dwilde(at)clearwire.net Guest
Posted: Wed Mar 25, 2009 4:20 pm Post subject: Rubber Spacers on main gear |
This afternoon I started taxiing and heard a metal to metal grinding.
On investigation, I found the upper rubber spacer for the main gear on
the right side was missing and the lower one in bad shape. My plane
only has a little over 50 hours. The left side spacers look to be ok
for now. I guess the upper spacer must have departed after my last
landing because I don't remember hearing that noise before.
Is this a common issue or did I not install and/or tighten the spacers
correctly the first time?
Dan Wilde
N948DW
arno7452(at)bellsouth.net Guest
Posted: Wed Mar 25, 2009 4:32 pm Post subject: Rubber Spacers on main gear |
Dan,
I think this is weakness on CH701. I finally cut tread from auto tire to
fit. All four pads seem to be surviving great. Cutting the steel belts on
the tire is a little difficult but can be done.
The little sponge like pads from Zenith last about 5 landings.
Ken Arnold
CH701 N701LK 912ULS
NYTerminat(at)aol.com Guest
Posted: Wed Mar 25, 2009 5:06 pm Post subject: Rubber Spacers on main gear |
Dan,
Yes this is common, did mine 3x until I finally got smart and cut up a truck tire and used the tread portion. has worked great since.
Bob Spudis
N701ZX 172 hrs
In a message dated 3/25/2009 8:21:12 P.M. Eastern Daylight Time, dwilde(at)clearwire.net writes:
| Quote: | --> Zenith701801-List message posted by: Dan Wilde <dwilde(at)clearwire.net>
Dan Wilde
Great Deals on Dell 15" Laptops - Starting at $479
bobkat
Joined: 07 Sep 2008 Posts: 143 Location: Bismarck, ND
Posted: Wed Mar 25, 2009 6:04 pm Post subject: Rubber Spacers on main gear |
My original rubber Zenith pads lasted about 3 landings! I went down to the local Macs Hardware surplus place and got some thick belting. Works great now!
ggower_99(at)yahoo.com Guest
Posted: Wed Mar 25, 2009 6:17 pm Post subject: Rubber Spacers on main gear |
Happened the same to our 701 here, cut one from a old Cessna tire (avoid using car tires, is an airplane and cut the rubber part(s) to use from the sides of the tire... Lasted nearly 200 hrs.... Plane has 236 hrs and just looks like the piece of tire needs replacement. Probably this next Saturday... Not a dificult thing to do. Once you get the correct size, cut some extras to save for next 200 hrs "preventive mantainance" or maybe a few more hrs...
Saludos
Gary Gower.
Flying from Chapala
701 912S 236 hrs.
--- On Wed, 3/25/09, NYTerminat(at)aol.com <NYTerminat(at)aol.com> wrote:
| Quote: | From: NYTerminat(at)aol.com <NYTerminat(at)aol.com>
Subject: Re: Rubber Spacers on main gear
Date: Wednesday, March 25, 2009, 9:06 PM
Dan,
Bob Spudis
N701ZX 172 hrs
Dan Wilde
l?redir=http:%2F%2Fad.doubleclick.net%2Fclk%3B213153654%3B34689672%3Bo" target=_blank rel=nofollow>Great Deals on Dell 15" Laptops - Starting at $479 | Quote: |
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?Zenith701801-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
kenryan(at)alaska.net Guest
Posted: Wed Mar 25, 2009 7:19 pm Post subject: Rubber Spacers on main gear |
So, the obvious question is ...
Have they corrected the problem? Are they now using different material?
On Wed, Mar 25, 2009 at 6:02 PM, BokKat <bobkat(at)btinet.net (bobkat(at)btinet.net)> wrote:
[quote] My original rubber Zenith pads lasted about 3 landings! I went down to the local Macs Hardware surplus place and got some thick belting. Works great now!
Posted: Wed Mar 25, 2009 7:47 pm Post subject: Rubber Spacers on main gear |
On the 601XL they use a piece of radiator hose cut in half.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of BokKat
Sent: Wednesday, March 25, 2009 8:02 PM
JohnDRead(at)aol.com Guest
Posted: Wed Mar 25, 2009 8:59 pm Post subject: Rubber Spacers on main gear |
The answer to your question that Zenith has switched to a urethane material for the pad They cost $6.50 each plus shipping.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 3/25/2009 9:20:26 P.M. Mountain Daylight Time, kenryan(at)alaska.net writes:
| Quote: | So, the obvious question is ...
| Quote: | My original rubber Zenith pads lasted about 3 landings! I went down to the local Macs Hardware surplus place and got some thick belting. Works great now!
| Quote: | ----- Original Message -----
From: NYTerminat(at)aol.com (NYTerminat(at)aol.com)
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Sent: Wednesday, March 25, 2009 8:06 PM
Dan,
Bob Spudis
N701ZX 172 hrs
In a message dated 3/25/2009 8:21:12 P.M. Eastern Daylight Time, dwilde(at)clearwire.net (dwilde(at)clearwire.net) writes:
| Quote: | --> Zenith701801-List message posted by: Dan Wilde <dwilde(at)clearwire.net (dwilde(at)clearwire.net)>
Dan Wilde
st href="http://www.matronics.com/Navigator?Zenith701801-List">http://www.matronics.com/Navigator?Zenith701801-List
.matronics.com/">http://forums.matronics.com
://www.matronics.com/contribution">http://www.matronics.com/contribution
Feeling the pinch at the grocery store? Make dinner for $10 or less.
