rv8builder
Posted: Sat Mar 14, 2009 11:06 am Post subject: Grove brake resevoir |
I have a RV-8 under construction and have installed the Grove brake reservoir on each brake master cylinder. It should be noted that I have the 'In-Flight' adjustable rudder pedals. With the pedals at the full forward position, the brake reservoirs do hit the firewall when the pedals are deflected. Has anyone come up with a way to mount the Grove reservoirs in this situation with out the reservoir hitting the firewall? Or do I have to just bit the bullet and install the leaky nylon tubing!
Thanks in advance,
Dale
| | - The Matronics RV8-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
_________________ Dale |
madman266(at)comcast.net Guest
Posted: Sat Mar 14, 2009 11:41 am Post subject: Grove brake resevoir |
unless your 7 feet tall i doubt you will ever use the forward stop . I'm
5,10 and I'm on the first stop, also note that when you connect the rudder
cables , the pedals tilt aft reducing the possibility of reservoir reaching
the firewall...j
rice737(at)msn.com Guest
Posted: Sat Mar 14, 2009 5:04 pm Post subject: Grove brake resevoir |
Hey Dale C
I have the same reservoirs. I'm 5'10" with and inseam of 32 inches C and have my adjustable peddles in the closest hole to me. This gives me just the right amount of knee bend and is very comfortable. So unless you are very tall with long legs C you probable will not be using the hole closest to the firewall. Good luck.
Paul
RV8 140 hours
Flying Siren.
| Quote: | Subject: Grove brake resevoir
Date: Sat C 14 Mar 2009 12:06:41 -0700
To: rv8-list(at)matronics.com
--> RV8-List message posted by: "rv8builder" <rv8builder(at)earthlink.net>
I have a RV-8 under construction and have installed the Grove brake reservoir on each brake master cylinder. It should be noted that I have the 'In-Flight' adjustable rudder pedals. With the pedals at the full forward position C the brake reservoirs do hit the firewall when the pedals are deflected. Has anyone come up with a way to mount the Grove reservoirs in this situation with out the reservoir hitting the firewall? Or do I have to just bit the bullet and install the leaky nylon tubing!
Thanks in advance C
Dale
Dale
http://forums.matronics.com/viewtopic.php?p=234560#234560
rv8builder
Posted: Sun Mar 15, 2009 3:45 am Post subject: Grove brake resevoir |
It sounds like I need to hang and rig the rudder before I try to make adjustments.
Dale
rv8builder
Posted: Sun Mar 15, 2009 3:49 am Post subject: Grove brake resevoir |
Hi Paul.
I am 6' 4" with and wear pants with 37" inseams. (And then my pants sometimes look like 'high water pants'!) I just know that I will need the rudder pedals in the full forward position.
But from other comments, it sounds like I need to hang and rig the rudder before I get carried away with making changes.
Dale
Posted: Sun Mar 15, 2009 8:42 am Post subject: Grove brake resevoir |
Well C you are quite tall C sounds like a good plan to set it all up before you make a final decision.
Let us know how it goes.
Paul
[quote] Date: Sun C 15 Mar 2009 07:45:41 -0400
Subject: RE: Grove brake resevoir
--> RV8-List message posted by: Dale Ellis <rv8builder(at)earthlink.net>
Hi Paul.
But from other comments C it sounds like I need to hang and rig the rudder before I get carried away with making changes.
Thanks C
Dale
