dlorrzen701(at)earthlink. Guest
Posted: Mon Mar 23, 2009 9:03 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
Hi Curt, Check out this attached picture of my firewall construction. There really is no gap after all the rivets are in.
David L. Orr
[quote]--
163.27 KB |
7715 Time(s) |
Curt.Thompson(at)verizon. Guest
Posted: Mon Mar 23, 2009 9:43 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
David,
I see the ten A5 rivets in 7F8-4, then it looks like there are four more A4 rivets, then a gap, and then the two rows of A4 rivets continue. Doesn’t that area behind 7F8-4 (between the ten A5’s and the four A4’s cause a bend in the stiffener (7F8-1) (looking from the side)? I assume that the rivet gap is because you have not put in 7C4-2 (Pedal Central Bearing) yet?
Curt
p.s. It was good to meet you the other day to talk CH701s. The water jet cutter ripped my 0.75”x4”x96” AL bar down to 3.25” wide like it was butter. The Landing gear is bent and ready to go on the plane.
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of David L. Orr
Sent: Monday, March 23, 2009 9:59 PM
Subject: Re: Zenith701801-List: CH701 front lower bearing plate (7F8-4) location?
David L. Orr
Posted: Tue Mar 24, 2009 6:05 am Post subject: CH701 front lower bearing plate (7F8-4) location? |
The top of drawing 7F8 shows the lower bearing plate (7F8-4) on the outside of the skin (like your second picture).
I’m wondering about a wedge made out of 0.090” to the rear of 7F8-4 so that the stiffener transitions rather than having 7F8-4 being punched?
Curt
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Craig Payne
Sent: Monday, March 23, 2009 10:29 PM
Subject: RE: Zenith701801-List: CH701 front lower bearing plate (7F8-4) location?
Not sure which is correct but it can be built either of two ways. The first shot (white paint) is of my unflown 701. I didn’t build the section shown. The second shot is of George Race’s 701 N73EX (from his excellent DVD of photos). You either have a gap between the floor and the plate or between the plate and the channel. Unfortunately no one has a shot from the side to show what happens between the channel and the plate. The shots in the Zenith photo assembly guide from inside the fuselage don’t appear to shot the plate. So I guess it goes outside. I think I prefer it that way – like George’s and David’s. But it is worth asking Zenith about. Let us know what you find out.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Curt Thompson
Sent: Monday, March 23, 2009 10:26 PM
Subject: CH701 front lower bearing plate (7F8-4) location?
Where does the Central Floor Stiffener (7F8-1) go in relation to the Front Lower Bearing Plate (7F8-4)? Does 7F8-1 go below 7F8-2? That is what drawing 7F10 seem to indicate. Won't there be a gap between the floor (7F8-7) and 7F8-1 at the end of 7F8-4?
Curt | Quote: | | http://www.matronics.com/Navigator?Zenith701801-List |
| Quote: | | http://forums.matronics.com |
| Quote: | | http://www.matronics.com/contribution | [quote] [b]
Posted: Tue Mar 24, 2009 6:31 am Post subject: CH701 front lower bearing plate (7F8-4) location? |
Oh, one more thing. Aren’t the bolts on 7F8-4 in George’s picture too short? BTW, on mine when I use AN3-10A (per plans) they seem too long.
Curt
-- Craig
agibeaut
Posted: Tue Mar 24, 2009 7:20 am Post subject: CH701 front lower bearing plate (7F8-4) location? |
I'm at this stage of building my 701 and I saw the same thing. Those 10's look really long. Anyone know the reason for this?
--- On Tue, 3/24/09, Curt Thompson <Curt.Thompson(at)verizon.net> wrote:
| Quote: | From: Curt Thompson <Curt.Thompson(at)verizon.net>
Subject: RE: CH701 front lower bearing plate (7F8-4) location?
Date: Tuesday, March 24, 2009, 9:28 AM
location?
Oh, one
bolts on 7F8-4 in George’s picture too short?Â
BTW, on mine when I
long.
Â
Curt
Â
On Behalf Of Craig
Payne
Sent: Monday,
PM
To:
Subject: RE:
Zenith701801-List:
location?
Â
Not
sure which is
The second shot is
photos). You either
plate and the
show what happens
George’s and
know what you find
out.
Â
Craig
Posted: Tue Mar 24, 2009 11:40 am Post subject: CH701 front lower bearing plate (7F8-4) location? |
You could just file a ramp on the trailing edge of the plate. I don’t think you would have to take it down to a knife edge. I’d love to see a photo from the side with all the rivets and bolts in to see what happened to the channel.
-- Craig
Sent: Tuesday, March 24, 2009 8:04 AM
Curt
-- Craig
Curt | Quote: | | http://www.matronics.com/Navigator?Zenith701801-List http://forums.matronics.com http://www.matronics.com/contribution | 01234567890123456789
Posted: Tue Mar 24, 2009 1:53 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
Attached is a picture of the gap and bend behind 7F8-4. This is only clecoed now. Is this okay?
Curt
863.77 KB |
7695 Time(s) |
Harvey Richards
Posted: Tue Mar 24, 2009 3:29 pm Post subject: Re: CH701 front lower bearing plate (7F8-4) location? |
I filed a bevel on mine as Craig suggested and this made for a nicer fit .
_________________ CH 701 |
georgerace
Posted: Tue Mar 24, 2009 3:50 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
Hi Curt:
Here is part of my picture, Nose Gear 2.jpg from the DVD
Note there is a very small tapered opening from the back of the bearing plate. Also note the longer "final" bolts in the bearing mount with extra spacer.
I am not sure what I am seeing in your picture. Looks like the floor pan is sort of bent up away from the mounting bracket below it. Maybe just an illusion the way the picture was taken. I don't see that same floor pan warp in my picture, but it is taken from a slightly different direction. Will keep looking to see if I have any better picture of the area.
George
Sent: Tuesday, March 24, 2009 5:49 PM
Curt
29.4 KB |
7689 Time(s) |
_________________ Check out my CH-701 project at:
http://www.mykitairplane.com |
Posted: Tue Mar 24, 2009 4:07 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
BTW: Zenith “solved” this problem on the 601. The channel is wider than the plate. So the plate fits inside the U of the channel. I wonder what they do on the 750? Given the resemblance of the 750’s firewall to the 601 I be it uses the same approach.
-- Craig
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of George Race
Sent: Tuesday, March 24, 2009 5:50 PM
Hi Curt:
George
Curt
georgerace
Posted: Tue Mar 24, 2009 4:08 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
Hi Curt:
Here I think is a better picture from a slightly different angle.
Everything is riveted together on this one.
George
Curt
52.93 KB |
7689 Time(s) |
agibeaut
Posted: Tue Mar 24, 2009 6:19 pm Post subject: CH701 front lower bearing plate (7F8-4) location? |
That's what mine looks like. Right or wrong, I don't really see an alternative.
Date: Tuesday, March 24, 2009, 4:49 PM
location?
Attached is
okay?
Curt
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Wed Mar 25, 2009 4:53 am Post subject: Re: CH701 front lower bearing plate (7F8-4) location? |
For those who still have access to the firewall, you might want to go ahead and put in whatever baffling you plan to use over the nose steering rods. I waited until I had the engine on and the plane on wheels. It was a pain to install.
Tommy Walker in Alabama
_________________ Tommy Walker
N25A - Anniston, AL |
