bjudge(at)gmail.com Guest
Posted: Tue Apr 21, 2009 4:09 pm Post subject: DynaVibe prop Balancer |
Fellow RV drivers:
does anyone have any first hand experience with the DynaVibe dynamic prop balancing test set?
http://www.rpxtech.com/rpxweb/Dynavibe.asp
They are $1500 I'm kicking around the idea of throwing in with some other experimental owners and getting one. I've had some trouble getting my prop balanced locally and for $1500 it wouldn't take to many interested parties in my EAA Chapter to justify it. I just need to know that it does the job.
N84WJ
grumman1(at)hotmail.com Guest
Posted: Tue Apr 21, 2009 6:12 pm Post subject: DynaVibe prop Balancer |
You may want to go to e-bay and check out an EVA 2 electronic vibration anilizer C got mine for 450.00 C new thay run 1600.00 they are used in the auto ind.
works like a champ C
Michael P. Jefferson
Date: Tue C 21 Apr 2009 20:05:18 -0400
Subject: DynaVibe prop Balancer
To: rv-list(at)matronics.com
Fellow RV drivers:
N84WJ
Windows Live™ Hotmail®:…more than just e-mail. Check it out. [quote][b]
retasker(at)optonline.net Guest
Posted: Tue Apr 21, 2009 8:08 pm Post subject: DynaVibe prop Balancer |
How do you use the EVA2 to determine where to place weights on the
spinner to balance the prop? Trial and error or is there something that
I don't understand about this analyzer (probably) that would tell you this?
Dick Tasker
MIKE JEFFERSON wrote:
| Quote: | You may want to go to e-bay and check out an EVA 2 electronic
vibration anilizer, got mine for 450.00, new thay run 1600.00 they are
works like a champ,
Date: Tue, 21 Apr 2009 20:05:18 -0400
Fellow RV drivers:
N84WJ
ronics.com
ww.matronics.com/contribution
<http://windowslive.com/online/hotmail?ocid=TXT_TAGLM_WL_HM_more_042009>
Please Note:
No trees were destroyed in the sending of this message. We do concede, however,
that a significant number of electrons may have been temporarily inconvenienced.
Vanremog(at)aol.com Guest
Posted: Tue Apr 21, 2009 9:47 pm Post subject: DynaVibe prop Balancer |
This link has a pretty good explanation of the principles involved in dynamic prop balancing.
http://lists.kjsl.com/pipermail/beech-owners/2003-February/019466.html
N1GV (RV-6A Flying 920TTAE Silicon Valley, CA)
In a message dated 4/21/2009 9:09:51 P.M. Pacific Daylight Time, retasker(at)optonline.net writes:
| Quote: | How do you use the EVA2 to determine where to place weights on the
Big savings on Dell XPS Laptops and Desktops!
robin1(at)mrmoisture.com Guest
Posted: Tue Apr 21, 2009 11:53 pm Post subject: DynaVibe prop Balancer |
Zero experience with the device but my local prop shop charges $200 and says he should probably charge more. Should not take long to pay for it.
Robin
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Bill Judge
Sent: Tuesday, April 21, 2009 5:05 PM
Fellow RV drivers:
N84WJ | Quote: | | http://www.matronics.com/Navigator?RV-List | 0123456789
Checked by AVG - www.avg.com
04/21/09 16:48:00
dauscj(at)nb.net Guest
Posted: Wed Apr 22, 2009 3:23 am Post subject: DynaVibe prop Balancer |
Mike,
I am interested in the vibration analyzer you had mentioned about. I am trying to think it through and was wondering how you locate the rotational location to place or remove the weight needed to balance the object you are working on? I have not found any that have a strobe light included. Does your kit have one or is there a different way obtaining this information?
Thank you!
