Engine Mount Crack
crazyivan
PostPosted: Sat Mar 14, 2009 4:11 am    Post subject: Engine Mount Crack Reply with quote
I wanted to pass along some critical information to the group. I have a Kitfox Speedster with a 1995 standard firewall forward Rotax 912UL (80hp). I found a crack 3/4 of the way around one of the engine mount tubes that go from the firewall to the "ring." Kitfox has an SB regarding cracks in this tube and require a gusset to be welded in to reinforce. Thing is, the SB targets the 912ULS (100hp) installation because of the kickback the engine gives during start-up and shut-down. I'm here to tell ya, the 80hp will crack it as well.
It's the tube that comes from the upper right (pilot's view) firewall attach point to the "ring." It has the right oil tank support bracket attached. It looks like the crack started in the lower, outboard quadrant of the weld seam by the "ring."
The red mount in the pictures are my mount. The yellow mount is the replacement Kitfox sells with a circle around the gusset and the area where my mount cracked.
If you have a 912 and the engine mount without the gusset, then inspect these areas carefully.
 Filesize:  9.31 KB
 Viewed:  8492 Time(s)
 Filesize:  450.46 KB
 Filesize:  269.4 KB
Dave
Piper PA-22/20
Paul A. Franz, P.E.
PostPosted: Sat Mar 14, 2009 7:07 am    Post subject: Engine Mount Crack Reply with quote
Which propeller are you using?
Paul A. Franz
Registration/Aircraft - N14UW/Merlin GT
Engine/Prop - Rotax 914/NSI CAP
Bellevue WA
425.241.1618 Cell
"We have rights, as individuals, to give as much of our own money as
we please to charity; but as members of Congress we have no right so
to appropriate a dollar of public money."
-- American hunter, frontiersman, soldier and politician Davy Crockett (1786-1836)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
View user's profile Send private message Send e-mail Visit poster's website MSN Messenger
crazyivan
PostPosted: Sat Mar 14, 2009 7:49 am    Post subject: Re: Engine Mount Crack Reply with quote
I'm using an IVO ultralight 70". It's a few lbs lighter than the GSC I removed 2.5 years ago.
Dave
Piper PA-22/20
Paul A. Franz, P.E.
PostPosted: Sat Mar 14, 2009 12:01 pm    Post subject: Engine Mount Crack Reply with quote
years ago.
This reason I asked is a lighter prop would make the torsional vibration in shutdown a
little higher frequency. That might be contribute to this failure mode which is a
fatigue type failure. Fatigue in an Engineering sense is a failure mode that occurs
within the linearly elastic range of the material's stress-strain curve. The slope of
that curve is E, the modulus of Elasticity and where that line is linear, that is the
material's elastic range.
The lighter weight prop might produce either higher or lower torsional loads in
shutdown but they will occur in more cycles over a long period of time. Can you recall
any differences when you went to the lighter prop during shutdown?
Paul A. Franz
Bellevue WA
425.241.1618 Cell
"The great advances of civilization, whether in architecture or
painting, in science or in literature, in industry or agriculture,
have never come from centralized government."
--economist Milton Friedman (1912-2006)
Paul A. Franz, P.E.
Bellevue WA
425.241.1618 Cell
425.440.9505 Office
crazyivan
PostPosted: Sat Mar 14, 2009 12:28 pm    Post subject: Re: Engine Mount Crack Reply with quote
I was thinking about the resonance thing as well. Problem is that there was not a substantial difference between the GSC kick and the Ivo kick. Then again, higher frequency resonance won't have the higher amplitude that lower f resonance will have, generally speaking, so I probably would not feel a big increase of high f resonance for such a short period of time.
Theory aside, a 1 to 2 pound difference in props should not make a difference regarding a crack in a chromoly tube. Ultimately, I think it was a fatigue issue caused by a stress riser in the weld seam. It would have cracked eventually regardless of the prop.
As usual, my 2 cents.
Dave
Piper PA-22/20
akflyer
PostPosted: Sat Mar 14, 2009 2:45 pm    Post subject: Re: Engine Mount Crack Reply with quote
The weld does come in pretty sharply at the toe on the bottom. The stress riser theory has alot going for it, and once the crack started it just propagated around the heat affected zone. One reason I make sure all the welds I visual and accept transition smoothly to the base metal.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
