william(at)gbta.net Guest
Posted: Sun Mar 22, 2009 3:47 pm Post subject: Aileron pushrod holes |
Today I started working on the rear wing spars. The instructions show a "squared" hole to be cut into the W-1007D doubler plate however the hole in my rear spar is actually a "teardrop" shape. Am I to modify the hole in the spar or simply copy the shape in the spar? A picture is attached.
Also, the doubler plates overhang the slot cut into the spar (slot is for the flap brackets I assume) just a little. Do I need to trim the doubler plates to the slot in the spar?? Another picture is attached.
524.41 KB |
2184 Time(s) |
![100_3691[1].jpg](files/100_3691_1__140.jpg)
450.37 KB |
2184 Time(s) |
![100_3692[1].jpg](files/100_3692_1__175.jpg)
rene(at)felker.com Guest
Posted: Sun Mar 22, 2009 4:21 pm Post subject: Aileron pushrod holes |
Just off of memory. The teardrop is an improvement so the rivet from the aileron connecting rod can not get caught. Match the holes…..just my old memory at work. If you check the archives I think you can find some discussion on the interference problem.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton
Sent: Sunday, March 22, 2009 5:43 PM
Subject: Aileron pushrod holes
LarryRosen
Posted: Mon Mar 23, 2009 8:12 am Post subject: Aileron pushrod holes |
That is the shape of the hole in my quick build wings.
I will send you a photo off list.
Larry Rosen
#356
Bill and Tami Britton wrote:
| Quote: | Today I started working on the rear wing spars. The instructions show
is attached.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
