Douglas Fly-In slideshow/video
cristalclear13
PostPosted: Tue Mar 10, 2009 4:47 am    Post subject: Douglas Fly-In slideshow/video Reply with quote
Here's the link:
http://www.youtube.com/watch?v=Ooo85LaMbuE
Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009
jbhart(at)onlyinternet.ne
PostPosted: Tue Mar 10, 2009 7:49 am    Post subject: Douglas Fly-In slideshow/video Reply with quote
At 05:47 AM 3/10/09 -0700, you wrote:
Here's the link:
Cristal,
Good Video. I am curious. Where you carrying a passenger on your flight
and were the photos taken while you were in level flight? From the photos
it looked like quite a bit of down elevator in two of them. Why?
Jack B. hart FF004
Winchester, IN
cristalclear13
PostPosted: Tue Mar 10, 2009 7:58 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Here's the link:
Cristal,
Jack B. hart FF004
Winchester, IN
Thanks Jack,
I don't see it. Maybe it's the angle of the shot. They were either above or below me taking the pictures.
I was flying solo.
Cristal Waters
cristalclear13
PostPosted: Tue Mar 10, 2009 8:00 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Here's the link:
Cristal,
Jack B. hart FF004
Winchester, IN
Oh yeah, and we had just taken off and was still climbing, but I don't see a whole lot of up elevator in the pictures.
Cristal Waters
cristalclear13
PostPosted: Tue Mar 10, 2009 8:04 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Meant to say down elevator there. Looks like normal down elevator to me since we were still climbing.
Are you trying to make a wise crack about my weight? Sad
Cristal Waters
JetPilot
PostPosted: Tue Mar 10, 2009 8:43 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Nice video and beautiful music to go along with it Crystal ! Looks like you guys had a great time. I wish I could have gone !
I see what Jack is talking about on the elevator, but being down elevator in cruise could possibly indicate a tail heavy condition, but it could be other things also. I don't know if the TwinStar has the adjustable horizontal stab as my MK III Does. It looks to me like most of the load of the tail is being carried by the Horizontal Stab and the elevator may even working against it a bit with so much down in cruise. I don't know much of anything about the Twinstar, if this is normal or not, I just know its far different from what I see in my MK III Xtra in cruise ! Maybe John H could take a look at the pictures... I bet he has seen stuff like this in Kolbs a couple hundred times before.
Kolb MK-III Xtra, 912-S
PostPosted: Tue Mar 10, 2009 8:55 am    Post subject: Douglas Fly-In slideshow/video Reply with quote
Cristal,
Now that you made the statement, you must be sensitive. Nothing is more
unattractive than someone who is anorexic. Your fairings look great and I
would say you are in the bloom of health. Let the Kolb worry about your
weight and go fly.
Jack B. Hart FF004
Winchester, IN
cristalclear13
PostPosted: Tue Mar 10, 2009 8:59 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Ok, I see what you're saying. I was thinking backwards (which I tend to do after a long tiring weekend).
I don't know the answer. I might have been going down a little at some time to let the gyrocopter catch up to me. But more than likely I didn't have my trim set. That might cause it, right?
Cristal Waters
cristalclear13
PostPosted: Tue Mar 10, 2009 11:14 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Cristal,
weight and go fly.
Jack B. Hart FF004
Winchester, IN
Thanks Jack, How nice you are. In an attempt to be funny or head off kidding (which I tend to be on the receiving end alot) I'll cut myself down. But it's hard to tell joking on forums since less than 10% of understanding comes from words (and emoticons aren't too much help). The rest comes from diction, inflection, facial expressions, body language, etc.
Back to your original concern...My weight and balance shows me safely within the CG range. My big trim tab affects my up and down elevator quite a bit so maybe that had something to do with it. I hadn't adjusted my trim when I was flying there because I was trying to get a feel for how quickly the gyrocopter was climbing/following. Maybe I'll ask the gyrocopter to fly with me some more and I can experiment with my trim tab and see if that makes a difference.
Thanks.
Cristal Waters
JetPilot
PostPosted: Tue Mar 10, 2009 11:25 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
A trim tab is used to position the elevator, it does not make much difference if you hold the stick by force, or if the trim tab does it for you, that just looks like bunch of down elevator in several of the shots ( it looks more constant, not just a momentary movement ). I don't see this as being related to the position of your trim tab at all.
