The Obvious
dalamphere(at)comcast.net
PostPosted: Wed Mar 18, 2009 1:01 pm    Post subject: The Obvious Reply with quote
You know, sometimes the obvious can be the most hidden.... I've been wrestling with a new intercom (PS1000II) that would stop working when the headset microphone was plugged in. All the wiring checked out, I disconnected it from the radio and everything I could - still it wouldn't work. Definitely didn't get any help from the manufacturer - His email response was anything but friendly or helpful. After a warning message, he just said to read the FAQ's.
Homebuilders beware, PS Engineering's stand is (here is the exact quote):
"Who did the installation?"
"If not installed by a PS Engineering dealer or a PS Engineering custom harness not purchased, the warranty is void."
When all I wanted was some information and suggestions how to proceed.
Would I buy anything more from these guys - no way!
Anyway, 12 hrs into the pursuit, the problem turns out that the mike key and audio hi wires were connected to the wrong jack pins - on each mike jack (pilot, co-pilot, aux).
On a microphone plug the tip is the mike key connection - NOT the center band like I thought. So obvious and yet so hidden... I'll bet more than one person has been bit by this misunderstanding! How come THAT wasn't in the FAQ's - eh?
Now I have to reinstall that harness!
Dave L.
harley(at)AgelessWings.co
PostPosted: Wed Mar 18, 2009 1:33 pm    Post subject: The Obvious Reply with quote
Amazing! They give harness construction instructions right on their website, and in the same breath say that the warranty is void if you follow them!
Harley
David & Elaine Lamphere wrote: [quote] You know, sometimes the obvious can be the most hidden.... I've been wrestling with a new intercom (PS1000II) that would stop working when the headset microphone was plugged in. All the wiring checked out, I disconnected it from the radio and everything I could - still it wouldn't work. Definitely didn't get any help from the manufacturer - His email response was anything but friendly or helpful. After a warning message, he just said to read the FAQ's.
Dave L.
msausen
PostPosted: Wed Mar 18, 2009 1:43 pm    Post subject: The Obvious Reply with quote
That’s a standard response from PS and I can’t really blame them. They have had lots of intercoms that were toasted by users installing their equipment and then trying to return them saying it’s PS’s fault. Solution to this is require a harness. Seems a level headed requirement rather than not supporting guys like us.
Michael
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of David & Elaine Lamphere
Sent: Wednesday, March 18, 2009 4:49 PM
Subject: The Obvious
Dave L.
PostPosted: Wed Mar 18, 2009 1:48 pm    Post subject: The Obvious Reply with quote
If you had queried the AeroElectric Connection
website search feature on "microphone" . . . one of the
hits you would have received . . .
http://www.aeroelectric.com/articles/micjack/micjack.html
. . . speaks to this issue.
You gotta cut the PS guys a bit of slack. The
majority of installations for their products are
carried out by folks who have done it before. I get dozens
of e-mails and phone calls per weeks with questions
that are equally simplistic. None of this stuff
is "hard" to do . . . but there's so much "easy"
stuff you need to know. Time that customer
service folks spend on the phone/email trying
to figure out which "easy" thing is being
overlooked doesn't help the bottom line.
I've listened to one sided conversations in the
customer service departments at Hakwker-Beech.
In most cases, the exchange of data is rapid,
concise, often folks at both ends of the line
are looking at the same computer screen. Occasionally,
you hear a conversation that is NOT moving
ahead smoothly. I've been told that sifting
the easy things with a new technician is
4 to 10 times more expensive to the company
than working with the more experienced tech.
Nonetheless they are courteous and as helpful
as they know how to be but its exceedingly
difficult to know what your listener doesn't
know. One of those calls can keep 4 to 10
more experienced folks waiting with commensurate
extensions of THEIR customer's down time on
a very expensive airplane!
I'm not suggesting that anyone is right or
wrong here. I'm only pointing out that
education is EXPENSIVE in terms of $time$
and patience. A lot of my time billed to customers
is to educate myself in the magnitude and
character of simple-ideas that require sifting.
Your frustration is understandable and perhaps
expected . . . but pitching mudballs at the PS
Engineering guys is perhaps unustified and
certainly not productive. I'm pleased that
root cause of your problem is solved and
that the project is again moving forward.
( -Thomas Paine 1776- )
jay(at)horriblehyde.com
PostPosted: Wed Mar 18, 2009 1:49 pm    Post subject: The Obvious Reply with quote
Hi there Dave,
I have had exactly the same problem when installing the PM1000 system from PS Engineering; so far I have not been able to solve the problem- your mail gives me a new place to look.. I’ll check it out and report back!
