which use the common ground that the Hobbs also uses. Could this affect it at all? It does not make any sense that it could but no harm in questioning it.
So, any ideas or similar experiences?
James
Kitfox 3 / 582 / 70" IVO 2 blade GA
50 hrs on the 582 swapping for HKS 700E and Avid Cowl.
akflyer
PostPosted: Mon Apr 20, 2009 11:29 pm    Post subject: Re: Charging system trouble shooting Reply with quote
Same thing happened on my brothers KF II. I went to the key west thinking the regulator had fried. Turned out much worse, the charging coils were fried in a big way. It will only set ya back about a grand unless you can find a used one. Hopefully your problem is much simpler.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
Fox5flyer
PostPosted: Tue Apr 21, 2009 2:49 am    Post subject: Charging system trouble shooting Reply with quote
James, you might consider subscribing to the Aeroelectric list on Matronics.
There are some real electrical geeks over there and would be glad to help.
Deke
Tom Jones
PostPosted: Tue Apr 21, 2009 5:55 am    Post subject: Re: Charging system trouble shooting Reply with quote
Deleted, bad info.
Tom Jones
Classic IV
Ellensburg, WA
dave
PostPosted: Tue Apr 21, 2009 9:46 am    Post subject: Re: Charging system trouble shooting Reply with quote
James, Have you checked your battery ?
- Fluid level -- top with distilled water and slow charge over night
- once charge put on a load test.
I assume that after you put on the key west regulator that you ran a voltage check ? You should be getting about 14 V with engine running and 12.5 to 13.2 with engine off
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
kerrjohna(at)comcast.net
PostPosted: Tue Apr 21, 2009 10:26 am    Post subject: Charging system trouble shooting Reply with quote
My experience has been that these small batteries are only good for 12-18 months. Good advise.
John Kerr
Classic IV 912ul 784hrs
WurlyBird
PostPosted: Tue Apr 21, 2009 3:17 pm    Post subject: Re: Charging system trouble shooting Reply with quote
Thanks for the responses.
Tom, I sure have been learning a lot, in a good way I think. I am getting to do a lot of construction and repair type items but the plane is flyable through most of the problems so it keeps me entertained. I don't really follow with what you are saying about the Key West though. The Rotax regulator I removed had two yellow wires (no black stripe), a black, and a red, which all wired directly to the Key West.
Dave, besides taking the battery to the auto parts store how do you do a load test? The water is good and I always slow charge it.
When I first flip in the Master I usually have 12.5 to 13 volts indicated and it never gets any higher then that. Does this mean that there is no charging going on at all? I wouldn't doubt it.
Thanks again.
James
Float Flyr
PostPosted: Tue Apr 21, 2009 3:51 pm    Post subject: Charging system trouble shooting Reply with quote
When it is charging (engine running) you should see a minimum of 13.8V and
a max of 14.8V.
BTW the trickle charger is not the best for small batteries a pulse charger
is much better to maintain the electrical form of the battery. There are
pulse chargers for motorcycles that do fantastic jobs of keeping potteries
in tip top shape.
It sounds to me you have one of two problems. Either the voltage regulator
is not wired up correctly ( the black and red wires) or your lighting coil
in the mag is toast. Check the lighting coil for an open with an ohm meter.
If there is continuity start the engine and check there is AC voltage across
the two yellow wires. That requires you set your voltmeter to ACV not DCV a
common enough mistake.
An additional problem you may have is one of poor grounding. The regulator
senses the voltage level against a system ground. (battery -) Generally
this is done through the case of the regulator. If the regulator is mounted
on an insulated sheet or has a poor ground then the regulator may not work.
Make sure the metal under the regulator is nice and clean and shiny.
Best of luck
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Fox5flyer
PostPosted: Tue Apr 21, 2009 4:33 pm    Post subject: Charging system trouble shooting Reply with quote
Thanks again.
James
Kitfox 3 / 582 / GSC prop
Just about ready to take my check ride.
