EGT Sensors installation and clocking
AirMike
PostPosted: Thu Apr 02, 2009 9:05 pm    Post subject: EGT Sensors installation and clocking Reply with quote
I have the AFS3500 EGT kit. Any suggestions or better yet pictures of the final installed position of the sensors?
I was told to install 2" out from the flange on the engine. I am worried about the clocking so that the wire ends do not interfere with the cowling.
Any suggestions, comments and pictures appreciated
See you OSH '18
Q/B - sold.
jcumins(at)jcis.net
PostPosted: Thu Apr 02, 2009 11:19 pm    Post subject: EGT Sensors installation and clocking Reply with quote
One other thing u have to be careful with is the plug removal, install them
as to be able to install and remove the spark plugs. Contact me off list
and I can tell you how I did my Saratoga.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
Tim Olson
PostPosted: Fri Apr 03, 2009 3:20 am    Post subject: EGT Sensors installation and clocking Reply with quote
Make sure as you set them up you also have your plugs and wires in
place so you don't interfere there. If you do that and then clock
them as low profile as possible you should be ok.
Tim
with the cowling.
OSH '08 or Bust (busted) be there in &quot;09
Q/B Kit - wiring and FWF
http://forums.matronics.com/viewtopic.php?p 37488#237488
drfred(at)suddenlinkmail.
PostPosted: Fri Apr 03, 2009 6:52 am    Post subject: EGT Sensors installation and clocking Reply with quote
Mike;
How soon do you need pics.? I have the same setup. I can pull the
cowling this weekend and take a few pics if that would help.
Dr Fred
call if needed
903 491 5207 cell
I'll probably be free from that day job thing after 1 pm central time..
partner14
PostPosted: Fri Apr 03, 2009 7:18 am    Post subject: EGT Sensors installation and clocking Reply with quote
Can't remember exactly what distance was recommended (2"-4"?), but I believe the critical element is to make them all the same. I think mine are 3"... Make sure you measure the inside radius of the pipe and make a mark, and then the outside of the radius of the pipe and make another mark. Then figure where the sensor needs to be to clear everything (plugs, wires, etc), and then draw a line between those tow marks. I kept mine to the inside thus avoiding the cowl problem.
Don McDonald
--- On Thu, 4/2/09, AirMike <Mikeabel(at)Pacbell.net> wrote:
Subject: EGT Sensors installation and clocking
Date: Thursday, April 2, 2009, 10:05 PM
--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net (Mikeabel(at)Pacbell.net)>
http://forums.matronics.combsp; --> http://foru - List Contribution We -Matt Dralle, Listm/contribution" target=_blank>http://www.matronics.com/contribution
 Filesize:  307.63 KB
 Viewed:  8546 Time(s)
 Filesize:  755.75 KB
 Filesize:  295.3 KB
Don A. McDonald
40636
jim(at)CombsFive.Com
PostPosted: Fri Apr 03, 2009 5:37 pm    Post subject: EGT Sensors installation and clocking Reply with quote
Here is the left side of my installation. Picture xx35 is the front / middle pipes, xx34 is the middle and rear cylinders. I used the same clocking on the other side (leads go toward the prop).Jim CN312F - Flying (40192)Do Not Archive--> RV10-List message posted by: "AirMike" <Mikeabel(at)Pacbell.net>I have the AFS3500 EGT kit. Any suggestions or better yet pictures of thefinal installed position of the sensors?I was told to install 2" out from the flange on the engine. I am worriedabout the clocking so that the wire ends do not interfere with thecowling.Any suggestions, comments and pictures appreciated--------OSH '08 or Bust (busted) be there in &quot;09Q/B Kit - wiring and FWFRead this topic online here:http://forums.matronics.com/viewtopic.php?p 37488#237488
 Filesize:  440.32 KB
 Viewed:  8533 Time(s)
 Filesize:  407.2 KB
planesmith(at)hotmail.com
PostPosted: Sat Apr 04, 2009 8:43 pm    Post subject: EGT Sensors installation and clocking Reply with quote
Jim C
Do you ( or anyone else) have a photo of the area about 6" under the pictures you sent? I'm trying to figure out the best routing for the fuel line from the mechanical fuel pump to the Bendix servo to get it away from the exhaust.
