timing advance
dale1rv6(at)comcast.net
PostPosted: Mon Mar 30, 2009 7:14 pm    Post subject: timing advance Reply with quote
I have to protest the allegation that conditions in the combustion chamber would cause early failure of a magneto. BTW, Before installing my 2nd (dual) electronic ignition I put 900 hours on a slick mag (while running the Electroair), working perfect at the time of removal. Proper use of the Electroair or Lightspeed systems reduces CHTs and increases horsepower. There are many well educated pilots on this forum. Your system may be good, but please stick to the facts.
Dale
RV6a
0-360 Electroair / Lightspeed, dual electric sys
 Filesize:  2.67 KB
 Viewed:  2644 Time(s)
G3i Ignition
PostPosted: Tue Mar 31, 2009 4:07 am    Post subject: timing advance Reply with quote
Hello Dale,
Thank for the reply, this is a great topic and has been going around the lunchroom many times and at my chapter meetings as well as others.
Definitely do not want to step on any toes or slam other ignition systems. This is just experience and information that I and others have gathered over the years. The mags that I have inspected that were 1/2 and 1/2 that had failed, the failure was in the distributor block with severe carbon tracking, resulting in miss-fire. However, I've have seen that in the typical normal 2 mag set-up as well. The cylinder pressure does increase when there is a earlier firing event before the mag firing. However, this is NOT going to guarantee of an early magneto failure though. The mag just has to work harder to ionize the spark that’s all. Now if there was already an existing problem. It would definitely increase the chance of earlier failure of that mag/component.
Sincerely,
Thomas S.
----- Original Message -----
[quote] Sent: Monday, March 30, 2009 9:11 PM
Subject: ***SPAM***Re: Re: timing advance
Dale
RV6a
 Filesize:  2.67 KB
 Viewed:  2643 Time(s)
Thomas S.
www.G3ignition.com
Follow G3i on Facebook.
www.facebook.com/pages/G3i-Ignition/243104229291
PostPosted: Tue Mar 31, 2009 2:41 pm    Post subject: timing advance Reply with quote
Hi Thomas,
And thank you for further info. Compliments to you for taking my opinion in a positive way. Will be watching to learn more.
Best of luck,
Dale
