lie.buyse(at)telenet.be Guest
Posted: Mon Apr 20, 2009 3:33 am Post subject: Magneto high tension lead |
Hi,
Anyone knows if the magneto high tension lead (insulated 7,5 cm long and 7
mm wide pencil like rod wich connects the high tension coil to the
distributor cap), can be repaired or substituted by a piece of spark plug
wire? Insulation is burnt by arcing and I can't find a spare one. Unless I
buy an overhauled one, but it has only 20 hours since overhaul!
L. Buyse
Yak52 RA1428K
Posted: Mon Apr 20, 2009 3:42 am Post subject: Magneto high tension lead |
Here is a link to 7 mm wire which I have used in the past with no problems. http://www.mfgsupply.com/m/c/24-8775.html
Dennis
Posted: Mon Apr 20, 2009 9:50 am Post subject: Magneto high tension lead |
Thanks Dennis,
Is it necessary to solder some kind of "head" on both copper ends?
Lieven B.
Posted: Mon Apr 20, 2009 10:09 am Post subject: Magneto high tension lead |
No. You will see how the end fits into the starting coil when you remove it and the lead into the magneto is the same as all the other spark plug wires.
Dennis
yakplt(at)yahoo.com Guest
Posted: Mon Apr 20, 2009 2:36 pm Post subject: Magneto high tension lead |
Are we talking about the internal "cigarette" inside the mag, or the wire going from the starting spark transformer TO the mag?
I'm confused.
Mark Bitterlich
From: A. Dennis Savarese <dsavarese0812(at)bellsouth.net>
To: yak-list(at)matronics.com
Sent: Monday, April 20, 2009 2:04:04 PM
Subject: Re: Magneto high tension lead
Dennis
Posted: Tue Apr 21, 2009 1:25 am Post subject: Magneto high tension lead |
Indeed, the internal "cigarette" INSIDE the mag.
Lieven Buyse
| Quote: | ----- Oorspronkelijk bericht -----
Van
: Yak Pilot [mailto:yakplt(at)yahoo.com]
| Quote: | Verzonden
: dinsdag
, april
21, 2009 12:35 AM
| Quote: | Onderwerp
I'm confused.
Mark Bitterlich
Dennis
Posted: Tue Apr 21, 2009 3:04 am Post subject: Magneto high tension lead |
Ahhh! I misinterpreted your email. Please do not try to use the 7 mm wire I sent the link to. I do not have a fix for the internal cigarette. Sorry.
Dennis
Posted: Tue Apr 21, 2009 7:23 am Post subject: Magneto high tension lead |
Lieven, there should be several sources in the U.S. for that part. George
Coy, Carl Hays, Vladimir Yastremski, etc.
George is:
Motorstar NA
714 Airport Rd.
Swanton VT 05488
802-868-5633 off
802-363-5782 cell
george.coy(at)gmail.com
SKYPE george.coy
motorstarna.com
Vladimir Yastremski
858-780-1860
yastremski(at)msn.com
Carl Hays, via
Jill Gernetzke
M-14P, Incorporated
4905 Flightline Drive
Kingman, AZ 86401 -7417
(928)-681-4400
Fax(928)681-4404
www.m-14p.com
Mark Bitterlich
smime.p7s |
4.81 KB |
262 Time(s) |
dougsappllc(at)gmail.com Guest
Posted: Wed Apr 22, 2009 8:06 am Post subject: Magneto high tension lead |
I have a few in stock.
Doug Sapp
On Mon, Apr 20, 2009 at 4:32 AM, lieven buyse <lie.buyse(at)telenet.be (lie.buyse(at)telenet.be)> wrote:
| Quote: | --> Yak-List message posted by: "lieven buyse" <lie.buyse(at)telenet.be (lie.buyse(at)telenet.be)>
Hi,
Anyone knows if the magneto high tension lead (insulated 7,5 cm long and 7 mm wide pencil like rod wich connects the high tension coil to the distributor cap), can be repaired or substituted by a piece of spark plug wire? Insulation is burnt by arcing and I can't find a spare one. Unless I buy an overhauled one, but it has only 20 hours since overhaul!
ilities such as List Un/Subscription,
www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List
Matt Dralle, List Admin.
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
Posted: Wed Apr 22, 2009 8:20 am Post subject: Magneto high tension lead |
Doug, I'm an idiot. My sincere apologies for forgetting to mention you.
Mark
smime.p7s |
4.81 KB |
285 Time(s) |
Posted: Wed Apr 22, 2009 8:56 am Post subject: Magneto high tension lead |
now if I told you that you would be mad at me!! ;o)
No problem Mark.
Best from here,
doug
On Wed, Apr 22, 2009 at 9:15 AM, Bitterlich, Mark G CIV Det Cherry Point, MALS-14 64E <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
[quote]Doug, I'm an idiot. My sincere apologies for forgetting to mention you.
Mark
