canopy
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List
robertrv607(at)yahoo.com
PostPosted: Sun Apr 05, 2009 11:03 am    Post subject: canopy Reply with quote
Hi:
I have decided to re work my canopy, that is to remove the canopy and get a new canopy frame.
It never fit in a manner I would like.. soooo does any one have a
canopy frame for sale? or perhaps and old canopy, not being used ..
Trying to save some money...I know the work would be a pain....I even
try to talk to some people, south in Florida, i got the names from some
\one on the list... They did not know any thing on how to to do this,
or they did not want to do it, this guy tells me reluctanly,, well
if we do it would be about $1,200, exactly what he said...they are a
joke.. I understand, if some one does not want to do the jobe, that is
fine, just say so..or sorry we do not do that type of work etc...
That is the situation now..
any suggestions, ideas, appreciated
I have the Rv6a..
robert
- The Matronics RV6-List Email Forum -
http://www.matronics.com/Navigator?RV6-List
ghfrost(at)earthlink.net
PostPosted: Sun Apr 05, 2009 11:39 am    Post subject: canopy Reply with quote
On Apr 5, 2009, at 3:03 PM, bert murillo wrote:
Hi:
some
is
I have the Rv6a..
robert
wdleonard(at)gmail.com
PostPosted: Sun Apr 05, 2009 2:17 pm    Post subject: canopy Reply with quote
Robert,
like many of the early QB RV-6's, the fit of my canopy was appauling.  Particularly at its leading edge.  Being disinclined to re-do any of that canopy work, I instead eventually 'fixed' the problem by laying up micro over the front turtledeck and on the front deck of the canopy frame.  Then just sand down until it looks like it fits better, and paint.  added a couple of pounds, but turned out OK and at least I didn't have to re-do the canopy (and potentially get the same problem all over again.
David Leonard
Turbo Rotary RV-6 N4VY
http://N4VY.RotaryRoster.net
http://RotaryRoster.net
On Sun, Apr 5, 2009 at 12:03 PM, bert murillo <robertrv607(at)yahoo.com (robertrv607(at)yahoo.com)> wrote:
--> RV6-List message posted by: bert murillo <robertrv607(at)yahoo.com (robertrv607(at)yahoo.com)>
Hi:
I have the Rv6a..
robert
http://w===
http://forums.mle, List Admin.
rledwards9(at)yahoo.com
PostPosted: Sun Apr 05, 2009 7:43 pm    Post subject: canopy Reply with quote
I had` the same problem with the frame on my QB6. I did some "forming" and fiberglass buildup for the rest of the fit. It was a lot of extra work for a poor fitting frame. Never could get the rear skirt to fit nice and tight. I suspect Van's would have fired the welding shop for this frame if they had to use it on one of their planes. ??
--- On Sun, 4/5/09, David Leonard <wdleonard(at)gmail.com> wrote:
Subject: Re: canopy
To: rv6-list(at)matronics.com
Date: Sunday, April 5, 2009, 6:14 PM
Robert,
again.
David Leonard
bert murillo <robertrv607(at)yahoo.com>
posted by: bert murillo <robertrv607(at)yahoo.com>
Hi:
one have a
used ..
pain....I even
names from some
to to do this,
reluctanly,, well
said...they are a
jobe, that is
etc...
I have the Rv6a..
robert
rowse, Chat, FAQ,
="http://www.matronics.com/Navigator?RV6-List"
target="_blank">http://w===
Admin.
PostPosted: Mon Apr 06, 2009 10:21 am    Post subject: canopy Reply with quote
HI:
Thanks to all those who respoonded to my question on the canopy,
I should clarify that I have the Slider, and the poor fiting I have
is mainly on the sides, the rear portion...I understand the only way I could fix this, is to remove everything and re-bend the frame..
which I do not want to even think about it..
The options some suggested, would be using fiber glass, to fill the spaces
, that would be fine, in my case the space is too large to do this,
almost 3/8..
I think if I could get a new frame, I would have to start all over..
remove everything and, put the plexi on the new frame no?\
Where can I get a frame, cheaper than, buying a new one, that is the question.
Any how, thanks to all for your suggestions.
Bert
rv6a
n8zg(at)mchsi.com
PostPosted: Mon Apr 06, 2009 1:49 pm    Post subject: canopy Reply with quote
Bert -
My RV-7 slider canopy was also too wide after I put the plexi on (Sikaflex).
I wrapped a cargo strap around it and cranked it down. Then put it inside a
plywood box with some quartz shop-lights for heat, and monitored the
temperature with a thermometer stuck thru the top. Left it for six hours,
turned the lights off and let it cool in the box with the strap in place.
Several iterations with progressively higher tension on the strap got it to
fit much better.
It took a LOT of tension to get the plexi to move a little. I finally quit
because I was afraid I'd find the yield point and kink the frame.
neal
HI:
almost 3/8..
question.
Bert
rv6a
PostPosted: Mon Apr 06, 2009 2:17 pm    Post subject: canopy Reply with quote
Neal"Razz
Thanks for the idea. I will be afraid to crack the canopy.  The problem is that
the Canopy frame, needs to be bend..and it is more than a couple of 1/16 that is the problem..
