grayhill rotary
Fergus Kyle
PostPosted: Sat Mar 07, 2009 8:44 am    Post subject: grayhill rotary Reply with quote
Bob,
[And Ron] I tried the referred part no. and it seerms no longer to be in
stock. I didn't try to research further (lazy)......
Ferg
I don't have much space (rotary switch?) is there such a thing as a
four pole, triple throw three position mini toggle switch with three
positions and 16 terminals?
If so where can you get one?
I can make do with a 4 pole, double throw with center off but the 4PTT
would be "much more better" if such a thing exists.
I want to control intensity of several different light sources to
achieve a "Day", "Night" and "Dark night" level of intensity. Since all
the light sources are different (one linear regulator would not cut
it), will choose resistors that are close to what I want, and fit mini
potentiometers to fine tune. A DPDT could have up "Day", down "Night"
and "Dark night" could use middle to turn everything off. A triple
throw would allow me to have 3 intensities.
Thx.
Ron Parigoris
Grayhill
#51PT30-01-4-03N
http://tinyurl.com/bsws4r
winmail.dat
 Filename:  winmail.dat
 Filesize:  8.09 KB
 Downloaded:  336 Time(s)
