danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Fri Mar 31, 2006 3:56 am Post subject: paint finishing |
Hi All.
Now that I've finished the filling / sanding and the UV
Priming. its time to think of which top coat to use. As I've decided to
farm this job out to a "proper painter" a Polyurethane type would seem
to be the best.
So my question to fellow builders, What did you use on your bird? did
you find it satisfactory? any problems latter on?
Thanks in anticipation Danny
G-C.E.R.I.
build no 541
erichdtrombley(at)juno.co Guest
Posted: Sat Apr 01, 2006 6:57 am Post subject: paint finishing |
Regarding paint for your bird... I used Sherwin Williams Acry Glow an Acrylic Urethane which I highly recommend. It is a true aircraft paint and is resistant to most, if not all, solvents and fuels found on a plane. Very easy to apply for the novice painter, yet professional results are not uncommon. See archives for more info on painting with this product which I posted several years ago.
Erich Trombley
N28ET Classic Mono 914
Try Juno Platinum for Free! Then, only $9.95/month!
Regarding paint for your bird... I used Sherwin Williams Acry Glowan Acrylic Urethane which I highly recommend. It is atrue aircraft paint and is resistant to most, if not all, solvents and fuels found on a plane. Very easy to apply for the novice painter, yet professional results are not uncommon. See archives for more info on painting with this product which I posted several years ago.
Erich Trombley