Kolbs are very different than other types of planes in many respects, which is why I would wonder what John Hauck would think about this. I would hate to get you all worried about this and then have John H come and say that half the Kolbs he flown fly with the elevator in that position ! But whenever you see something that looks different, its better to ask someone that knows then to just ignore it Smile
PostPosted: Tue Mar 10, 2009 12:48 pm    Post subject: Douglas Fly-In slideshow/video Reply with quote
Mike,
The reason I asked is that the air craft looked out of trim. If it was in
level flight and trimmed out, I thought the horizontal stabilizer and
elevator would have been in line with each other. If anything I would have
expected the elevator to have been displaced upward to maintain a heavier
load or climb. If down elevator is required for level flight with two
people aboard, it might be good to adjust the horizontal stabilizer.
A nephew took some photos during a July 4th 2007 fly over of the FireFly
while in level flight. I have an elevator position indicator but I have
never been able to verify that it was indicating properly. Both of these
can be seen at:
http://www.thirdshift.com/jack/firefly/firefly137.html
http://www.thirdshift.com/jack/firefly/firefly102.html
FWIW
Jack B. Hart FF004
Winchester, IN
grantr
PostPosted: Wed Mar 11, 2009 4:46 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Crystal,
How does your airplane behave in a stall? Does it drop the nose and resume flying or do you have to give it a bit of forward stick to break the stall? Does your stick ever get lite and want to falls back in you lap?
http://www.youtube.com/watch?v=-pudkDMJWcs&feature=channel_page&fmt=18
In the video at around 7:35 I do some stalls. You can see the nose drops off fairly sharp and the plane resumes flying. It doesn't take the forward stick to do this. If the plane is tail heavy it may tend to want to stay stalled requiring a bit of forward stick to break the stall. In a stall a tail heavy plane will sometimes drop the tail which will cause the stick to go back in your lap as the airflow pushes the elevator up. Good thing with our airplanes is that adding power can save you since it pushes the nose down. A Cessna would be different since adding power pulls the nose up.
cristalclear13
PostPosted: Wed Mar 11, 2009 5:15 am    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
grantr wrote:
Crystal,
Grant,
I don't remember to that detail...I just always stick forward in a stall - automatic reaction. Maybe after I replace my exhaust gaskets I'll go out and play around with it and let you know.
I do know that on a power-on stall with a totally full load I felt some buffeting before an oncoming stall. I was flying with my Dad and noticed we weren't getting much climb so I pulled back just a little more and a few moments later it felt like I hit some turbulence but it was a still day. Realized not much later it was the buffeting before a stall...luckily my automatic reaction to turbulence is also to put my nose down. If I fly with that much weight anymore I just plan on having a stinky climb rate, but mostly I just avoid having that much weight.
Cristal Waters
JetPilot
PostPosted: Sat Apr 04, 2009 3:33 pm    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Where have you been Crystal ? I havent seen a post from you for several weeks. Have you been flying ? I have not flow my Kolb in well over a month, every day I am in Miami, its very windy Sad Today and tomorrow look perfect, and I am up north flying airplanes that aren't as much fun as my Kolb...
I ran across this picture of a MK III like yours in flight, the elevator seems to be very close to she same position as yours, so its probably normal. The big wedge of the MK III Xtra tends to push the nose down a lot, so the elevator is a lot more up during flight.
The elevator looks to be in the same position in flight as Crystals.
 Filesize:  64.39 KB
 Viewed:  14272 Time(s)
cristalclear13
PostPosted: Sun Apr 05, 2009 6:29 pm    Post subject: Re: Douglas Fly-In slideshow/video Reply with quote
Thanks Mike. John Hauck said he had one that flew like that.
I just got back from taking the Rotax 2 stroke maintenance class at South Mississippi Light Aircraft. I learned a lot and really enjoyed it. Ronnie Smith is a great instructor. He checks to make sure you understand before he moves on.
All the storms made for an "interesting" drive to MS and back. On the way home I was wondering if I was going to make it home since several roads I tried to get home on were closed due to rivers flooding over the roads. I finally found a road that would get me home. The sheriff was parked on that bridge watching and waiting as the river was creeping up so close to it also. It gave a whole new meaning to the saying I've heard...Lord willing and the creek don't rise.
When I got to Ronnie Smith's in MS I camped out by Ronnie's hanger and it was a gorgeous sunset every evening. I've attached a couple pictures here (taken with my cell).
On the way to MS I stopped by and saw Jim and John Hauck's camping hideaway...it's in the sticks. That's why you haven't heard from them either. No internet out there, barely any cell phone coverage. Jim is going to help me with my muffler. Thanks Jim! Smile
Before that I was working like a dog trying to get ahead on my work so I could take some time off from work for the class and spring break.
 Filesize:  23.22 KB
 Viewed:  14239 Time(s)
 Filesize:  11.68 KB
Cristal Waters
