partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Wed Apr 08, 2009 6:00 pm Post subject: Phase I |
Is it possible/legal as a student pilot to be signed off for solo flight in ones own RV10 during the fly off of phase I? That would enable the checkride to be performed in the RV10 as well. Cross training with Alex has already been completed.
A CFI with 350 hours of RV10 time, and 4900 hours total time would be doing the signoff.
Don
_________________ Don A. McDonald
40636 |
LarryRosen
Posted: Wed Apr 08, 2009 6:21 pm Post subject: Phase I |
Anything is possible
Legal yes
Prudent - probably not
I would think the problem would be with the insurance company. Can you
get insurance for a solo student pilot in the 10?
Larry
partner14 wrote:
Don
Don A. McDonald
40636
http://forums.matronics.com/viewtopic.php?p 38421#238421
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
dlm46007(at)cox.net Guest
Posted: Wed Apr 08, 2009 6:37 pm Post subject: Phase I |
Unless you get a change to the standard operating limitations, only one
pilot is allowed in the RV10 during phase I testing and fly off. A change is
possible maybe , but likely not. N289DT received an inspection by the FAA
Airworthiness employee, not a DAR, and I believe got some exception but then
he had a private license and he still rolled it into a ball five months
after first flight
robin1(at)mrmoisture.com Guest
Posted: Wed Apr 08, 2009 6:59 pm Post subject: Phase I |
Possibly cheaper to buy or partner in a 152/172 than insure a 10 with
minimal experience. Yes RV's are fantastic to fly but that does not make
them slow enough for many student and low time pilots. I know for sure
my 6A gear would NEVER hold up to the punishment a low time pilot can
put on them. Bend the nose wheel ($) and look what hits next. Oh the
prop ($$). Now what's connected to the prop? Engine overhaul anyone
($$$)? I count a total of 6 $ signs.
If you happen to damage your plane not only will it cost you with
insurance etc... but you will be down with no plane to fly till it is
airworthy. Then you will have to rent a plane to fly while yours is
being repaired. If you are going to have to rent anyway why not do it
the other way around. Learn hard lessons in theirs before you fly yours.
While I am not a fan of Cessna's the engineer that designed their main
gears deserves an award.
Please keep in mind that every time you fill out an insurance
application you may have to recite the time you blah, blah, blah... and
placed a claim. It can haunt you for decades.
Robin
Tim Olson
Posted: Wed Apr 08, 2009 7:03 pm Post subject: Phase I |
Don,
There are some people who I've spoken to since Dan Lloyd put
his plane in the ground and we feel that no matter how much
we cringe to have to say it, we feel responsible to at least
speak up when we think the need arises. I know Stein and
myself both feel like kicking ourselves for not trying
harder with Dan. But anyway, please....don't be in a rush.
Just learn to fly and get your certificate, THEN fly your
RV-10. We will all feel very bad if something tragic happens.
Dan had somewhere around 200 hours when he crashed, and
the afternoon before he died he expressed how much more
of a handful his RV-10 was than that Cherokee he used to
fly.
In response to David, I do not believe Dan had special
permission from the FAA for having a 2nd person aboard.
I believe he knew that what he was doing was wrong.
partner14 wrote:
Don
Don A. McDonald
40636
pascal(at)rv10builder.net Guest
Posted: Wed Apr 08, 2009 7:47 pm Post subject: Phase I |
I think you give good advice on this Tim.
Don, get the license in a slow plane, it will give you more time to think
about what you need to do and time to recover from mistakes, Phase 1 is for
testing the plane not the pilot.
You flew with Alex, that is a great start, I suggest you get the license
with the CFI and than keep that CFI and spend a few more hours in your
neighbors RV-10 with that CFI, once the CFI signs you off as being ready
THAN get in your plane and solo around the pattern, remember your testing
the plane, assume something will go wrong when you do the solo and as long
as you and the CFI can say you're ready for anything than you'll be ready.
Pascal
Sent: Thursday, April 09, 2009 7:01 PM
Subject: Re: Phase I
Don,
fly.
> has already been completed. A CFI with 350 hours of RV10 time, and 4900
> Don
> Don A. McDonald
> 40636
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Tue Apr 14, 2009 12:20 pm Post subject: Phase I |
I would strongly recommend against it as a RV-10 is a much different beast than a trainer aircraft and it's a lot easier to get behind in a -10 than a trainer. Also, don't forget you need an HP endorsement under FAR 61.31(f) which is something, in my opinion, no instructor should be giving to a student pilot.
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgFar.nsf/FARSBySectLookup/61.31
Michael
AV8ORJWC
Posted: Tue Apr 14, 2009 12:58 pm Post subject: Phase I |
Hey Michael......"The tree of life can be self pruning".
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of RV Builder (Michael Sausen)
Sent: Tue 4/14/2009 1:18 PM
Subject: RE: Phase I
--> RV10-List message posted by: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
Michael
Posted: Tue Apr 14, 2009 3:53 pm Post subject: Phase I |
Sometimes the tree of life prunes others at the same time…
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Cox
Sent: Tuesday, April 14, 2009 1:53 PM
John Cox
Michael
61.09 KB |
6641 Time(s) |
24.86 KB |
6641 Time(s) |
120.48 KB |
6641 Time(s) |
83.96 KB |
6641 Time(s) |
dogsbark(at)comcast.net Guest
Posted: Tue Apr 14, 2009 5:48 pm Post subject: Phase I |
