yakflyr
Posted: Sat Mar 14, 2009 4:36 pm Post subject: Scott Taliwheel for Yak 55M |
Has anyone had experience installing a Scott tailwheel on a Yak 55M? If so, is there any special fabrication I need to be aware of?
Anthony.
scott-p(at)texas.net Guest
Posted: Sat Mar 14, 2009 6:21 pm Post subject: Scott Taliwheel for Yak 55M |
Hi Anthony,
I have a Scott 3200 on my 55M. I love it. MUCH superior to the Russian
tail wheel, especially as regards pushing and pulling and steering
into/out of the hangar. Plus if an FBO has any tailwheel tires/tubes,
they have that one.
You will need to fab an adapter plate to adapt the Russian tailwheel
spring to the Scott bolt pattern. I will be out at my hangar on Monday
(unfortunately have to work tomorrow, and didn't get this until afte I
came back for today...) and will shoot you a couple of pictures. It is
appears to be a pretty straightforward machining job, so it shouldn't be
a big deal to find a shop that can do it.
Good luck,
Scott Poehlmann
Yak 55M N155YK
Yak 55M wrote:
| Quote: | Has anyone had experience installing a Scott tailwheel on a Yak 55M?
Anthony.
drc(at)wscare.com Guest
Posted: Sat Mar 14, 2009 9:01 pm Post subject: Scott Taliwheel for Yak 55M |
If you could copy me on the pictures also.
Herb Coussons
drc(at)wscare.com
On Mar 14, 2009, at 9:19 PM, Scott Poehlmann wrote:
Hi Anthony,
Russian tail wheel, especially as regards pushing and pulling and
steering into/out of the hangar. Plus if an FBO has any tailwheel
tires/tubes, they have that one.
Monday (unfortunately have to work tomorrow, and didn't get this
until afte I came back for today...) and will shoot you a couple of
pictures. It is appears to be a pretty straightforward machining
job, so it shouldn't be a big deal to find a shop that can do it.
Good luck,
Scott Poehlmann
Yak 55M N155YK
> Thanks,
> Anthony.
warner.wesley(at)gmail.co Guest
Posted: Sun Mar 15, 2009 7:48 am Post subject: Scott Taliwheel for Yak 55M |
Here are some pics of the assembly I had made. It bolts up underneath
the spring just like the original, using the the original holes,
etc... I had a bunch made. I'm not sure if the guy has any left
over. I could check if you're interested. I don't recall the cost
exactly, but I know they weren't cheap.
On Sat, Mar 14, 2009 at 8:35 PM, Yak 55M <yak55m(at)gmail.com> wrote:
| Quote: | Has anyone had experience installing a Scott tailwheel on a Yak 55M? If so,
Anthony.
194.72 KB |
18626 Time(s) |
207.75 KB |
18626 Time(s) |
204.22 KB |
18626 Time(s) |
talew(at)bellsouth.net Guest
Posted: Sun Mar 15, 2009 8:06 am Post subject: Scott Taliwheel for Yak 55M |
yakflyr
Posted: Sun Mar 15, 2009 6:09 pm Post subject: Scott Taliwheel for Yak 55M |
Hi Wesley,
thanks for the info and photos, this is very helpful. If there are any leftovers from the original run, I would be very interested in purchasing one.
Anthony.
On Sun, Mar 15, 2009 at 8:47 AM, Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)> wrote:
[quote] Here are some pics of the assembly I had made. It bolts up underneath
On Sat, Mar 14, 2009 at 8:35 PM, Yak 55M <yak55m(at)gmail.com (yak55m(at)gmail.com)> wrote:
> Thanks,
> Anthony.
yakflyr
Posted: Sun Mar 15, 2009 6:10 pm Post subject: Scott Taliwheel for Yak 55M |
Thanks Scott,
that is exactly what I am hoping to use on my airplane. Photos would be a great help.
Anthony.
On Sat, Mar 14, 2009 at 7:19 PM, Scott Poehlmann <scott-p(at)texas.net (scott-p(at)texas.net)> wrote:
[quote]--> Yak-List message posted by: Scott Poehlmann <scott-p(at)texas.net (scott-p(at)texas.net)>
Hi Anthony,
I have a Scott 3200 on my 55M. I love it. MUCH superior to the Russian tail wheel, especially as regards pushing and pulling and steering into/out of the hangar. Plus if an FBO has any tailwheel tires/tubes, they have that one.
You will need to fab an adapter plate to adapt the Russian tailwheel spring to the Scott bolt pattern. I will be out at my hangar on Monday (unfortunately have to work tomorrow, and didn't get this until afte I came back for today...) and will shoot you a couple of pictures. It is appears to be a pretty straightforward machining job, so it shouldn't be a big deal to find a shop that can do it.
