roxianmike(at)msn.com Guest
Posted: Sun Mar 29, 2009 1:11 pm Post subject: Removing Weldon |
Made the mistake today of getting weldon on the plexi as glueing in the rear windows. I searched the archive without luck. Any ideas how to remove without affecting the plexi?
Mike Lefever
finishing up cabin top while waiting on finish kit to ship
AV8ORJWC
Posted: Sun Mar 29, 2009 2:36 pm Post subject: Removing Weldon |
Micro-mesh.
John Cox
From: owner-rv10-list-server(at)matronics.com on behalf of Roxanne and Mike Lefever
Sent: Sun 3/29/2009 2:10 PM
Subject: Removing Weldon
Mike Lefever
tomhanaway
Posted: Sun Mar 29, 2009 5:10 pm Post subject: Re: Removing Weldon |
I had some run off of weldon on the inside of the plexi on the first window I installed. I tried several different polishing systems to get it off but really wasn't happy with the result in such a high visibility area. The glass still had a haze to it. I finally bit the bullet and ordered a replacement plexiglas window.
5 months down the road on the build and I'm really glad I did a complete replacement. No second guessing if it could have been done better. And I knew how not to do the window.
Hint-be very careful that the masking tape is tightly sealed so you don't get any weldon seeping under it. I found the 3m auto detailing tape from an auto body shop much better than any of the painting masking tapes from Home Depot or equivalent.
Tom H.
Boynton Beach, FL
Posted: Mon Mar 30, 2009 9:10 am Post subject: Removing Weldon |
I used acetone and a lot of rubbing...... Worked for me
On Mar 29, 2009, at 9:10 PM, "tomhanaway" <tomhanaway(at)comcast.net>
wrote:
Tom H.
Boynton Beach, FL
http://forums.matronics.com/viewtopic.php?p 36759#236759
