larryhorne
Posted: Wed Mar 25, 2009 8:47 am Post subject: FS Two MATCO Wheel Assemblies |
For Sale $300 OBO plus Shipping
Two (2) USED MATCO mfg MH SERIES Wheels and Brake Assemblies (rim, disc, caliper and tires) with tubes and tires.
Very Good Condition. One pad has a chipped corner and should be replaced. Pads are available from MATCO.
Model No. MH6B (labels read: MH6B.62D 11/01 and MH6BD.62 9/01)
Wt: 5.16 lbs
Static Rating: 660 lbs
Calipers: PH3 (SLC, UT) Single Caliper, Dual Piston
Tires and Tubes: TITAN Turf Glide, Tube Type, 8.00-6
Retail for $280 each new (minus tires and tubes)
Also included are Four (4) KYK Bearings (new) P/N 4MSC1630DCTN, Ball 0.75 (1630-2RS) which changes them from 0.625 inch to 0.75 inch.
Bought from another kit builder. Even though the labels read differently, MATCO has confirmed they are identical rims and discs. The difference in models refers to how they come matted with calipers. MATCO has technical specs for these on their web site.
Larry Horne
111 Springfield Terrace
Suffolk, VA 23434
(757) 880-1883
larry.e.horne(at)ngc.com
| Description: |
| Filesize: |
758.22 KB |
| Viewed: |
2627 Time(s) |
| Description: |
| Filesize: |
162.38 KB |
| Viewed: |
2627 Time(s) |
_________________ Lar |