With engine running you should be getting somewhere around 14.5v at the
battery. If not you have a charging problem. Recheck your regulator wiring
before you start tearing things apart.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 402+ TT
- Joseph Joubert
WurlyBird
PostPosted: Tue Apr 21, 2009 5:49 pm    Post subject: Re: Charging system trouble shooting Reply with quote
Red flags are going up all of a sudden.
1. There is NO charging going on at the battery as is evidenced by the fact that the voltmeter does not indicate anything different between running and not.
2. The Key West is mounted to the front of the firewall which is covered on BOTH sides with fire retardant mats (this is where the original regulator was mounted). So it is pretty easy to say that there is either very little or no grounding at all between the regulator housing and the plane or battery.
So, if I were to cut away the matting behind the regulator should the firewall provide sufficient grounding?
When I "Check the lighting coil for an open" am I checking at the yellow wires? Can I check for this open as well as for an AC voltage at the terminals of the regulator without having to disconnect any other wires? Hopefully this will be as simple as doing a little cutting and then just running the engine out in the cul de sac, it's not like my neighbors don't already think I am nuts. Laughing
James
dave
PostPosted: Tue Apr 21, 2009 5:52 pm    Post subject: Re: Charging system trouble shooting Reply with quote
Key West regulator should not be showing over 14 V, Thy will usually be 13.8 to 13.9 volts that is one of their attributes. ON a Rotax regulator you cold get 14 to 18 v , I stay away from them.
Dave
Thanks again.
James
Deke Morisse
Mikado Michigan
- Joseph Joubert
Tom Jones
PostPosted: Tue Apr 21, 2009 6:20 pm    Post subject: Re: Charging system trouble shooting Reply with quote
Deleted, bad info.
tj
Tom Jones
Classic IV
Ellensburg, WA
Float Flyr
PostPosted: Tue Apr 21, 2009 6:34 pm    Post subject: Charging system trouble shooting Reply with quote
Answer to 2 is it should make sure the metal is shiny behind the regulator.
Most regulators ground through the back of the case. Some have additional
ground wires. It's worth checking the back of the regulator every three or
four years... more often in corrosive climates.
Check the continuity of the two yellow wires from the lighting coil.
Continuity testing will not tell you if there is a short in the coil but it
will tell you if there is a full open anywhere in the coil. Yes this is the
same two wires you check for AC voltage when you run your engine.
Disconnect at least one of the yellow connections to the regulator when you
do the AC-V and continuity tests.
You won't be the first to run an engine in a Cul De Sac... try to do it when
kids are in school and everybody else is off to work. Do not try to bribe
any cops who may turn up!
Finally, laugh at the neighbours from 3000 feet.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Tue Apr 21, 2009 6:38 pm    Post subject: Charging system trouble shooting Reply with quote
Guaranteed any regulator that allows buss voltage to climb to 18V will only
burn up your battery or worse!
Being a fan of Murphy and O'Tooles' laws I'd expect worse...much worse!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Paul A. Franz, P.E.
PostPosted: Tue Apr 21, 2009 6:44 pm    Post subject: Charging system trouble shooting Reply with quote
How was it that Johnny used to interrupt ed McMahon? Whoa, lead acid breath, let's
review this.
As pointed out earlier today in a post, an hour meter (Hobbs?) wired into the system,
might prevent the regulator from working. Or make it seem like the lighting coils were
ineffective. So, in the absence of any particular wisdom about his system, I think it
is appropriate to first isolate it to the battery, the charging system and a simple DC
load, like a headlamp.
