Molex - AMP "Mate-n-Lock" pin extraction tool
PostPosted: Tue Apr 14, 2009 6:23 pm    Post subject: Molex - AMP "Mate-n-Lock" pin extraction tool Reply with quote
At 12:32 PM 4/14/2009, you wrote:
Anyone know where I can get a high quality Molex - AMP "Mate-n-Lock pin extraction tool as sold by Steinair?
I have the blue and white tool as sold by Stein and Spruce but it is not the right tool. Need to do battle with keep on rebending it and once in a while lose a pin.
I have universal tool from Spruce but largest insert it is not big enough.
Radio Shack cheap extraction tool works great for their connectors but it is too small for Steins.
I saw on EAA instructional video a tool that looked like a blue anodized aluminium handle with a stout insert.
Depends on the specific connector. There are a number
of "similar" products which can be inserted/extracted
with a tool for another series . . . but as you can see
here:
http://tinyurl.com/clkq9t
http://tinyurl.com/dc6j2y
there's a whole fist-full of tools for the Mate-n-Lok
series connectors. Further, be sure you're not really
looking for a Waldom/Molex tool. Lots of folks mistake
the W/M parts for Tyco-Amp.
Your description of a "blue anodized tool" reminds me
of this critter:
[img]cid:.0[/img]
This is the Molex 11-03-0006 for the larger, .093 power
pins which are 'close' to Tyco-Amp Mate-n-Lok but no
cigar. The smaller .062 power pin tool is red. But
Digikey will have the tool you need once you figure out
which connectors you're working with.
( -Thomas Paine 1776- )
 Filesize:  13.17 KB
 Viewed:  4139 Time(s)
PostPosted: Tue Apr 14, 2009 7:39 pm    Post subject: Molex - AMP "Mate-n-Lock" pin extraction tool Reply with quote
FWIW, I removed all the molex connectors from my airframe
because they are the least reliable I know, highly prone to the
connectors backing out of the bodies secondary to vibration.
I was working at Cessna when the Amp Mate-n-Loks
came in the door. This would have been about 1968.
After years of paying homage to "aircraft quality"
connectors at Boeing and Cessna, I was skeptical
of these cheesy looking connectors.
In the intervening years, I've had numerous
occasions to ask FBO mechanics what problems they've
had to fight with those connectors. The complaints
were surprisingly few. If these things don't get
splashed with water or mechanically damaged, they've
held up well.
Of course, this presumes they've been installed
to the manufacturer's specifications.
rampil
PostPosted: Thu Apr 16, 2009 10:16 am    Post subject: Re: Molex - AMP Reply with quote
Hi Bob,
Sometimes your mileage may vary!
I used the AMP frame and the specified dies. One wire once pulled out
under minimal strain(and I will take the hit for that!), in the other cases,
the wire/connection pin or socket just backed out of the plastic.
Given the pain in the neck that repairing finished connectors in an airframe
can be, I chose to invest in a higher quality part which mostly translates to AMP CPC connectors
Ira
Ira N224XS
PostPosted: Thu Apr 16, 2009 4:52 pm    Post subject: Molex - AMP "Mate-n-Lock" pin extraction tool Reply with quote
At 01:16 PM 4/16/2009, you wrote:
Hi Bob,
Hmmmm . . . can you send me your tool, some pins and
the connectors you're working with? Something doesn't
add up here. AMP has been in business for a very long
time and they seldom stub their toe . . . especially
on a legacy product of some 40+ years.
