andrew(at)nzactive.com Guest
Posted: Thu Apr 02, 2009 11:56 pm Post subject: Fuel tank/burn questions |
Guys, thanks for all the kind responses re fuel caps. It's all sorted.
I have some questions which may sound nuts, but which are better asked
here than figured out in the air:
1. Has anyone heard of (early) RV-4 tanks of less than 16 gallons
capacity? I ran a tank dry today, by mistake, switched over and
landed...and when I refuelled, it only took 12.5 gallons. I've got
aerobatic baffles, so it takes a while for the fuel to settle in, but I
took my time, and 12.5 it was. I then flew on that tank for exactly an
hour (2 x 30 mins) and it ran dry AGAIN, which leads me to ask...
2. Is a fuel burn of 16 gallons an hour, WOT, 5000 feet, and leaned ROP
reasonable? I was definitely leaned out, albeit conservatively. (Don't
have the instrumentation to support LOP running). Sounds crazy to me.
Anyone care to tell me what reasonable burns in an 0-360 at altitude,
FP, might be?
3. Anything y'all can think of that might reduce the effective volume of
a fuel tank? (A leak, I thought....but can't see one - and that doesn't
explain the fact that the tank took 12.5 gallons after having been
conclusively established as empty, and unseable fuel drained.)
4. OK, now it gets really weird. Anyone ever hear of fuel caps being
"sucked" out of the wing, in flight? This happened to me y/day, and
again (other wing) 2 days prior. I am aware it sounds bizarre. The RV is
just coming off long term sitting around, cos I mainly fly my beloved
Harmon Rocket, and I wonder if it's possible that caps could get old,
and not "spread" when the lever is snapped flush with the top of the
wing.
All comments from those more experienced in RVs than me would be
welcomed. Me and my RV are just getting to know each other again, after
a long time of being unfaithful to her, in the Rocket
Cheers
Andrew
________________________________________________________________________
Posted: Fri Apr 03, 2009 5:06 am Post subject: Fuel tank/burn questions |
Andrew, I'm going to answer even though I'm not an experienced RVer just
yet. I am just now coming off a fuel related incident in my Pitts with
an O-360 in it. I don't believe you can eat up 16 gal of gas in an
hour. I get somewhere between 10 and 11 and hour when I'm WOT doing
aerobatics.
However things you said may point to your possible problem: If you can
suck the caps out, then you can suck fuel out too. I'd replace the
O-rings and/or adjust the cap so the caps are really tight ..... to the
point where it's hard to open. But what do I know???
Linn
ACTIVE NZ - Andrew wrote:
FP, might be?
wing.
Cheers
Andrew
Posted: Fri Apr 03, 2009 5:36 am Post subject: Fuel tank/burn questions |
I've not heard of smaller fuel tanks - I thought the -4 and the -6 had similar configurations....so much for what I know...
I'm breaking in a new IO360B1F6 (180hp) in my 6A with 19 gal tanks and I see 16 gph fuel flows on my engine monitor - I'm running 25.5 squared for the break-in period. I haven't done much leaning at all as I have been doing most of my flying at 3000' and below. The total fill up matches what the engine monitor says.
Ralph
RV6A N822AR (at) N06 8.3 hrs
khorton01(at)rogers.com Guest
Posted: Fri Apr 03, 2009 5:47 am Post subject: Fuel tank/burn questions |
On 3 Apr 2009, at 03:57, ACTIVE NZ - Andrew wrote:
but I
ROP
FP, might be?
volume of
doesn't
RV is
wing.
after
Andrew,
Assuming the fuel tanks were built according to the plans, the tank
capacity should be pretty close to 16 USG. But, there are possible
fuel pickup issues that could cause the fuel pickup to suck air wile
there is still a lot of fuel left in the tank. Possible fuel pickup
issues are:
1. inverted fuel pickup hung up inside tank, such that it its end is
no longer at the lowest point,
2. inverted fuel pickup unscrewed at the elbow inside the forward
inboard end of the tank,
3. normal fuel pickup rotated so that its end is well above the bottom
of the tank, or
4. normal fuel pickup tube broken off.
See http://www.vansaircraft.com/pdf/sb06-2-23.pdf
In all the above cases, you would be able to drain several gallons
from the tank drain after a fuel starvation event.
One other possible cause is a fuel vent blockage that hinders the air
from entering the tank to replace the fuel that is being sucked out.
Ensure the fuel vents are completely clear.
If you can drain only a minimal amount of fuel from the drain after a
fuel starvation event, and an unusually low quantity is required to
fill the tank up, maybe there is a large quantity of solid matter in
the tank. It would be wise to remove the inspection cover on the
inboard end of the tank to do an inspection. Also inspect all fuel
filters for contamination.
Good luck,
Kevin Horton (Grounded)
RV-8 (Flight Test Phase)
Ottawa, Canada
http://www.kilohotel.com/rv8
john_s_bright(at)yahoo.co Guest
Posted: Fri Apr 03, 2009 6:00 am Post subject: Fuel tank/burn questions |
What does it mean to suck the caps out of the wing in flight?
John Bright
o:757-864-2305
h:757-874-0861
c:757-812-1909
mrobert569(at)hotmail.com Guest
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Fri Apr 03, 2009 12:10 pm Post subject: Fuel tank/burn questions |
On Fri, 2009-04-03 at 20:57 +1300, ACTIVE NZ - Andrew wrote:
| Quote: | it only took 12.5 gallons.
| Kevin's response covers the options. Key question is if you can drain fuel from the 'dry' tank.
If you have a fuel gauge, what does it read?
Does the alternate tank have the same issue?
Consider: (16 - 12.5) leaves 3.5 gallons in the tank. 3.5 gal is about 25% full scale on the Vans fuel gauge that is reasonably accurate at this level, so you are most likely sucking air when fuel is about 25% up the inboard tank rib. My money is on a loose/cracked/damaged fuel pickup.
Doug [quote][b]
Doug Gray
Posted: Fri Apr 03, 2009 12:26 pm Post subject: Fuel tank/burn questions |
On Sat, 2009-04-04 at 06:08 +1000, Doug Gray wrote:
Wait a minute - are you in New Zealand? 12.5 Imp Gallons * 1.2 => 15 USG
You might also be losing fuel - check tank & gascolator drains under pressure, perhaps through the poorly sealed caps.
Seems to me you are being punished for flirting with a Rocket! [quote][b]
denis.walsh(at)comcast.ne Guest
Posted: Fri Apr 03, 2009 2:40 pm Post subject: Fuel tank/burn questions |
first of all my money is with Doug's Imperial answer.
As to cap sucking. My six has blown (had sucked) off a couple tank caps over the years. I now carry a spare with me. In my case they were left loose, either by the fueler or by me.
The good news is that in coordinated flight and reasonable attitudes and speeds, the fuel quits drooling after only a half gallon or so.
I should add that I have also fliight checked another fascinating condition, which is having the fuel cap slightly cocked in the receptacle, but latched snug. This can also result in fuel going overboard, due to the aforementioned low pressure area over the cap. Again the fuel drool stops after a short time in coordinated flight, most likely because of the fortuitous dihedral of the Van's wing.
Denis
On Apr 3, 2009, at 2:24 , Doug Gray wrote:
| Quote: | On Sat, 2009-04-04 at 06:08 +1000, Doug Gray wrote:
Seems to me you are being punished for flirting with a Rocket! | Quote: |
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