Good luck,
Scott Poehlmann
Yak 55M N155YK
Yak 55M wrote:
| Quote: | Has anyone had experience installing a Scott tailwheel on a Yak 55M? If so, is there any special fabrication I need to be aware of?
Anthony.
rget="_blank">http://www.matronics.com/Navigator?Yak-List
http://forums.matronics.com
le, List Admin.
mikspin
Posted: Sun Mar 15, 2009 6:57 pm Post subject: Re: Scott Taliwheel for Yak 55M |
Wesley,
Since you had this made, any chance you have some drawings for the piece?
Mike Hastings
Posted: Sun Mar 15, 2009 8:19 pm Post subject: Scott Taliwheel for Yak 55M |
I'll find out tomorrow what/if there are any more available. The
angle is set so that it is correct if you have gear extenders
installed (I did with Clevelands). If you don't have the extenders,
it's possible I could sell you the one that I have here. It has the
original angle (copied from the original tailwheel). I don't have the
model we did. It was done at the machinists facility. If he doesn't
have any more, I can create a new model from the one I have here.
These planes are a little tough for parts. I had to have aileron
bushings made as well. The availability wasn't good enough. If you
need some of those... I have extra sets. The easiest way to do a
quick check is to just to try and move your aileron at the tip
vertically. If you feel any play at all, chances are that they need
replacing.
Wes
On Sun, Mar 15, 2009 at 10:08 PM, Yak 55M <yak55m(at)gmail.com> wrote:
| Quote: | Hi Wesley,
one.
yakflyr
Posted: Sun Mar 15, 2009 9:13 pm Post subject: Scott Taliwheel for Yak 55M |
Thanks Wes,
the previous owner installed Grove 500x5 wheels and tires. I don't think I have gear extenders, from what I can tell the axles are bolted directly to the base of the legs. What do the extenders look like, and what is their purpose? I will check my ailerons as you suggested and let you know if I need the bushings.
Anthony.
On Sun, Mar 15, 2009 at 9:18 PM, Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)> wrote:
[quote] --> Yak-List message posted by: Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)>
replacing.
Wes
On Sun, Mar 15, 2009 at 10:08 PM, Yak 55M <yak55m(at)gmail.com (yak55m(at)gmail.com)> wrote:
> Hi Wesley,
> one.
> Thanks,
le, List Admin.
Posted: Wed Mar 18, 2009 12:16 pm Post subject: Scott Taliwheel for Yak 55M |
I'm having some issues getting in touch with the the guy I had making
them before. Hopefully I can see him next week or so. I thought I
had one of the prototypes here, but I guess it's not. I should be
able to find that one next week also.
The extenders normally are just some plate material that bolts to the
landing gear holes and lowers the axles by about 3". Most people
started using them to run the larger Whirlwind prop and still have an
adequate amount of ground clearance.
Wes
On Mon, Mar 16, 2009 at 1:12 AM, Yak 55M <yak55m(at)gmail.com> wrote:
| Quote: | Thanks Wes,
need the bushings.
Anthony.
yakflyr
Posted: Wed Mar 18, 2009 3:35 pm Post subject: Scott Taliwheel for Yak 55M |
Thanks Wes,
that makes sense. I think I have the extenders, but I will double check. Any chance you can provide a photo (sorry to be a pest)? Thanks for the follow up on the adapter plate, anything would help.
Anthony.
On Wed, Mar 18, 2009 at 1:13 PM, Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)> wrote:
[quote]--> Yak-List message posted by: Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)>
Wes
On Mon, Mar 16, 2009 at 1:12 AM, Yak 55M <yak55m(at)gmail.com (yak55m(at)gmail.com)> wrote:
> Thanks Wes,
> need the bushings.
> Regards,
> Anthony.
le, List Admin.
Posted: Fri Mar 20, 2009 8:28 am Post subject: Scott Taliwheel for Yak 55M |
I found the one adapter I have here at home. It was packed away. I
have attached a pic of it. In the picture is a gear extender as well,
so you can get an idea of what they look like. This particular Scott
adapter is for a plane without the gear extenders. It will work on
one with them, it's just not perfect.
Wes
Anthony.
On Wed, Mar 18, 2009 at 1:13 PM, Wesley Warner <warner.wesley(at)gmail.com>
> Wes
> > Thanks Wes,
> > think I
> > to
> > their
> > I
> > need the bushings.
> > Regards,
> > Anthony.
> le, List Admin.
> ="_blank">http://www.matronics.com/contribution
322.16 KB |
18581 Time(s) |
355.15 KB |
18581 Time(s) |
yakflyr
Posted: Mon Mar 23, 2009 3:55 pm Post subject: Scott Taliwheel for Yak 55M |
Hi Wes,
I am not sure if you received my previous email, but this is great news. Are you willing to part with it for a price? Or is there a way I can get the details to have one made locally?
