keithmckinley
Posted: Wed Mar 11, 2009 7:21 pm Post subject: Landing light replacement for CJ |
The Chinese landing lights are just not lasting for me. Does anyone have a mod they could recommend that would incorporate a halogen light or some other high intensity light that is reasonably priced. (<200 bucks)
Keith
dougsappllc(at)gmail.com Guest
Posted: Thu Mar 12, 2009 8:35 am Post subject: Landing light replacement for CJ |
Keith,
About your landing light:
1. They run really hot, so finger prints/grease on the glass is a factor, wipe them down after installation.
2. When you remove a TU bulb is the glass still tight in the metal base? If no, then you need to take some of the tension off the "ears" which hold the bulb in place. If the bulb goes in hard you may be damaging it during installation.
3. Have you checked the amount of amps/volts your drawing. Check both with engine not running and with engine running with gen light off.
About the inst screws:
I do have a bit of stock here, tell me which ones you need (for which instrument) and I'll see what I can find. Doubt I have a full set, but I might be able to help.
Always Yakin,
Doug
On Wed, Mar 11, 2009 at 8:21 PM, keithmckinley <keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com)> wrote:
| Quote: | --> Yak-List message posted by: "keithmckinley" <keith.mckinley(at)townisp.com (keith.mckinley(at)townisp.com)>
Keith McKinley
700 HS
KFIT
http://forums.matronics.com/viewtopic.php?p=234307#234307
Un/Subscription,
www.matronics.com/Navigator?Yak-List" target="_blank">http://www.matronics.com/Navigator?Yak-List
Matt Dralle, List Admin.
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
mgdimarco
Joined: 20 Apr 2006 Posts: 23 Location: Kissimmee, FL
Posted: Thu Mar 12, 2009 8:47 am Post subject: Re: Landing light replacement for CJ |
Replace the mount with a T-28 landing light (28v). It will require some riveting.
Mike
_________________ Michael Di Marco
China Blue
mgdimarco@yahoo.com
407-608-3290 |
keithmckinley
Posted: Thu Mar 12, 2009 9:03 am Post subject: Re: Landing light replacement for CJ |
Thanks Doug, I'll check all of that. As for the instrument screws that was Mike Bourget inquiring about those.
Mike, what is the source for the T-28 light?
Keith