Curt.Thompson(at)verizon. Guest
Posted: Wed Mar 25, 2009 9:07 pm Post subject: Rubber Spacers on main gear |
I was at my father place a few months ago and out of the blue I asked if he
had any pieces of conveyer belt. He walked to the corner of his shop and
handed me a slab of it. I got a chuckle. Dad's a packrat for everything.
A few months ago in the DVD that came with the Zenith newsletter had someone
doing a pre-flight on a CH701 (I think it was Gus). That CH701 had some
kind of pink material on the main gear. Anyone know what that is?
Curt
Posted: Thu Mar 26, 2009 2:06 am Post subject: Rubber Spacers on main gear |
A piece of hose was supplied with the 701 and it just does not hold up.
Bob Spudis
In a message dated 3/25/2009 11:47:57 P.M. Eastern Daylight Time, craig(at)craigandjean.com writes:
-- Craig
Subject: Re: Zenith701801-List: Rubber Spacers on main gear
bobkat
Posted: Thu Mar 26, 2009 4:13 am Post subject: Rubber Spacers on main gear |
I used the hose they sent, but replaced it right away (a couple hours flying) for heavy thick belting of some kind. About 1/4 to 3/8 in thick!
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Mar 26, 2009 4:35 am Post subject: Re: Rubber Spacers on main gear |
I think Zenith also changed the culprit that caused the premature failure of the rubber pad.
I peeked in the parts bin when I was up there in September and it looked to me like that part has been changed. There was a ridge along the bottom side that just cut through the rubber bumper, causing it to fail early. I think they have a new design now.
I also received the rubber hose with my two kits. We finally fixed it by using a six-ply truck tire sidewall.
Tommy Walker in Alabama
O[quote="JohnDRead(at)aol.com"]The answer to your question that Zenith has switched to a urethane material for the pad They cost $6.50 each plus shipping.
John Read
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
[quote]So, the obvious question is ...
_________________ Tommy Walker
N25A - Anniston, AL |
randy(at)rjhebertassoc.co Guest
Posted: Thu Mar 26, 2009 6:04 am Post subject: Rubber Spacers on main gear |
Mine are in place for temporary fit.
These were hard to drill out the openings for the studs.
617.01 KB |
8208 Time(s) |
lgold(at)quantum-associat Guest
Posted: Thu Mar 26, 2009 10:47 am Post subject: Rubber Spacers on main gear |
I have about 50-hours and many rough field landings on the new Zenith
Urethane pads... They don't show any wear on them and seem to be working
fine.
Les
Tommy Walker
Posted: Thu Mar 26, 2009 10:59 am Post subject: Re: Rubber Spacers on main gear |
Gary,
I enjoy the humor in your posts to this list. Plus, you have good advice to pass along to those of us who sometimes get a little humor impaired.
Redneck Spanish Translation: "Gary, you are funny!"
[quote="ggower_99(at)yahoo.com"]Happened the same to our 701 here, cut one from a old Cessna tire (avoid using car tires, is an airplane � and cut the rubber part(s) to use from the sides of the tire...� Lasted nearly 200 hrs.... Plane has 236 hrs and just looks like the piece of tire needs replacement. Probably this next Saturday... Not a dificult thing to do. Once you get the correct size, cut some extras to save for next 200 hrs "preventive mantainance" or maybe a few more hrs...
Saludos
Gary Gower.
Flying from Chapala
701 912S 236 hrs.
bobkat
Posted: Thu Mar 26, 2009 11:34 am Post subject: Rubber Spacers on main gear |
Definitely!
Posted: Thu Mar 26, 2009 11:51 am Post subject: Rubber Spacers on main gear |
Thanks to all for the help on this issue. I really like the urethane
solution but not the color. However, being frugal (cheap) and having an
abundance of discarded tires along side the road in my area, I will go
the tire route. This will also please my wife since I will be greening
the landscape. Reduce, reuse, recycle, repair.
Dan Wilde
N948DW
raymondj(at)frontiernet.n Guest
Posted: Thu Mar 26, 2009 2:48 pm Post subject: Rubber Spacers on main gear |
Greetings,
Is anyone out there using the radius plates from Grove instead of or in
combination with the "rubber" blocks? I am planning on using them and
wondered about the metal on metal issue.
http://www.groveaircraft.com/radiusplates.html
Raymond Julian
Kettle River, MN
"Hope for the best,
but prepare for the worst."