Anthony.
On Fri, Mar 20, 2009 at 9:26 AM, Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)> wrote:
[quote] I found the one adapter I have here at home. It was packed away. I
Wes
On Wed, Mar 18, 2009 at 7:34 PM, Yak 55M <yak55m(at)gmail.com (yak55m(at)gmail.com)> wrote:
> Thanks Wes,
> Regards,
> Anthony.
>> Wes
>> > Thanks Wes,
>> > think I
>> > to
>> > their
>> > I
>> > need the bushings.
>> > Regards,
>> > Anthony.
>> le, List Admin.
mikspin
Posted: Thu Apr 02, 2009 10:57 am Post subject: Re: Scott Taliwheel for Yak 55M |
Wes,
I never saw a reply post on this, did you say that you had or could get some drawings on the Scott tailwheel adapter that was machined?
Please lemme know,
Mike Hastings
Posted: Thu Apr 02, 2009 12:04 pm Post subject: Scott Taliwheel for Yak 55M |
Mike,
The guy I was working with was supposed to get back to me. I just
spoke with him a few minutes ago, and lit a fire. He made it seem
as though the file was gone because it has been so long. However,
he's going to look. He said that if he had the file and the rest of
the parts from the initial run, and I bought them, he would include
the file (if he can find it). I'll keep you updated.
Wes
On Thu, Apr 2, 2009 at 2:57 PM, mikspin <acromike(at)gmail.com> wrote:
Wes,
Please lemme know,
Mike Hastings
http://forums.matronics.com/viewtopic.php?p 37409#237409
Posted: Fri Apr 03, 2009 6:02 pm Post subject: Scott Taliwheel for Yak 55M |
Ok. The guy got back to me tonight. He sent me a pic of the adapters
he has left (7 of them) and is looking for the digital file. I think
they are complete except for a counter-bore hole and a final
sanding/finishing. I'm trying to work a deal with him on all 7. If
it works out, they should be around $150ea with the final
sanding/finishing to be done by the buyer. They're made of 7075
Aluminum. They bolt up to the existing tailwheel spring on Yak 55 and
55M's with no modifications. If anyone is interested, please let me
know so, I can give him the go-ahead or not.
Thanks, Wes
On Thu, Apr 2, 2009 at 3:57 PM, Wesley Warner <warner.wesley(at)gmail.com> wrote:
| Quote: | Mike,
Wes
> Wes,
> Please lemme know,
> Mike Hastings
> http://forums.matronics.com/viewtopic.php?p=237409#237409
ralle, List Admin.
354.81 KB |
18524 Time(s) |
yakflyr
Posted: Sat Apr 04, 2009 9:33 am Post subject: Scott Taliwheel for Yak 55M |
Hi Wes,
I am interested.
Anthony.
On Fri, Apr 3, 2009 at 7:00 PM, Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)> wrote:
[quote]Ok. The guy got back to me tonight. He sent me a pic of the adapters
Thanks, Wes
On Thu, Apr 2, 2009 at 3:57 PM, Wesley Warner <warner.wesley(at)gmail.com (warner.wesley(at)gmail.com)> wrote:
> Mike,
> Wes
> On Thu, Apr 2, 2009 at 2:57 PM, mikspin <acromike(at)gmail.com (acromike(at)gmail.com)> wrote:
>> --> Yak-List message posted by: "mikspin" <acromike(at)gmail.com (acromike(at)gmail.com)>
>> Wes,
>> Please lemme know,
>> Mike Hastings
ralle, List Admin.
Posted: Sat Apr 04, 2009 10:04 am Post subject: Scott Taliwheel for Yak 55M |
Count me in.
Herb Coussons
639-8434
On Apr 3, 2009, at 9:00 PM, Wesley Warner wrote:
| Quote: | Ok. The guy got back to me tonight. He sent me a pic of the adapters
Thanks, Wes
> Mike,
> Wes
>> Wes,
>> machined?
>> Please lemme know,
>> Mike Hastings
ralle, List Admin.
<IMG_0117.JPG>
bu131(at)swbell.net Guest
Posted: Sat Apr 04, 2009 5:37 pm Post subject: Scott Taliwheel for Yak 55M |
count me in
andres
To: yak-list(at)matronics.com
Sent: Saturday, April 4, 2009 1:02:56 PM
Subject: Re: Re: Scott Taliwheel for Yak 55M
| Quote: | > Mike,
> Wes
>> machined?
>> Please lemme know,
>> Mike Hastings
ralle, List Admin.
