rawheels
Joined: 09 Jul 2008 Posts: 89 Location: Westfield, IN
Posted: Thu Apr 02, 2009 3:18 am Post subject: Oil injection conversion |
Is there a way to adjust/modify the oil injection system on a Rotax 582 so that it meters at 100:1 instead of 50:1 at cruise?
_________________ Kitfox IV-1200
Indianapolis, IN |
Roger Lee
Posted: Thu Apr 02, 2009 6:10 am Post subject: Re: Oil injection conversion |
Hi Ryan,
What would be your reason to change a very proven worldwide mix?
Thousands of people have played with the oil mixture over the years with the 582 with costly results. There are really good reasons for 50:1
I would stay with it and enjoy the longevity and reliability of the 582 at 50:1, plus you need to maintain this engine just as the manual says to achieve those results.
If you are thinking of using AmsOil at 100:1 then you will have excessive wear issues and maybe engine failures when things like weather or other variables change.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
dave
Posted: Thu Apr 02, 2009 6:43 am Post subject: Re: Oil injection conversion |
Ryan, I have to agree with Roger.
Rotax has spent millions on R & D - what make s you think you have a better idea?
Besides the oil injection when properly set up ( align the 2 marks on pump and lever) You will get 50 to 1 at Wide open. in cruise you likely will see approx 65 to 1 ratio.
Stick with API TC rated oil and my preferance is Mineral oil and after thousands of hours of two strokes alone I can tell you it works well.
MY last 582 was over 500 hours and not de-carboned at all. Still ran fine.
No need to re-create the wheel .
Kitfox movies here using Mineral oil in Rotax Engines.
http://rotaxaircraft.com/forum/viewforum.php?f=8
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
rawheels
Posted: Thu Apr 02, 2009 7:08 am Post subject: Re: Oil injection conversion |
I really don't want to get in a debate over the advantages/disadvantages between petroleum vs synthetic based oils. And yes, it is to run Amsoil. Does, anyone have an answer for the 100:1 question?
Indianapolis, IN |
dave
Posted: Thu Apr 02, 2009 7:27 am Post subject: Re: Oil injection conversion |
| rawheels wrote: | | I really don't want to get in a debate over the advantages/disadvantages between petroleum vs synthetic based oils. And yes, it is to run Amsoil. Does, anyone have an answer for the 100:1 question? |
Oddly enough Ryan you just got advice form two Rotax Techs.
I do like Amsoil , They help me sell new cranks.
So you win -- no debate.
Just the facts, Dave
rawheels
Posted: Thu Apr 02, 2009 8:05 am Post subject: Re: Oil injection conversion |
| dave wrote: | | Oddly enough Ryan you just got advice from two Rotax Techs. |
Thats great Dave. I really appreciate all the help you give us on this forum. A engine that is constantly used always seems to go farther past TBO than an occasionally used one. You could probably use vegetable oil with as much as you fly. You seem pretty invulnerable to everything.
I wasn't trying to imply that I didn't value your opinion on the oil. I've never heard of using mineral oil, but I've got two other Rotax techs that say the OEM recommended Pennzoil is crap. Who to believe? The one that will honor my overhaul warranty if I use Amsoil.
Indianapolis, IN |
dave
Posted: Thu Apr 02, 2009 8:23 am Post subject: Re: Oil injection conversion |
Ryan, you have never heard of mineral oil? Well it is likely the most popular oil for two strokes and after 35 years I have seen it all. Don;t get me wrong as synthetics in two strokes do seem to lubricate ok , but where they lack is on corrosion protection.
For the record I don;t use Pennzoil but I use mostly Bombardier XPS mineral oil . It is API tC rated and if you engine sits for a few weeks or a month you don;t have ot worry about corrosion. Now if you live in a dry climate then synthetics will fare you better. Around here, no chance you would get the same protection.
You really never heard of mineral oil? Are you a real newbie? Come on you are not serious ? We not talking castor oil here .
oh and if you are not in a dry climate you had better get used to using fogging oil in your engine or be prepared for a shortened engine life.
Dave
| rawheels wrote: | | dave wrote: | | Oddly enough Ryan you just got advice from two Rotax Techs. |
e OEM recommended Pennzoil is crap. Who to believe? The one that will honor my overhaul warranty if I use Amsoil. |
PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Thu Apr 02, 2009 8:53 am Post subject: Oil injection conversion |
What does Rotax recommend for the 912?