Thanks C
Vern Smith (#324 finishing)
Date: Fri C 3 Apr 2009 21:35:28 -0400
Subject: Re: EGT Sensors installation and clocking
Here is the left side of my installation.  Picture xx35 is the front / middle pipes C xx34 is the middle and rear cylinders.  I used the same clocking on the other side (leads go toward the prop).
Jim C
cowling.
Any suggestions C comments and pictures appreciated
http://forums.matronics.com/viewtopic.php?p=237488#237488
Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check it out. [quote][b]
PostPosted: Sun Apr 05, 2009 3:44 am    Post subject: EGT Sensors installation and clocking Reply with quote
Vern,Here is a front view from the front. There is a right angle fitting at the fuel servo and the line runs along side it back to the fuel pump. The DAR suggested and helped me attach the scat tubing to the fuel line for the same reason. Get it away from the exhaust.Jim CombsN312F - Flying (50+ hours)40192-------------------------------------------------------------------------------------------------------------------Jim,Do you ( or anyone else) have a photo of the area about 6" under thepictures you sent? I'm trying to figure out the best routing for the fuelline from the mechanical fuel pump to the Bendix servo to get it away fromthe exhaust.Thanks,Vern Smith (#324 finishing)do not archiveDate: Fri, 3 Apr 2009 21:35:28 -0400Subject: Re: EGT Sensors installation and clockingFrom: jim(at)CombsFive.ComTo: rv10-list(at)matronics.comHere is the left side of my installation. Picture xx35 is the front/ middle pipes, xx34 is the middle and rear cylinders. I used thesame clocking on the other side (leads go toward the prop).JimCN312F - Flying (40192)Do Not Archive-->RV10-List message posted by: "AirMike"<Mikeabel(at)Pacbell.net>I have the AFS3500 EGT kit. Anysuggestions or better yet pictures of thefinal installed position ofthe sensors?I was told to install 2" out from the flangeon the engine. I am worriedabout the clocking so that the wire endsdo not interfere with thecowling.Any suggestions,comments and pictures appreciated--------OSH '08 or Bust(busted) be there in &quot;09Q/B Kit - wiring and FWFRead this topic online here:http://forums.matronics.com/viewtopic.php?p 37488#237488_________________________________________________________________Rediscover Hotmail®: Now available on your iPhone or BlackBerryhttp://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_Mobile1_042009
 Filesize:  353.12 KB
 Viewed:  8514 Time(s)
PostPosted: Sun Apr 05, 2009 3:57 am    Post subject: EGT Sensors installation and clocking Reply with quote
VErn,Here are a couple more.Jim CombsN312F - Flying----------------------------------------------------------------------------------------------Jim,Do you ( or anyone else) have a photo of the area about 6" under thepictures you sent? I'm trying to figure out the best routing for the fuelline from the mechanical fuel pump to the Bendix servo to get it away fromthe exhaust.Thanks,Vern Smith (#324 finishing)do not archiveDate: Fri, 3 Apr 2009 21:35:28 -0400Subject: Re: EGT Sensors installation and clockingFrom: jim(at)CombsFive.ComTo: rv10-list(at)matronics.comHere is the left side of my installation. Picture xx35 is the front/ middle pipes, xx34 is the middle and rear cylinders. I used thesame clocking on the other side (leads go toward the prop).JimCN312F - Flying (40192)Do Not Archive-->RV10-List message posted by: "AirMike"<Mikeabel(at)Pacbell.net>I have the AFS3500 EGT kit. Anysuggestions or better yet pictures of thefinal installed position ofthe sensors?I was told to install 2" out from the flangeon the engine. I am worriedabout the clocking so that the wire endsdo not interfere with thecowling.Any suggestions,comments and pictures appreciated--------OSH '08 or Bust(busted) be there in &quot;09Q/B Kit - wiring and FWFRead this topic online here:http://forums.matronics.com/viewtopic.php?p 37488#237488_________________________________________________________________Rediscover Hotmail®: Now available on your iPhone or BlackBerryhttp://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_Mobile1_042009
 Filesize:  434.76 KB
 Filesize:  380.1 KB
kdbelue(at)charter.net
PostPosted: Sun Apr 05, 2009 6:03 am    Post subject: EGT Sensors installation and clocking Reply with quote
Jim,
I noticed that you have a straight (flat) mixture arm in your photos.
