flyboy3847(at)onecommail. Guest
Posted: Wed Apr 01, 2009 6:24 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
It has been my experience that you must plan carefully before you limit
access to anything on the airframe. I didn't install the firewall until I
had the rudder and brake cylinders in place along with all brake lines. As
for the panel, we made separate removable sub panels for the EIS, the flight
instruments as well as the radio and GPS. You can then remove them to get
behind the panel. I'm just about finished with a plans-built 601HD.
Remember, the upper glare shield that rivets to the top of the firewall is
structural. Be careful if you're planning on skimping on rivets.
Flyboy3847(at)onecommail.com
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Wed Apr 01, 2009 6:47 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
(Please trim your quotes, people. There's no reason to include the entire
digest in a reply.)
On Wed, Apr 01, 2009 at 10:24:22AM -0400, Leroy Wheeler wrote:
| Quote: | Remember, the upper glare shield that rivets to the top of the firewall is
If you're referring to the metal cover that goes across the top of the panel
and down to the fuselage longerons, from the firewall back, that piece
(6C1-4 on my parts catalog drawing) is held on my XL by lots of screws. This
makes working on stuff in the panel a lot easier. Is the structural nature
of it an HD-specific thing?
Jay Maynard, K5ZC, PP-ASEL, AGI http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Posted: Thu Apr 02, 2009 7:02 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
I think the fuselage is the same for both models of the 601. If the factory
put the screws in the kit I must assume it's right. I also think that
rivets are stronger than screws. The panel is structural. It keeps the
upper longerons parallel. The upper longerons are directly connected to the
motor mounts.
jfowler120(at)verizon.net Guest
Posted: Thu Apr 02, 2009 7:19 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
I agree. Rivets are permanent, screws are not.
Karl Polifka
leo.gates
Posted: Thu Apr 02, 2009 7:33 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
601HD/HDS - In 2003 Chris approved my use of Rivnuts and #6 SS screws in
place of rivets for the front panel on my HDS. Basically the same at
the front end as the XL.
Leo Gates
N601Z - CH601HDS TDO
Rotax 912UL
motor mounts.
Jeyoung65(at)aol.com Guest
Posted: Thu Apr 02, 2009 7:38 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
Rivets are NOT STRONGER than screws unless you are talking about sheet metal
screws in tension then they MAY be. Rivets are permanent only until you get
the drive out. The problem with removing rivets is you enlarge the holes each
time and soon you will need the next size rivets- reducing the edge
distance.
Jerry of GA DO NOT ARCHIVE
In a message dated 4/2/2009 10:19:55 A.M. Eastern Standard Time,
jfowler120(at)verizon.net writes:
Karl Polifka
z601(at)anemicaardvark.co Guest
Posted: Thu Apr 02, 2009 8:21 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
On Thursday 02 April 2009 10:37, Jeyoung65(at)aol.com wrote:
| Quote: | Rivets are NOT STRONGER than screws unless you are talking about sheet
metal screws in tension then they MAY be. Rivets are permanent only until
you get the drive out. The problem with removing rivets is you enlarge the
holes each time and soon you will need the next size rivets- reducing the
edge distance.
I agree with Jerry in a general sense. But it depends on the screw and the rivet. Sheet metal screws are, generally, not stronger than rivets of the same size.,
My copies of AC 43-13 are burried at the moment, but I believe there are tables in one of the two books which show the size of machine screw that can replace a rivet in an aircraft. I've done this on certificated aircraft, and sold it to the FAA without a whimper.
Assuming I remember correctly, Zenith states that it takes five of their rivets to replace three driven rivets of the same diameter. It should be possible to take this information, and determine the size, number, and type of machine screws that could replace the rivets to have the same or better strength.
Note that this applies only to aircraft quality screws, which have known structural properties, not to hardware store screws.
I plan to replace some of the rivets inside the cockpit of my 601XL with screws, so I can remove panels for maintenance.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
============================================= [quote][b]
Posted: Thu Apr 02, 2009 11:13 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
Okay, since I have been so expertly corrected -- why not use nothing but sheet metal screws and screw the rivets. Pun intended.
Karl Polifka
Posted: Thu Apr 02, 2009 11:26 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
I still want to use rivets. If you plan you don’t need to use them.
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of KARL POLIFKA
Sent: Thursday, April 02, 2009 3:13 PM
Subject: Re: RE: Zenith601-List Digest: 8 Msgs - 03/31/09
Karl Polifka
Posted: Thu Apr 02, 2009 11:33 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
On Thursday 02 April 2009 14:12, KARL POLIFKA wrote:
| Quote: | Okay, since I have been so expertly corrected -- why not use nothing but
1) Because sheet metal screws aren't the ones with the same or greater
strength. Machine screws do that.
2) It's very possible that the machine screws (or sheet metal screws, for that
matter) wind up weighing more than the rivet they would replace. That might
not matter much on a few screws, but on a plane full, it matters a lot.
It seems to me that the BD-4 used mostly machine screws and bolts instead of
rivets. But I could be mistaken about that; it's just what I remember.
I don't know that you were "expertly corrected;" we just found a place where
I'd happened to walk down a path you hadn't. I had an instance - maybe ten
years ago - where it wasn't practical to use rivets. I forget why now - I
just remember it wasn't.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Do not archive.
Jim B Belcher
A&P/IA
Posted: Thu Apr 02, 2009 11:55 am Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
Sheet metal screws will pull through the alum. sheets if over torqued and
will vibrate loose. Machine screws, sheet metal screws and bolts cost more than
rivets. DO NOT ARCHIVE Jerry of GA
In a message dated 4/2/2009 2:34:18 P.M. Eastern Standard Time,
z601(at)anemicaardvark.com writes:
bryanmmartin
Posted: Thu Apr 02, 2009 12:12 pm Post subject: Zenith601-List Digest: 8 Msgs - 03/31/09 |
I wouldn't use sheet metal screws anywhere in an airplane (or any
other vehicle for that matter) except maybe on some non-essential item
that is in plain sight and easily inspectable. Sheet metal screws tend
to loosen up whenever they are subjected to the slightest vibration.
Machine screws are much more likely to stay tight in the long term and
rivets even more so. Rivets also have the advantage of being lighter
than a screw of equivalent strength.
Karl Polifka
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
