rparigor(at)SUFFOLK.LIB.N Guest
Posted: Wed Mar 25, 2009 10:14 am Post subject: Ray Allen stick grip wired up to control 6 items with just 1 |
Managed wiring up Ray Allen stick grip using 1 relay, 2 diodes, a rotary switch and a 9 pin Radio Shack Molex connector to accomplish the following:****Pitch trim****Roll trim****Manual control of Airmaster prop****Audio panel PTT****Audio panel recorder playback****Switch from pilot to Co-Pilot control of pitch trim, roll trim and Airmaster manual prop controlWas going to use a 9 pin D-sub to fit inside the 1" OD (7/8" ID) stick, but liked the 9 pin Molex from Radio Shack better for a number of reasons:****Easier to remove pins****Fit of plug when you mutilate corners a little is a perfect fit****Snug fit requires no holdemtogetherDetails:http://www.europaowners.org/modules.php?set_albumName=album284&op=modload&name=gallery&file=index&include=view_album.phpRon Parigoris [quote][b]
