challgren(at)mac.com Guest
Posted: Fri Apr 10, 2009 7:44 am Post subject: Tubes in Tubeless Tires |
Listees:
I am concerned about the tubeless nose gear tire on my 701 going
flat and resulting in a greatly reduced prop clearance with the
ground. I had been considering installing a tube in the tire and was
surprised when the April Popular Mechanics had this to say on page
112: "Don't ever install a tube in a tire that says "tubeless on the
sidewall"... The ribbed inside surface of the tubeless tire is not
finished to accept a tube. Tube-type tires have smoother surfaces,
without any outstanding ribs or texture to wear out that tube
prematurely."
Does anyone know if the above applies to the tubeless tire provided
with the 701 kit? Has anyone installed a tube in their 701 nose gear
and flown it for a significant period of time?
Stan Challgren
701/3300
Building slowly due market crash
john.marzulli(at)gmail.co Guest
Posted: Fri Apr 10, 2009 7:53 am Post subject: Tubes in Tubeless Tires |
Zenith drop shipped the Matco tires and brakes to me. After having problems with the tubeless design I called Matco.
The guy at Matco happily sold me the correct tubes for the tires. Just make sure that you powder the insides appropriatley and keep the PSI to acceptable levels.
Good luck!
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
On Fri, Apr 10, 2009 at 8:43 AM, Stanley Challgren <challgren(at)mac.com (challgren(at)mac.com)> wrote:
[quote]--> Zenith701801-List message posted by: Stanley Challgren <challgren(at)mac.com (challgren(at)mac.com)>
Listees:
I am concerned about the tubeless nose gear tire on my 701 going flat and resulting in a greatly reduced prop clearance with the ground. I had been considering installing a tube in the tire and was surprised when the April Popular Mechanics had this to say on page 112: "Don't ever install a tube in a tire that says "tubeless on the sidewall"... The ribbed inside surface of the tubeless tire is not finished to accept a tube. Tube-type tires have smoother surfaces, without any outstanding ribs or texture to wear out that tube prematurely."
Does anyone know if the above applies to the tubeless tire provided with the 701 kit? Has anyone installed a tube in their 701 nose gear and flown it for a significant period of time?
Stan Challgren
701/3300
========================http://www.matronics.com/Navigator?Zenith701801-List
Matt Dralle, List Admin.
arno7452(at)bellsouth.net Guest
Posted: Fri Apr 10, 2009 8:21 am Post subject: Tubes in Tubeless Tires |
Hey Stan,
You might give it a try and see what happens. Keep us posted.
Ken
CH701 N701LK
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Fri Apr 10, 2009 8:39 am Post subject: Tubes in Tubeless Tires |
I put tubes in all of mine. Those tubeless ones drove me nuts and I didn't
trust them. Maybe I'm wrong but the psi on such a light airplane is so low
anyway. I have the same rims on my main gear on the Kitfox and they were
supplied with tubes from Matco or Grove, one or the other.
That sure may be true with car tires, though.
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Fri Apr 10, 2009 12:31 pm Post subject: Re: Tubes in Tubeless Tires |
My first 701 and the one I'm building now have tube type tires. They are generic turf tires. (Not suitable for highway use" is printed on the side). We didn't put tubes in the first one, per the plans, and never had a problem.
I wondered at the time if that was correct, but followed the plans, thinking the designer knew what he was talking about. About once every two months, we would air the tires up, usually about 15 lbs all around. They would leak down about 2-3 lbs over that span.
Not that I would recommend that to others, but that is what we did and we won't put tubes in this one either, since we had success with the first set of tires. Some wear suspenders and a belt because it makes them feel better, so if you feel better with tubes in your tires I say go for it.
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
lrm(at)skyhawg.com Guest
Posted: Fri Apr 10, 2009 6:16 pm Post subject: Tubes in Tubeless Tires |
The tires I got from Zenith, say in big black letters on the side "Tube
Type". However, Zenith recommends running them tubeless. They furnish
tubeless stems and "O" rings. I put tubes in mine. I trust the tire
manufacturers more than Zenith. Everything with Zenith is about saving
weight. Larry, N1345L
Stanley Challgren wrote:
<challgren(at)mac.com>
Listees:
Stan Challgren
701/3300
Checked by AVG - www.avg.com
kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Sat Apr 11, 2009 4:23 am Post subject: Re: Tubes in Tubeless Tires |
Not sure about doing this in airplanes though I cant see a problem at the 701 ground speed.
But my dad has been putting tubes in tubeless tires since I can remember and driving them on the road. And believe me that depression era man gets his moneys worth out of his tires, so they spend a lot of miles at to me, unsafe tread thickness, with no problems.
just my $.01 worth
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
jetboy
Posted: Sat Apr 11, 2009 10:01 pm Post subject: Re: Tubes in Tubeless Tires |
My kit was CZAW supplied with the Matco rims and "not for highway" "Tube type" tyres.
But after a year one tyre would leak slowly and at that time I discovered there are no tubes in there. I got a tube from ACS and fitted it, the leak was a thin area in the inside of the tyre that was venting out the tread groove. Four years on the other two are still OK as tubeless and I will fit tubes when they need it. What usually gets tyres around here is the gorse (braken?) prickles that sometimes inhabit bush runways. These will flatten tube or tubeless equally well. I run around 24 - 28 psi
Ralph
_________________ Ralph - CH701 / 2200a |