I also encountered the same poor service response from them- extremely bad. I would not at all recommend PS Eng products based on the extremely poor after sales service. If I hadn’t already cut the panel I’d go so far as to toss the damned thing out..
The PS Eng guys response was similar to that that you encountered- speak to the avionics agent who installed or sold you the product- I bought it from their stand at Oshkosh last year… to which I got the equivalent of an ‘oh well’ shrug…
Jay
Sent: 18 March 2009 10:49 PM
You know, sometimes the obvious can be the most hidden... I've been wrestling with a new intercom (PS1000II) that would stop working when the headset microphone was plugged in. All the wiring checked out, I disconnected it from the radio and everything I could - still it wouldn't work. Definitely didn't get any help from the manufacturer - His email response was anything but friendly or helpful. After a warning message, he just said to read the FAQ's.
[i]"Who did the installation?"[/i]
[i]"If not installed by a PS Engineering dealer or a PS Engineering custom harness not purchased, the warranty is void."[/i]
Dave L.
-- This message has been scanned for viruses and dangerous content by Pinpoint Securemail, and is believed to be clean. [quote][b]
PostPosted: Wed Mar 18, 2009 2:20 pm    Post subject: The Obvious Reply with quote
Hmm, I disagree somewhat with you Bob; if this is such an obvious problem and continuously encountered then the manufacturer ought to make it clearer on the installation instructions- quite simple really. Or, in the FAQ list on their website, provide pictures like you have- its obviously a frequent source of frustration for customers, and hence support staff- so make it clearer…
I have just checked my wiring, and I had also previously looked at the link that you provide in your mail, and my wiring is exactly as you indicate. I took my unit to a local PS Eng agent and avionics shop to check out and provided the detailed wiring diagram as I wired it up. They checked the unit out and found it to be fine- they also thought that my wiring was correct, but still the Icom A210 won’t talk to the PS unit..
Jay
Sent: 18 March 2009 11:47 PM
Subject: Re: AeroElectric-List: The Obvious
PostPosted: Wed Mar 18, 2009 2:43 pm    Post subject: The Obvious Reply with quote
Yep - that's the article! The light bulb went on at that moment!
Very clear essay on the subject Smile Thank You!
As to PS Engineering - they could have been just a little bit more helpful Smile
Not the kind of treatment you would like I am sure.
[quote] If you had queried the AeroElectric Connection
PostPosted: Wed Mar 18, 2009 2:51 pm    Post subject: The Obvious Reply with quote
Jay,
One other gotcha is keeping the jacks detached electrically from the panel. Those parts that come with the jacks : phenolic rings and black plastic rings that have a lip that fit in the mounting hole and insulate the jack stud are to be used! The signal lows are NOT ground and need to be kept isolated from the airframe/panel ground.
To their credit, they (PSE) DO give you the installation schematic. Some of the other manufacturers of avionics do not! DIY's have to really dig and scramble in those cases. Bob's postings and documents are priceless in those cases.
Dave
tonybabb(at)alejandra.net
PostPosted: Wed Mar 18, 2009 3:05 pm    Post subject: The Obvious Reply with quote
I have little to no sympathy for PS position I think the problems are completely of their own making and the solution is in their own hands. If their products are difficult to install then they should only sell through resellers who do installation or they should insist on a harness being purchased, or insist on customers taking a training course. Seems to me they want it both ways - additional revenue by selling direct to any retail customer with a credit card and low service level costs assuming they're selling through qualified installers.
Back in the early days of PCs there were numerous issues with customers buying PCs direct from manufacturers and then not being able to assemble them. Some manufacturers referred customers to the cheapest tech support they could find ( usually off-shore with a heavy accent following a script) and others stepped up to the plate and provided very simple color diagrams - with only numbers and pictures with no text descriptions that matched the color coded connectors and cables. Guess which manufacturers are still around today.....
If you know that your customers are going to be challenged to install your stuff then you have to look at the whole customer experience - a flashy stand at Oshkosh doesn't cut it any more - well designed products with documentation that matches the expected experience level of your customers. If you can't do that then get out of the business or you will be overtaken by those who will.
Tony
Velocty SEFG 62% done, 78% to go
www.alejandra.net/velocity
rjquillin
PostPosted: Wed Mar 18, 2009 3:13 pm    Post subject: The Obvious Reply with quote
I'm with Bob on this.