I had one like that and couldn't get it to fit with the air filter
box. I had to buy the dogleg version as shown in the plans. Have you
fitted the airbox yet?
Kevin Belue
RV-6A flying
RV-10 flying
On Apr 5, 2009, at 6:56 AM, jim(at)CombsFive.Com wrote:
VErn,
Jim Combs
N312F - Flying
Jim,
fuel
away from
the exhaust.
Jim
C
the sensors?
cowling.
Any suggestions,
OSH '08 or Bust
Rediscover HotmailĀ®: Now available on your iPhone or BlackBerry
<DCP_2330.JPG>
<DCP_2331.JPG>
PostPosted: Sun Apr 05, 2009 10:00 am    Post subject: EGT Sensors installation and clocking Reply with quote
Jim C
Thank you for the pictures. They are just what I needed.
Vern
Date: Sun C 5 Apr 2009 07:56:38 -0400
Subject: RE: EGT Sensors installation and clocking
VErn C
Jim Combs
N312F - Flying
GLM_WL_HM_Rediscover_Mobile1_042009Rediscover Hotmail®: Get quick friend updates right in your inbox. Check it out. [quote][b]
PostPosted: Sun Apr 05, 2009 1:45 pm    Post subject: EGT Sensors installation and clocking Reply with quote
Vern,Glad to help out.JimC-----------------------------------------------------------------------------------------------------Jim,Thank you for the pictures. They are just what I needed.Verndo not archive [quote][b]
PostPosted: Sun Apr 05, 2009 2:07 pm    Post subject: EGT Sensors installation and clocking Reply with quote
I made a spacer using 1" aluminum. I didn't like the idea of cutting into the side of the airbox to make room for the throttle arm.I will post a picture as soon I figure what directory I hid the darn thing in!Jim CN312F - Flying--> RV10-List message posted by: Kevin Belue <kdbelue(at)charter.net>Jim,I noticed that you have a straight (flat) mixture arm in your photos.I had one like that and couldn't get it to fit with the air filterbox. I had to buy the dogleg version as shown in the plans. Have youfitted the airbox yet?Kevin BelueRV-6A flyingRV-10 flyingSent from my iPhoneOn Apr 5, 2009, at 6:56 AM, jim(at)CombsFive.Com wrote:> VErn,>> Here are a couple more.>> Jim Combs> N312F - Flying>>>> ---> ---> ---> ---> ---> ---> ---> ---> ---------------------------------------------------------------------->>>> Jim,>> Do you ( or anyone else) have a photo of the area about 6" under the> pictures you sent? I'm trying to figure out the best routing for the> fuel> line from the mechanical fuel pump to the Bendix servo to get it> away from> the exhaust.>> Thanks,>> Vern Smith (#324 finishing)> do not archive>> Date: Fri, 3 Apr 2009 21:35:28 -0400> Subject: Re: EGT Sensors installation and clocking>From: jim(at)CombsFive.Com> To: rv10-list(at)matronics.com>> Here is the left side of my installation. Picture xx35 is the front> / middle pipes, xx34 is the middle and rear cylinders. I used the> same clocking on the other side (leads go toward the prop).>> Jim> C> N312F - Flying (40192)>> Do Not Archive> -->> RV10-List message posted by: "AirMike"> <Mikeabel(at)Pacbell.net>>> I have the AFS3500 EGT kit. Any> suggestions or better yet pictures of the> final installed position of> the sensors?>> I was told to install 2" out from the flange> on the engine. I am worried> about the clocking so that the wire ends> do not interfere with the> cowling.>> Any suggestions,> comments and pictures appreciated>> --------> OSH '08 or Bust> (busted) be there in &quot;09> Q/B Kit - wiring and FWF>>>>> Read this topic online here:>> http://forums.matronics.com/viewtopic.php?p 37488#237488>>>>>>>>> _________________________________________________________________> Rediscover HotmailĀ®: Now available on your iPhone or BlackBerry> http://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_Mobile1_042009> <DCP_2330.JPG>> <DCP_2331.JPG> [quote][b]
