rv10rob(at)gmail.com Guest
Posted: Mon Mar 30, 2009 8:31 am Post subject: Baggage door lock |
Anyone know of a specific model lock that will work with the baggage door on the RV-10? I bought one at Home Depot yesterday, but it has a different style latch (thinner and smaller "hole" than the Van's F-1062 latch that ships with the kit). Before I attempt to make the Home Depot lock/latch work, I wanted to see if anyone is aware of a lock that will just work with the latch in the kit. Note I'm not using the ignition switch, so it didn't make sense to buy that set from Van's.
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Woodinville, WA (near Seattle)
http://kochman.net/N819K
LarryRosen
Posted: Mon Mar 30, 2009 9:06 am Post subject: Baggage door lock |
They are Aircraft Spruce locks.
ACS p/n 11-01600
They are shold in sets of 2 for $26.60
<http://www.aircraftspruce.com/catalog/elpages/igswitches.php>
towards the bottom of the page.
Larry Rosen
Rob Kochman wrote:
| Quote: | Anyone know of a specific model lock that will work with the baggage
from Van's.
Thanks...
-Rob
Rob Kochman
RV-10 Wings
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
planesmith(at)hotmail.com Guest
n277dl
pascal(at)rv10builder.net Guest
Posted: Mon Mar 30, 2009 9:37 am Post subject: Baggage door lock |
http://wcurtis.nerv10.com/08fuselage/fuselage34a.html
These work.
Pascal
Sent: Monday, March 30, 2009 8:27 AM
Subject: Baggage door lock
Thanks...
-Rob
Rob Kochman
RV-10 Wings
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Mon Mar 30, 2009 9:38 am Post subject: Baggage door lock |
That’s odd as I got my locks from HD also and had no problem putting it in the baggage door. If you watch for them, you can usually find 3 keyed alike for the baggage and main doors.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rob Kochman
Sent: Monday, March 30, 2009 12:27 PM
Thanks...
-Rob
Rob Kochman
RV-10 Wings
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 0123456789
Posted: Mon Mar 30, 2009 10:51 am Post subject: Baggage door lock |
find the lock number and get another key made based on the code- if it's a
AS purchased call them they can get you the key, if it's Home depot, go
there and buy another lock with the same number.
No time to be looking for keys when there is other stuff, like tools, to
find and building the plane.
Are you sure your wife didn't take it?? maybe a bargaining chip for future
use?? hmm
good luck with that key either way.
Sent: Monday, March 30, 2009 9:25 AM
Subject: Re: Baggage door lock
Speaking of baggage door locks....
anyone remember where I put the key to mine? My wife swears I
didn't give it to her. I know it's put up somewhere just can't remember
where.
DO NOT ARCHIVE
Doug
"Fools" are always more creative than process people and will
always find ways to ruin a perfectly good set of processes.
http://forums.matronics.com/viewtopic.php?p 36881#236881
ron.mcgann(at)baesystems. Guest
Posted: Mon Mar 30, 2009 2:06 pm Post subject: Baggage door lock |
I used the 2 keyed alike Spruce locks on the baggage door and pilot’s door. That left the copilot side door to lock. I did not really want another lock on the RHS, so built an internal ‘lock’ for the RHS door. A piece of angle with a nut/bolt that prevents retracting the rack. Took 5 minutes to make, is very secure, is easy to insert/remove and there is no way you can open the door from the outside (or inside for that matter).
Ron
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of RV Builder (Michael Sausen)
Sent: Tuesday, 31 March 2009 4:04 AM
Subject: RE: Baggage door lock
Michael
Thanks...
-Rob
Rob Kochman
RV-10 Wings
| Quote: | | [b]http://www.matronics.com/Navigator?RV10-List[b][b]http://forums.matronics.com[b]http://www.matronics.com/contribution |
| Quote: | "Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
93.06 KB |
10135 Time(s) |
carl.froehlich(at)cox.net Guest
Posted: Mon Mar 30, 2009 3:41 pm Post subject: Baggage door lock |
I’ll use a tubular key cam lock. I have one on the baggage door of my 8A as I was concerned that a flat key could break off in the lock more easily than a tubular key.
For the 10, recommend the MFW-1058 from Fort Lock. Here is a link: http://www.securitybase.com/Web_store/ws400CS.cgi?category=Cam+Locks&no_search=Y
Carl Froehlich
RV-8A (450 hrs)
RV-10 (fuselage)
Thanks...
-Rob
Rob Kochman
RV-10 Wings
Posted: Mon Mar 30, 2009 4:14 pm Post subject: Baggage door lock |
Thanks, all, for the advice. Sounds like I'll be placing an order with ACS in the near future.
-Rob
On Mon, Mar 30, 2009 at 9:27 AM, Rob Kochman <rv10rob(at)gmail.com (rv10rob(at)gmail.com)> wrote:
| Quote: | Anyone know of a specific model lock that will work with the baggage door on the RV-10? I bought one at Home Depot yesterday, but it has a different style latch (thinner and smaller "hole" than the Van's F-1062 latch that ships with the kit). Before I attempt to make the Home Depot lock/latch work, I wanted to see if anyone is aware of a lock that will just work with the latch in the kit. Note I'm not using the ignition switch, so it didn't make sense to buy that set from Van's.
Thanks...
-Rob
Rob Kochman
RV-10 Wings
get="_blank">http://www.matronics.com/Navigator?RV10-List
Rob Kochman
RV-10 Wings
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Tue Mar 31, 2009 12:36 pm Post subject: Re: Baggage door lock |
I used the door locks from Steve Dinieri's iflyRV10.com. I just had him send me a third lock keyed the same as the cabin doors. Worked very nicely. Sorry, I don't have a photo. Seems like I took fewer and fewer photo's as I got near finishing!
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