I guess  have to bite the bullet, and buy a new frame, fit it first right, then remove
the old canopy and fit it again.
thanks
bert
rv6a
--- On Mon, 4/6/09, Neal George <n8zg(at)mchsi.com> wrote:
Subject: RE: canopy
Date: Monday, April 6, 2009, 5:45 PM
Bert -
Bill Schlatterer
PostPosted: Mon Apr 06, 2009 5:25 pm    Post subject: canopy Reply with quote
Bert, this is just a thought. There is sort of metal/glass skirt combination that might work for you. Before you go to all that trouble, you might try just slotting the rear skirt where it bulges. Cut a couple of slots (1/16 to 1/8 wide as needed) in the skirt with a dremel tool running at an angle to match the bulge. This will allow you to bend individual pieces of the skirt down to match the profile of the deck. Should be able to adjust/bend the side skirts a little when the pressure on the rear skirt is gone. Close the canopy on a plastic sheet and then lay up glass over the original skirt covering the "adjustment slots". Couple of layers of glass and I think you end up with a nice looking skirt although it might pick up a pound or two of weight as you can't just glass one part. On the other hand, it will sound like the door on a Cadillac when it shuts Wink and you will have zero stress on the canopy itself.
If that doesn't work, you aren't any worse off. Not at all sure you couldn't just cut off the back couple of inches of the skirt and use the remaining part that is still riveted to the canopy as the base to bond on a new glass skirt.
If that doesn't work, then move on to new frame, refit canopy, etc,...
Bill S
7a nothing but the wings left
From: owner-rv6-list-server(at)matronics.com [mailto:owner-rv6-list-server(at)matronics.com] On Behalf Of bert murillo
Sent: Monday, April 06, 2009 5:17 PM
Subject: RE: RV6-List: canopy
Neal"Razz
thanks
bert
rv6a
--> RV6-List message posted by: "Neal George" <n8zg(at)mchsi.com (n8zg(at)mchsi.com)>
Bert -
fit much better.
neal
HI:
almost 3/8..
question.
Bert
rv6a
href="http://www.matronics.com/Navigator?RV6-List">http://www.matronics.com/Navigator?RV6-List
 Filesize:  79.36 KB
 Viewed:  11310 Time(s)
 Filesize:  88.03 KB
 Filesize:  69.76 KB
 Filesize:  105.79 KB
 Filesize:  103.47 KB
bertrv6(at)gmail.com
PostPosted: Wed Apr 08, 2009 6:44 am    Post subject: canopy Reply with quote
Bill:
Thanks fo the suggestion, it is a good one, however in my case, what
happens is the frame itself, is a little too wide at the rear,
so the problem is to re bend it if that is possible now. yours look very good..
Bert
rv6a
On Mon, Apr 6, 2009 at 9:23 PM, Bill Schlatterer
new glass skirt.
Bill S
Subject: RE: canopy
Neal"Razz
that
then remove
thanks
bert
rv6a
Subject: RE: canopy
Bert -
fit much better.
neal
HI:
almost 3/8..
question.
Bert
rv6a
rv6larry(at)msn.com
PostPosted: Wed Apr 08, 2009 2:25 pm    Post subject: canopy Reply with quote
Bert C
If you can remove the plexiglass you may be able to cut a small section out on each side of the rear frame (enough to pull frame in to proper fit) Then find some tubing with the outside diameter slightly smaller than the inside diameter of the tubing frame and use it to splice the frame back together. Tack weld or possibly rivet back together.
Good luck
Larry Rhea
[quote] Date: Wed C 8 Apr 2009 10:42:25 -0400
Subject: Re: canopy
--> RV6-List message posted by: bert murillo <bertrv6(at)gmail.com>
Bill:
Thanks fo the suggestion C it is a good one C however in my case C what
happens is the frame itself C is a little too wide at the rear C
Bert
rv6a
On Mon C Apr 6 C 2009 at 9:23 PM C Bill Schlatterer
> Bert C this is just a thought.  There is sort of metal/glass skirt
> combination that might work for you.  Before you go to all that trouble C you
> pound or two of weight as you can't just glass one part.  On the other hand C
> If that doesn't work C you aren't any worse off.  Not at all sure you
> new glass skirt.
> If that doesn't work C then move on to new frame C refit canopy C etc C...
> Bill S
> ________________________________
> Sent: Monday C April 06 C 2009 5:17 PM
> Subject: RE: canopy
> Neal"Razz
> that
> the Canopy frame C needs to be bend..and it is more than a couple of 1/16
> I guess  have to bite the bullet C and buy a new frame C fit it first right C
> then remove
> thanks
> bert
> rv6a
> do not archive
> --- On Mon C 4/6/09 C Neal George <n8zg(at)mchsi.com> wrote:
> From: Neal George <n8zg(at)mchsi.com>
> Subject: RE: canopy
> Date: Monday C April 6 C 2009 C 5:45 PM
> --> RV6-List message posted by: "Neal George" <n8zg(at)mchsi.com>
> Bert -
> plywood box with some quartz shop-lights for heat C and monitored the
> temperature with a thermometer stuck thru the top.  Left it for six hours C
> fit much better.
> neal
> --> RV6-List message posted by: bert murillo <robertrv607(at)yahoo.com>
> HI:
> Thanks to all those who respoonded to my question on the canopy C
> I should clarify that I have the Slider C and the poor fiting I have
> is mainly on the sides C the rear portion...I understand the only way I could
> fix this C is to remove everything and re-bend the frame..
> The options some suggested C would be using fiber glass C to fill the spaces
> C that would be fine C in my case the space is too large to do this C
> almost 3/8..
> I think if I could get a new frame C I would have to start all over..
> remove everything and C put the plexi on the new frame no?\
> Where can I get a frame C cheaper than C buying a new one C that is the
> question.
> Any how C thanks to all for your suggestions.
> Bert
> rv6a
> do not archive
> href="http://forums.matronics.com">http://forums.matronics.com
> href="http://www.matronics.com/contribution">http://www.matronics.com/c
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV6-List All times are GMT - 8 Hours