Sent: Thursday, April 2, 2009 12:23:28 PM
Subject: Re: Oil injection conversion
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com (dave(at)cfisher.com)>
Dave
rawheels wrote:
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://www.youtube.com/profile_videos?user=kitfoxflyer
http://forums.matronics.com/viewtopic.php?p=237390#23739r?Kitfox-List" target=_blank>http://www.matronics.com/Navigator?Kitfox-Lit;
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
rawheels
Posted: Thu Apr 02, 2009 10:21 am Post subject: Re: Oil injection conversion |
Newbie? Yes. Don't get me wrong; I've grown up my entire life on our family's airport, I am an A&P, multiple rated pilot, and have two aeronautics degrees from Purdue University. However, I only have about 2 years flying behind a snowmobile/pwc 2-stroke. The only thing I've used mineral oil for is breaking in a newly overhauled Continental.
There is one solid thing I do know about 2-strokes though, just about the entire internet content relating to them is a huge debate about what oil to use. Guess we can add this thread to the pile. I've seen synthetic, petroleum, blends and even vegetable/castor bean, but I must have glossed over the mineral oil discussion.
It does look like XP-S (synthetic and mineral) is generally liked by all, just really expensive.
Indianapolis, IN |
dave
Posted: Thu Apr 02, 2009 10:39 am Post subject: Re: Oil injection conversion |
XP-s is synthetic
XPS is mineral oil and retail about 5$ to 6 a quart in bulk
you can buy Castrol super two stroke at Walmart in Canada for 4.25 $ a quart
they are both APIC TC Rated ( read the label )
Shell advance Ski doo oil as well avail for about 17 to 25 $ a gallon,
About the internet -- yup there is allot of Armchair captains, I do agree.
I can tell you what works for me and me group of a dozen locals here that fly with out troubles.
I don;'t sell oil but the Amsoil sales guy does.
Dave
dave
Posted: Thu Apr 02, 2009 10:40 am Post subject: Re: Oil injection conversion |
Danielle Sassvile's site tell you the best
http://www.rotaxservice.com/rotax_tips/rotax_feed4.htm
[quote="PMorel"]What does Rotax recommend for the 912?
--> Kitfox-List message posted by: "dave" <dave>
Dave
rawheels wrote:
Thats great Dave. I really appreciate all the help you give us on this forum.� A engine that is constantly used always seems to go farther past TBO than an occasionally used one. You could probably use vegetable oil with as much as you fly. You seem pretty invulnerable to everything.
Paul A. Franz, P.E.
Posted: Thu Apr 02, 2009 11:52 am Post subject: Oil injection conversion |
On Thu, April 2, 2009 10:21 am, rawheels wrote:
| Quote: | The only thing I've used mineral oil for is breaking in a newly overhauled
Continental.
I think you don't realize "mineral oil" is standard refined oil. What you're thinking
is that for break-in you used straight mineral oil, non-detergent. Synthetic oil is
extracted from mineral oil.
The most important consideration for motor oils is ash content. The lower the better.
That applies to both oil mix in fuel and oil for crankcase uses.
Bean oil (primarily from castor beans) is the third broad type.
| Quote: | There is one solid thing I do know about 2-strokes though, just about the entire
Mineral oil is standard motor oil, all of it, except full synthetics and vegetable oil.
| Quote: | It does look like XP-S (synthetic and mineral) is generally liked by all, just really
expensive.
You pay a premium for close to zero ash content.
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
VILLAGE IDIOTS
Stop debating? But that's what science is: "The scientific community
has gone through this chapter and verse. We have long since passed
the time when we should pretend this is a 'on the one hand, on the
other hand' issue. It's not a matter of theory or conjecture, for
goodness sake."
-- Al Gore
Blame Rush: "President Obama's a good friend of mine, and I'd just
like to think about him and, you know, I know -- you know Rush
Limbaugh and a lot of jackasses give him a hard time right now. They
always trying to divide and conquer the country. They've already
ruined the country, and now he's trying to save the country, and I
want him to keep his head held high."
-- former NBA star Charles Barkley
Maybe she actually gets it: "If you are just fed up, at some point,
just lean out your window and scream, 'I'm mad as hell,' 'cause
that's what's happening to me. I'm losing my mind, because I don't
understand why -- like they -- one of the things that I saw
recently, they have this whole thing about taxing 'the wealthy.'
Okay. Now, I don't mind that. I don't mind paying a little more tax
'cause I make a good living. But I don't want to get it coming and
going. I don't want to get the federal raised and then the state
raised and then the phone tax raised and then the television tax
raised and then the city tax. Back off me!"
-- entertainer Whoopi Goldberg SHORT CUTS
"[M]any of us are hoping that all those in power fail, because those
in power have a grating habit of being annoyingly self-righteous,
hopelessly corrupt, resolutely incompetent and completely apathetic
about the freedoms that they have sworn to protect. Embrace the
failure. It's patriotic."
