dstroud(at)xplornet.com Guest
Posted: Tue Mar 31, 2009 1:39 pm Post subject: Eddie's Moose |
Giday, Eddie. Did you install a fuel debubbler device on your Moose ? If so,
could you please say what type and the source of it ? Thanks....
David Stroud Ottawa, Canada
Christavia C-FDWS
Fairchild 51 replica
under construction C-FYXV
[quote] [b]
eddiemoranii(at)yahoo.com Guest
Posted: Wed Apr 01, 2009 2:07 am Post subject: Eddie's Moose |
David, no I did not.
Eddie
--- On Tue, 3/31/09, DAVID STROUD <dstroud(at)xplornet.com> wrote:
Subject: Eddie's Moose
To: m14pengines-list(at)matronics.com
Date: Tuesday, March 31, 2009, 5:39 PM
Christavia C-FDWS
st" target=_blank rel=nofollow>http://www.matronics.com/Navigator?M14PEngines-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Wed Apr 01, 2009 5:04 pm Post subject: Eddie's Moose |
I'm helping to build a Moose with the M14. I just have to ask..... what is a fuel debubbler and what is it used for.
Ted
On 31-Mar-09, at 2:39 PM, DAVID STROUD wrote:
| Quote: | Giday, Eddie. Did you install a fuel debubbler device on your Moose ? If so,
Christavia C-FDWS
| Quote: | http://www.matronics.com/Navigator?M14PEngines-List
French_Edwin_L_(Ted).vcf |
502 Bytes |
816 Time(s) |
_________________ Ted French
RV-10 fuselage |
Posted: Thu Apr 02, 2009 11:10 am Post subject: Eddie's Moose |
Giday, Ted. The Yak has a de-bubbler on the firewall. It is a small sphereical item which takes any air out of the fuel system
before it heads off to the filter and carb. I am building a Fairchild 51 replica using the Huosai engine from a Nanchang and
look to the Yak list for any info I can get along the way. The Moose builders are usually ahead of me so I was wondering
if any were using one. It may not be necessary on a plane that will not fly inverted and that's a position I will not get into
on purpose anyway. More knowledgable members could confirm it's benefits on a non stock application like ours.
Christavia C-FDWS
Ted French
Posted: Thu Apr 02, 2009 5:43 pm Post subject: Eddie's Moose |
Thanks guys.
Ted
502 Bytes |
836 Time(s) |
RV-10 fuselage |
