john.marzulli(at)gmail.co Guest
Posted: Tue Mar 24, 2009 10:35 am Post subject: Spacer between 7F8-4 and 7F8-6? (was CH701 front lower bea |
My problem is similar, but not the same.
The bungee cord is not under much tension, but full extension should not cause any banging on the steering stops. I think a small spacer between the stop plate and the bearing is still the solution in my case.
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
On Tue, Mar 24, 2009 at 11:13 AM, George Race <mykitairplane(at)mrrace.com (mykitairplane(at)mrrace.com)> wrote:
| Quote: | You are correct Curt. I found that using the kit supplied parts, I was concerned that the top strut cover, 7L1-5J, would be coming down on the top support possibly bending or breaking the bolts that hold it in place. My solution was to add a couple of .125 spacers to raise the top plate about an 1/8 of an inch above the top plate.
And yes, later I did put longer bolts through the bottom bracket with proper thread extensions showing. I think somewhere on my DVD there are additional pictures that show the longer bolts.
George - N73EX
Builder/Test Pilot
From: owner-zenith701801-list-server(at)matronics.com (owner-zenith701801-list-server(at)matronics.com) [mailto:owner-zenith701801-list-server(at)matronics.com (owner-zenith701801-list-server(at)matronics.com)] On Behalf Of Curt Thompson
Sent: Tuesday, March 24, 2009 10:22 AM
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Subject: Spacer between 7F8-4 and 7F8-6? (was CH701 front lower bearing plate (7F8-4) location?)
Craig,
It looks like George put a spacer between the Rear Lower Bearing (7F8-4) and the Nose Gear Stops (7F8-6). I’m guessing that this was so the Nose Gear Strut Assembly (7L1-1J) doesn’t hit the stops before 7L1-1J rides in 7F8-6. I made my own 7L1-1J and have the same issue. I figured I made 7L1-1J about 1mm too long (not much). I think John Marzulli has the same issue with his kit. I’m trying to decide if (a) I leave it alone, or (b) I re-make 7F8-8 a little higher, or (c) I put a spacer under 7L1-5J, or (d) I do what George did.
Have other builders run into this?
Curt
====== ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List tp://forums.matronics.com _blank">http://www.matronics.com/contribution
[/b] |
