E10 SI out from Rotax now
lucien
PostPosted: Fri Apr 10, 2009 7:41 am    Post subject: E10 SI out from Rotax now Reply with quote
Just FYI if it hasn't been announced earlier, the new SI for approval of E10 is now out on rotax-owner.com.
SI-912-016 for the 912 drivers, SI-2ST-008 for the 2-strokes.
For the 2 strokes, they approved only the 503 and 582 for E10. The 447 and
others they didn't test with 10% so they're officially still restricted to 5%. I suspect that means the 447 is soon to be discontinued since they didnt bother to test it.
Internally, don't know of anything significantly different with the 447 over the 503 so I bet it'll run and wear fine on E10.
So there we finally have it....
LS
LS
Titan II SS
Roger Lee
PostPosted: Fri Apr 10, 2009 8:19 am    Post subject: Re: E10 SI out from Rotax now Reply with quote
10% ethanol is approved. Posted below. Decalin is ok for avgas. 25 hr. oil chnages if you use avgas.
A 2 stroke SI listed also.
SI-2ST-008.pdf
2 stroke fluids
 Filename:  SI-2ST-008.pdf
 Filesize:  85.2 KB
 Downloaded:  400 Time(s)
SI-912-016.pdf
10% ethanol, ok
 Filename:  SI-912-016.pdf
 Filesize:  71.12 KB
 Downloaded:  1178 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Thom Riddle
PostPosted: Sat Apr 11, 2009 3:11 am    Post subject: Re: E10 SI out from Rotax now Reply with quote
Lucien,
My thoughts exactly. If Rotax drops production of the 447 that will open up the market a bit for their competitors' low powered lightweight engines, like Hirth, Simonini, and MZ.
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
