jindoguy(at)gmail.com Guest
Posted: Wed Apr 08, 2009 6:53 am Post subject: Fwd: Re: IVOPROP Magnum installation instructions |
Gosh Bob, you haven't even begun to bed in the prop blades, yet. The fun is just beginning.
Rick
On Tue, Apr 7, 2009 at 8:07 PM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
To: ivoprop(at)pacbell.net (ivoprop(at)pacbell.net)
Subject: IVOPROP Magnum installation instructions
By way of introduction, I'm a retired electrical engineer
with 40+ years in aviation and other venues. I write and
publish the AeroElectric Connection, a guide for the
crafting of modern electrical systems in owner built and
maintained aircraft. I support a website at
Http://aeroelectric.com
and moderate an aviation electrical systems discussion
group with over 1800 subscribers on Matronics. com
One of my readers tells me that instructions for
one of your products calls for installing a wire
harness in its as-supplied length. When he asked about
cutting it to length, he tells me that your service
folks told him that the wiring resistance was part of
a critical calculation for the sizing of circuit breakers
. . . or some such.
I'm mystified by his understanding of the assertion. I
offered to write to your directly and inquire as to the
elements of physics that control your wire sizing and
why he is advised to install so much extra wire that
is not useful to his project.
I hope you can clear this up for me. Thanks!
| Quote: | Dear Robert, The elements of physics are not available.
The wire harness is used as a resistor. If shortened, too much current goes into the unit causing the carrier, gears, leadscrew, etc. to break. Once the spool reaches the stop, if the switch is continued
to be held the circuit breaker should pop within 5-7 seconds. It would be possible to shorten the wire
and put in its place a resistor that would cause the circuit
breaker to pop in the same amount of time. We do not encourage this because if there is a mistake,
parts will break and the factory sealed unit will need to be returned to our factory for repair. If the wire is too long it is best to just coil it up. Regards, Ron
Ron,
Hmmmm . . . I'm sorry to hear this. I would
have wished that design goals and demonstrable
robustness for this product were in closer
agreement with commercial aviation practices.
A motor driven gear train at risk for
damage by hitting mechanical stops could
not be qualified for use on a type certificated
aircraft. If limit switches and/or mechanical
torque limiters were not part of the basic
design, then some form of electrical torque
limiting is called for by tailoring the speed/
torque curve of the motor -AND- limiting energy
stored on the motor's armature when mechanical
limits are reached.
Is there a brake on the motor? What happens if the
prop mechanism becomes disconnected from the motor?
Will the mechanism back-drive? What pitch state does
the prop go if the drive train becomes disconnected?
It is stable in that state?
What is the maximum expected operating current for
the motor? What is it's expected stall current at
14.5V with the lead lengths as-supplied? What is
the as-supplied wire size? What is the size and
manufacturer's part number for the supplied breaker?
( -Thomas Paine 1776- )
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
http://forums.matronics.com
le, List Admin.
