W-1013A aileron hinge brackets warped
william(at)gbta.net
PostPosted: Sat Mar 14, 2009 3:29 pm    Post subject: W-1013A aileron hinge brackets warped Reply with quote
I started work on the rear wing spars today and noticed that the w-1013a aileron hinge brackets are warped. With them lying flat on the table there's 1/16-3/32" gap in the center off the table on all 4 of them. Has anybody else run into this problem. Looks like it might have happened when they were "stamped" out. Obviously I'll wait 'til monday and see what Vans has to say but does anybody else have any thoughts on this. Surely it's not wise to use them like this, or is it???
Anyhow, pictures are attached.
Thanks in advance,
Bill Britton
RV-10 #40137
 Filesize:  750.92 KB
 Viewed:  4436 Time(s)
 Filesize:  545.42 KB
Strasnuts
PostPosted: Sat Mar 14, 2009 4:09 pm    Post subject: W-1013A aileron hinge brackets warped Reply with quote
I would say, treat it as the horizontal tabs that stick up from the tailcone, beat on them in a vice with a rubber mallet to straighten them.
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
rnewman(at)tcwtech.com
PostPosted: Sat Mar 14, 2009 4:42 pm    Post subject: W-1013A aileron hinge brackets warped Reply with quote
I vaguely remember the same issue (I'm kit #40176), I reasonably sure I "flatened" them back out with a little vise and clamp action.
-Bob Newman
Ron B.
PostPosted: Sat Mar 14, 2009 4:50 pm    Post subject: Re: W-1013A aileron hinge brackets warped Reply with quote
Mine were like your's, I straightened them.
Ron
Tim Olson
PostPosted: Sat Mar 14, 2009 6:36 pm    Post subject: W-1013A aileron hinge brackets warped Reply with quote
Yep, perfectly normal. Just flatten them back out. They'll straighten
when you rivet them to the other piece anyway.
Thanks in advance,
Bill Britton
RV-10 #40137