I had a King KMA aka PS-7000 unit. Had sticky buttons, and -under warranty- a King dealer REFUSED to accept the unit for repair. I sent it to PS, had it upgraded and it came back, promptly, with a PS bezel and working buttons. The IM for the 7000B unit has a drawing of the jack with Hi, Lo and PTT clearly indicated. Assuming you meant PM1000-II and not PS1000II, an even better and very clearly labeled diagram is right in the manual. If we can't RTFM, and follow, we have no business wiring our avionics, perhaps incorrectly, and then slamming the factory customer support.
Apologies if I offend, just my opinion.
Ron Q.
Barry Chapman
PostPosted: Wed Mar 18, 2009 4:37 pm    Post subject: The Obvious Reply with quote
Something else that may be a gotcha on this system is that they want the jack isolated from aircraft ground and that the shield grounds are back at the ps1000 box, not at the jacks. I have a pdf schematic of the wiring if any are interested, email off list. Thanks.
Barry Chapman
RV-9A
Sent: Wednesday, March 18, 2009 4:55:05 PM
Subject: RE: AeroElectric-List: The Obvious
Hi there Dave,
Jay
Dave L.
http://www.matronics.com/Navigator?AeroElectric-Listhttp://forums.matronics.com
Barry Chapman
RV-9A in progress
Tail complete, Wings here, Engine needs rebuilt
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger
Tim Olson
PostPosted: Wed Mar 18, 2009 5:22 pm    Post subject: The Obvious Reply with quote
Boy I don't know, the audio panel is about the most complex item
in a panel to wire. I know it's about the largest and most
complex wired item in my plane. I'm really glad they do provide
the diagrams and I am allowed to wire it myself, but I certainly
wouldn't want to be on their end having to provide support to
the untrained. I know Stein spends WAY more time in his business
helping amateurs figure out what they screwed up than I could
ever tolerate, and I know of specific examples where people
came screaming at his guys blaming them for inop audio panels...
only to find out later that things like jacks were mis-wired,
causing the issues. So like Michael said, I think it's pretty
normal for them to want to require a purchased or custom harness.
Everything a person needs to know is usually
in the avionics manuals, and PS has some of the best manuals
there are as far as interconnect diagrams go. But still,
it takes a very diligent reader and some hard studying for
an amateur to figure it out. It's complicated stuff.
I spend a bunch of time supporting apps and networks and users,
and I'll tell you what, it gets frustrating. I can't blame them
for their warranty position. I just approach it from the angle
that I shouldn't be doing it unless I'm willing to work
hard enough to do it right.
Tony Babb wrote:
[quote] I have little to no sympathy for PS position I think the problems are
Tony
www.alejandra.net/velocity <http://www.alejandra.net/velocity>
BobsV35B(at)aol.com
PostPosted: Wed Mar 18, 2009 5:49 pm    Post subject: The Obvious Reply with quote
Good Evening Tim and All,
I find that PS Engineering is about the easiest supplier to work with of any
that I have ever used.
I am currently finishing the wiring on the third PSE installation that I
have utilized. As always, one step at a time and carefully following the
drawing gets the job done.
As you say, wiring a complete intercomm is NOT a trivial task. Every time I
make a dumb mistake, the PSE folks have been most gracious in trying to help
me solve my problem.
Have you ever tried to talk to Garmin about anything?
I not only think PS Engineering has the finest intercomm available on the
market, I also feel they are the very best when it comes to service or help for
we dummies!
Happy Skies
Old Bob
AKA
Bob Siegfried
Ancient Aviator
628 West 86th Street
Downers Grove, IL 60516
630 985-8502
Stearman N3977A
Brookeridge Air Park LL22
In a message dated 3/18/2009 8:24:59 P.M. Central Daylight Time,
Tim(at)MyRV10.com writes:
Tony
jindoguy(at)gmail.com
PostPosted: Wed Mar 18, 2009 5:51 pm    Post subject: The Obvious Reply with quote
For many years I worked in QA for office products and the aircraft industry
PostPosted: Thu Mar 19, 2009 3:39 am    Post subject: The Obvious Reply with quote
Yeah, keeping the microphone and headset jacks ISOLATED
from the airframe is an important noise mitigation
technique. B&C has the washer sets.
I also peeked at the PS Engineering schematics I have
on the hard-drive. Their depiction of microphone wiring
is typical of the industry and echoed in all of my
drawings as well. If you check the locations of the
signal contacts on the mic jack symbol, PTT is furthest
away form the panel bushing, microphone audio is further
in. It's a subtle thing but imporant.