Next, batteries don't have to be charged to capacity and in fact it is not at all
uncommon to have a vehicle manufacturer select a fully charged voltage of 13.6 to 13.8
volts. The batteries are thought to last longer doing so. Now, the maximum charged
voltage I've seen is 14.1 or 14.2 volts. I am under the impression that if you set a
battery charger to maintain a voltage higher than about that, it will just boil the
battery dry. So, what I am saying is, are you sure it's OK to see an applied voltage
that is sustained of 14.5 volts at the battery? I don't have test data right at hand,
but having it set that high might be cause for reduced battery life.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"When I took the oath of office, I pledged loyalty to only one
special interest group -- 'We the People.' Those people -- neighbors
and friends, shopkeepers and laborers, farmers and craftsmen -- do
not have infinite patience. As a matter of fact, some 80 years ago,
Teddy Roosevelt wrote these instructive words in his first message
to the Congress: 'The American people are slow to wrath, but when
their wrath is once kindled, it burns like a consuming flame.' Well,
perhaps that kind of wrath will be deserved if our answer to these
serious problems is to repeat the mistakes of the past."
-- Ronald Reagan
I don't make jokes. I just watch the government and report the facts.
-- Will Rogers
What this country needs are more unemployed politicians.
-- Edward Langley, Artist (1928-1995)
"[S]omething very ugly has surfaced in contemporary American
liberalism, as evidenced by the irrational and sometimes infantile
abuse directed toward anyone who strays from a strict party line.
Liberalism, like second-wave feminism, seems to have become a new
religion for those who profess contempt for religion. It has been
reduced to an elitist set of rhetorical formulas, which posit the
working class as passive, mindless victims in desperate need of
salvation by the state. Individual rights and free expression,
which used to be liberal values, are being gradually subsumed to
worship of government power. The problems on the American left were
already manifest by the late 1960s, as college-educated liberals
began to lose contact with the working class for whom they claimed
to speak. ... For the past 25 years, liberalism has gradually sunk
into a soft, soggy, white upper-middle-class style that I often
find preposterous and repellent. ... It's a comfortable, urban,
messianic liberalism befogged by psychiatric pharmaceuticals.
Conservatives these days are more geared to facts than emotions,
and as individuals they seem to have a more ethical, perhaps
sports-based sense of fair play."
-- columnist Camille Paglia
"The liberties of a people never were, nor ever will be, secure
when the transactions of their rulers may be concealed from them."
-- Patrick Henry
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
Fox5flyer
PostPosted: Wed Apr 22, 2009 4:55 am    Post subject: Charging system trouble shooting Reply with quote
Good points Paul. Thank you. To be more accurate I probably should have
stated "somewhere between 13.8 to 14.5", but even that probably would have
invited some sort of a correction. My point was, and what I was trying to
say, that if a voltage test only shows battery voltage then there is no
charge going on.
Deke
dave
PostPosted: Wed Apr 22, 2009 6:12 am    Post subject: Re: Charging system trouble shooting Reply with quote
Jame go back to the stasrt of this thread and all your answers right there. Smile
charge going on.
Deke
Posted: Tue Apr 21, 2009 9:52 pm Post subject: Re: Charging system trouble shooting Reply with quote Edit/Delete this post
Dave
Tom Jones
PostPosted: Wed Apr 22, 2009 7:33 am    Post subject: Re: Charging system trouble shooting Reply with quote
Oops, I have been confusing my Tympanium heavy duty regulator with the key West. I don't have any wiring knowledge for the key West. I am going to delete my other posts on this so as not to further confuse the issue along with the archives.
Sorry about that James
Key West on the left, Tympanium on the right
 Filesize:  19.28 KB
 Viewed:  18211 Time(s)
Tom Jones
Classic IV
Ellensburg, WA
WurlyBird
PostPosted: Fri Apr 24, 2009 7:46 pm    Post subject: Re: Charging system trouble shooting Reply with quote
So does it matter about the grounding so much now that the type of regulator is clarified? What is a logical starting point for trouble shooting, assuming the battery is fine, and the mags are fine?
James
dave
PostPosted: Sat Apr 25, 2009 2:36 am    Post subject: Re: Charging system trouble shooting Reply with quote
Did you check the voltage yet ?
Dave
Goto page 1, 2  Next
Page 1 of 2