-- columnist David Harsanyi
"Obama brags -- albeit dishonestly -- that he's only raising taxes
on rich people. Ninety-five percent of the American people will get
a tax cut, the president insists. Well, which is it? Do the times
demand shared sacrifice from us all, or from just 5 percent of
Americans? If I say to 10 co-workers, 'We all need to chip in
together to get this done,' and then say, 'So, Todd, open your
wallet and give five bucks to everyone else in the room,' it would
sound ridiculous. But when Obama says the same thing to 300 million
Americans it's called 'leadership.'"
-- columnist Jonah Goldberg
"President Obama defended his plan for higher taxes on the rich. He
is determined to level out the distribution of wealth in America. It
wasn't historic enough for him to be our first black president, he
also wants to be our first red one."
--comedian Argus Hamilton
_________________ Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office |
occom
Posted: Thu Apr 02, 2009 12:23 pm Post subject: Oil injection conversion |
Long experience with two strokes has shown the best wisdom is to use the
ratio recommended by the engine manufacturer and NOT the oil distributor. I
watched a guy with an old and rare east European two stroke destroy his
motor using 50:1 where the original ratio was recommended at 20:1.
Float Flyr
Posted: Thu Apr 02, 2009 2:03 pm Post subject: Oil injection conversion |
I though the injector was variable. Giving around a 40:1 mix at idle and a
70:1 mix at cruise
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Thu Apr 02, 2009 2:44 pm Post subject: Oil injection conversion |
As Dave mentioned there is the calibration on the injector pump. I thought
as the rpm increased the mix ratio increased. 40:1 low Rpm to 70:1 high
rpm. My understanding is this occurred because the quantity of fuel through
the base is much higher at high rpm the injector slows down a bit to give a
consistent usage per hour. Dave says different and I must bow to his
superior practical knowledge on this one. Never the less I'm sure if you
really want to you can adjust the arm of the injector pump to give a higher
mix ratio. Even with the synthetic oil I'd be particularly careful about
messing around with mix ratios. Amsoil themselves specify a 50:1 injection
ratio. Rotax also asks for a 50:1 for premix. I expect you are bucking a
trend and possible walking a tight rope here.
Noel
Kitfox III-A
Float Flyr
Posted: Thu Apr 02, 2009 2:49 pm Post subject: Oil injection conversion |
XPS is made by the guys who made the engine .... 'nuff said.
What I learned in technical school is synthetic oils typically have lower
ash content and a lot more range of viscosity. Unfortunately some of them
are so slippery they will actually drip off parts completely leaving them
prone to corrosion. They are supposed to be great for people who use the
engines every day.
Noel
Kitfox III-A
Float Flyr
Posted: Thu Apr 02, 2009 3:01 pm Post subject: Oil injection conversion |
XPS is just about the cheapest two stroke oil we can get here... It's the
only one sold in bulk. In this neck of the woods if you want Amsoil bring
money!
As to a huge debate over engine oils... When it comes to two strokes I
think people feel closer to their oil than to their wives. They are
certainly a lot more protective and choosy about their oil!
Noel
Kitfox III-A
Guy Buchanan
Posted: Thu Apr 02, 2009 3:13 pm Post subject: Oil injection conversion |
At 05:27 PM 4/2/2009, you wrote:
| Quote: | I though the injector was variable. Giving around a 40:1 mix at idle and a
70:1 mix at cruise
Nah, it's the other way around. It gives 50:1 at high RPM and 70:1 at idle.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 300 hrs. and counting
_________________ Guy Buchanan
Deceased K-IV 1200
A glider pilot too. |
Guy Buchanan
Ryan,
A cheaper well liked alternative is Pennzoil 2-Cycle for Air
Cooled Engines. It's now sold only in dinky 8 oz. bottles but is
still cheapest here in SoCal, even after shipping. It's a lot cheaper
if you can buy it locally. And the performance has been proven at
least adequate over the years in test and in use.
Guy Buchanan
San Diego, CA
Deceased K-IV 1200
akflyer
Posted: Thu Apr 02, 2009 4:12 pm Post subject: Re: Oil injection conversion |
We have been running the citgo sea and snow oil for 15+ years in sleds and for the last 2 years in the 582. I normally go through ~ 40 gallons of oil a year in the sled and planes. We tore a 582 down after 250 hrs using this oil with no wear or carbon present. The oil sells for 12-14 bucks a gallon.
My sleds that use power valves normally have to have the power valves cleaned every 500 miles if you use the arctic cat power valve oil ( manufacture recommended). With the sea and snow, I have not had one issue or needed to clean power valves in thousands and thousands of miles. We have used them in snowmachines for over a hundred thousand miles with no engine issues. ( various sleds added up) and one sled I know of with 14,000 very hard miles.
citgo sea and snow.pdf |
24.51 KB |
534 Time(s) |
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