Chuck
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of MIKE JEFFERSON
Sent: Tuesday, April 21, 2009 10:11 PM
Subject: RE: DynaVibe prop Balancer
You may want to go to e-bay and check out an EVA 2 electronic vibration anilizer, got mine for 450.00, new thay run 1600.00 they are used in the auto ind.
works like a champ,
Fellow RV drivers:
N84WJ
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
Posted: Wed Apr 22, 2009 5:13 am Post subject: DynaVibe prop Balancer |
the strobe light consist of only a timming light C been using one for about 12 years (EVA)
N9805U
Date: Wed C 22 Apr 2009 07:21:16 -0400
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Mike C
Thank you!
Chuck
Sent: Tuesday C April 21 C 2009 10:11 PM
Fellow RV drivers:
N84WJ
Windows Live™ Hotmail®:…more than just e-mail. Check it out. | Quote: |
| Rediscover Hotmail®: Get quick friend updates right in your inbox. Check it out. [quote][b]
rv8iator
Posted: Wed Apr 22, 2009 5:22 am Post subject: DynaVibe prop Balancer |
Our EAA chapter has an electronic prop balance, EAA 105. Not sure if it's a Dynavibe. Email Randy Lervold
randy(at)romeolima.com
He will be able to provide details.
Chris Stone
_________________ C. Stone (RV8iator) |
Posted: Wed Apr 22, 2009 6:31 am Post subject: DynaVibe prop Balancer |
Thanks, but that is really not the information I need. I already know
the principles and how one does it in practice. I just don't know
enough about the EVA2 to know if it can be used like the description.
Possibly it has an output for a strobe and can be used exactly as the
description you referenced. If not, it could be used in a trial and
error approach. Check the balance. Add a little weight somewhere and
see if the balance improves or degrades. Adjust weights appropriately.
Fairly easy, but much easier with a synchronized strobe.
Dick
So the EVA2 has an output for synchronizing with a strobe?
Thanks, Dick
| Quote: | the strobe light consist of only a timming light, been using one for
N9805U
Date: Wed, 22 Apr 2009 07:21:16 -0400
Mike,
Thank you!
Chuck
[mailto:owner-rv-list-server(at)matronics.com] *On Behalf Of *MIKE JEFFERSON
*Sent:* Tuesday, April 21, 2009 10:11 PM
*To:* rv-list(at)matronics.com
*Subject:* RE: DynaVibe prop Balancer
works like a champ,
Fellow RV drivers:
N84WJ
ronics.com
Check it out.
<http://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_Updates2_042009>
Posted: Wed Apr 22, 2009 9:09 am Post subject: DynaVibe prop Balancer |
You bet C I will look to see if i still have my owners manual and try to run off a copy C
| Quote: | Date: Wed C 22 Apr 2009 10:28:51 -0400
Subject: Re: DynaVibe prop Balancer
--> RV-List message posted by: Richard Tasker <retasker(at)optonline.net>
Thanks C Dick
> N9805U
> From: dauscj(at)nb.net
> Mike C
> Thank you!
> Chuck
> *From:* owner-rv-list-server(at)matronics.com
> *Sent:* Tuesday C April 21 C 2009 10:11 PM
> From: bjudge(at)gmail.com
> Fellow RV drivers:
> Thanks
> Bill
> N84WJ
> ronics.com
> href="http://forums.matronics.com">http://forums.matronics.com
> href="http://www.matronics.com/contribution">http://www.matronics.com/c
> Check it out.
&g= Archive Search & Download C 7-Day Browse C Chat C FAQ C
&g==
rgf(at)dcn.davis.ca.us Guest
Posted: Wed Apr 22, 2009 9:24 am Post subject: DynaVibe prop Balancer |
A typical dynamic balancer will place an accelerometer on the engine and a
small reflective timing tape on the prop along with a cheap light detector.
The outputs are sent to the balancer which using equations of vibration will
figure out where and how much weight to place on the spinner backplate. No
strobe involved, and certainly no trial and error: it's all deterministic.
Once the weight is placed, it's measured once again to check the improvement
and job done.
Our RV club a year ago had a great presentation by a fellow who measures the
acceleration (vibration) both fore and aft, not just in the front.
Apparently this does a better job.
The principles of dynamic balancing are not quantum chromodynamics and the
equipment should be inexpensive, so no reason why these things should cost
huge amounts.
RF