[img]cid:7.1.0.9.0.20090318214830.01c45618(at)aeroelectric.com.0[/img]
 Filesize:  32.64 KB
 Viewed:  17668 Time(s)
wooody04(at)bellsouth.net
PostPosted: Thu Mar 19, 2009 5:32 am    Post subject: The Obvious Reply with quote
I'll take one Barry
Jim Streit
wooody04(at)bellsouth.net (wooody04(at)bellsouth.net)
b e wrote: [quote] Something else that may be a gotcha on this system is that they want the jack isolated from aircraft ground and that the shield grounds are back at the ps1000 box, not at the jacks. I have a pdf schematic of the wiring if any are interested, email off list. Thanks.
Barry Chapman
RV-9A
From: Jay Hyde <jay(at)horriblehyde.com> (jay(at)horriblehyde.com)
Subject: RE: The Obvious
Hi there Dave,
Jay
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of David & Elaine Lamphere
Dave L.
5 [b]
rv9jim(at)juno.com
PostPosted: Thu Mar 19, 2009 5:37 am    Post subject: The Obvious Reply with quote
Dave,
I also had the same problem. My wiring is usually very good as I
check everything twice and follow the schematics faithfully. I have just
finished my second build. I have had no problems on my side. Then I
needed to have a passenger (finished my phase 1) and I could not talk to
him. I checked my wiring and thought that the PS1000II was the problem.
It was out of warranty and they (PS Eng) said that it would cost a bit to
fix the unit if it was bad. They said that the PS1000II is bullet proof
and they did not think the problem was in their unit. I had them send a
new unit just in case that was the problem. I was trying to get my
bi-annual flight check out of the way. When I swapped the intercom out,
the problem remained. I went back and did a very close check on the
wiring at the female jack. I had reversed two of the wires. I reversed
them to make the wiring correct. Volia --- everything worked fine. I
returned the unit to them and asked if there was a charge for the use. I
have not received a bill. This is my second PS1000II I have purchased
from them and if I build another plane I will use them again. I also
recommend the unit as it will let you set the squelch and volume
independantly. A great company. JMHO
Digital Photography - Click Now.
http://thirdpartyoffers.juno.com/TGL2141/fc/BLSrjpTDvmPiIfXkqfNqOqxTJ5qYnEwNAcycaE6tVIULDO9JI4yykXJhRMs/
echristley(at)nc.rr.com
PostPosted: Thu Mar 19, 2009 8:20 am    Post subject: The Obvious Reply with quote
industry. It never ceased to amaze me how companies will become so
entrenched in their way of doing things that they fail to take a step
back and analyze the costs of problems like these in terms of service
and ill will. Taken in that light I'd bet dollars to donuts they'd
find it was actually cheaper to bundle the harness with the intercom
even without a price increase over the cost of the intercom alone.
It wouldn't even take a full harness. Supply a little box and give
instructions to connect each of the mic/earphone combinations to the
little box. One wire from the box clips to airframe ground. There is a
connector for a 9V battery. On the front is some green LEDs and some
red LEDs. If you have the jack wiring correct, everything lights up
green. One of the wires hitting ground will give you a red light. A
single sheet of paper will tell you what is wrong with each jack.
The OBAM guys just runs through each of his jacks, and then connects
them to the intercom as each is confirmed. Bonus points if the little
box has a buzzer to confirm sound gets through to the headset. If they
don't want to give the things away, take a deposit, send one with each
unit, and refund the deposit when you get it back.
It's true that selling a highly technical device to the uninitiated is
difficult, but if you're not willing to confront the difficulty, don't
do it. Wiring the intercom is complicated, but it is not complex. You
have lots of wires, but each set basically does the same thing. It is
just a matter of confirming each piece individually, and then doing the
same operation several times. Smart companies take the time to look at
the problems their customers are having, and then takes steps to address
them.
http://www.ernest.isa-geek.org
Bob Collins
PostPosted: Thu Mar 19, 2009 11:04 am    Post subject: The Obvious Reply with quote
I hate to wade into the debate, especially when it's reached the "preachy"
stage (g), but I started tying this model into an Icom A210 radio last week,
then decided to chuck it and spend $200 on a harness from Stein.
http://rvnewsletter.blogspot.com/2009/03/no-fun-with-wiring-harnesses.html
Then a friend stepped in to connect the dots:
http://rvnewsletter.blogspot.com/2009/03/more-on-wiring-a210ps-1000.html
Bob Collins
St. Paul, Minn.
Letters from Flyover Country
n395v
PostPosted: Fri Mar 20, 2009 4:33 am    Post subject: Re: The Obvious Reply with quote
When wiring my PS audio panel their tech rep spent about 45 minutes on the phone with me until my problem was resolved. Friendly as could be and ended by saying call me back for any further problems.
Much more pleasant than Garmin who, by the way, will void the warranty after an owner install.
Would I buy another PS engineering product? Absolutely.
Milt
