patreilly43(at)hotmail.co Guest
Posted: Mon Mar 02, 2009 2:42 pm Post subject: Ski Size |
Lynn Matteson, Looking at snowboards to convert to skis. What length and sq ' or " footprint do I need?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
Lynn Matteson
Posted: Mon Mar 02, 2009 5:21 pm Post subject: Ski Size |
Hi Pat-
Mine are about 600 sq inches each. I measured a Cub that turned out
to be 768 sq in for the pair, and another pair for a
Cub...Federals...that measured 1008 sq in for the pair. So mine are a
bit oversize, but work very well in 12-14" of snow. Narrow skis seem
to work better in hard snow, and wider are better for lighter snow,
it seems.
Lynn Matteson
Jabiru 2200, #2062, 605 hrs
Sensenich 62x46
Status: flying
On Mar 2, 2009, at 5:41 PM, Pat Reilly wrote:
| Quote: | Lynn Matteson, Looking at snowboards to convert to skis. What
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
============================================================ _-
contribution_-
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
CDNCH701
Joined: 26 Feb 2009 Posts: 11 Location: Winnipeg, MB Canada
Posted: Mon Mar 02, 2009 6:39 pm Post subject: Ski Size |
Hey Lynn and Pat this link is from a 701 builder with some home built skis
on Yahoo, and here are a couple of messages... this is what he had to say:
"hi all took some time but the new skis are installed and tested
perfectly this past weekend. performed very well on the snow which b/c
of the recent thaw surface was very dense and hard. i can pull the
plane with one finger on prop on top of this stuff. because of the
cant in the main gear the outer edge of the ski is lower then i would
like but still performed very well on the grass.all skis are 15" wide
mains are 48" long and nw is 36" top speed was down about 5mph and is
noticable less responsive to full throttle up. A mushy 4ooo rpm to
5200 in flight, the engine responds like normal but the asi is a
little slower to catch up. climbout was still impressive as ever.
total weight of all hardware is 60 lbs. so not so good for passenger
carrying but at least spent 2hours sipping around doing t & g's with
the bunch of hanger buddies only able to watch from the snowbanks.
will post some pics soon but will look like carbon copies of the ones
listed at zenith."
"just uploaded some photos. mains are 14 x 48 x 1/8 alum sheet with a
3.5" incline. 2- 1 x 2" rails on 12" centers stitch welded with a 15 "
wide sheet of 1/8 uhmw popriveted to bottoms. an bolts for mounting
hardware and clips. rest of the cable, bungii and hardware is local
building material. the nw pivot is a shouldered bushing machined to
size witha 5/16 x 2 an bolt and locknut. the "s" brace is a just in
case support. I can remove the ski without touching the nw axle. tail
wheels are hockey pucks board and oilite bushings pressed into."
http://groups.yahoo.com/group/701builders/photos/album/995817052/pic/list
Let me know if you can access this link, there are some pics there of the
skis...
R.D.(Ron) Leclerc
CH701 Plans(Scrap) Builder #7-6699
Porsche Power Geared Redrive
Winnipeg, MB Canada
infow(at)mts.net
3/2/2009 7:56:49 PM
Hi Pat-
out to be 768 sq in for the pair, and another pair for a
are a bit oversize, but work very well in 12-14" of snow. Narrow
skis seem to work better in hard snow, and wider are better for
lighter snow, it seems.
Lynn Matteson
Sensenich 62x46
Status: flying
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
 _-
 _- contribution_-
= - The Kitfox-List Email Forum -
= - MATRONICS WEB FORUMS -
your generous support!
nail13zg(at)centurytel.ne Guest
Posted: Mon Mar 02, 2009 6:54 pm Post subject: Ski Size |
Ron,
How 'bout posting your pictures to the matronics/kitfox list
Trey Moran
CDNCH701
Posted: Mon Mar 02, 2009 7:24 pm Post subject: Ski Size |
Let me know if this works...
Ron
Ron, I couldn't open the photos.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
 Date: Mon, 2 Mar 2009 20:38:26 -0600
 Subject: Re: Ski Size
 --> Kitfox-List message posted by: "R.D.(Ron) Leclerc"
 home built skis on Yahoo, and here are a couple of
 tested perfectly this past weekend. performed very well on
 the snow which b/c of the recent thaw surface was very dense
 and hard. i can pull the plane with one finger on prop on top
 of this stuff. because of the cant in the main gear the outer
 edge of the ski is lower then i would like but still
 performed very well on the grass.all skis are 15" wide mains
 is noticable less responsive to full throttle up. A mushy
 4ooo rpm to 5200 in flight, the engine responds like normal
 but the asi is a little slower to catch up. climbout was
 still impressive as ever. total weight of all hardware is 60
 lbs. so not so good for passenger carrying but at least spent
 2hours sipping around doing t & g's with the bunch of hanger
 buddies only able to watch from the snowbanks. will post some
 pics soon but will look like carbon copies of the ones listed
 at zenith."
 sheet with a 3.5" incline. 2- 1 x 2" rails on 12" centers
 stitch welded with a 15 " wide sheet of 1/8 uhmw popriveted
 to bottoms. an bolts for mounting hardware and clips. rest of
 the cable, bungii and hardware is local building material.
 the nw pivot is a shouldered bushing machined to size witha
 5/16 x 2 an bolt and locknut. the "s" brace is a just in case
 tail wheels are hockey pucks board and oilite bushings
 pressed into."
 ist
 there of the skis... R.D.(Ron) Leclerc CH701 Plans(Scrap)
 Builder #7-6699 Porsche Power Geared Redrive Winnipeg, MB
 Canada infow(at)mts.net 3/2/2009 7:56:49 PM
 --> Kitfox-List message posted by: Lynn Matteson
 Hi Pat-
 turned out to be 768 sq in for the pair, and another pair for
 a Cub...Federals...that measured 1008 sq in for the pair. So
 mine are a bit oversize, but work very well in 12-14" of
 snow. Narrow skis seem to work better in hard snow, and wider
 are better for lighter snow, it seems.
 Lynn Matteson
 Sensenich 62x46
 Status: flying
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
 _-
contribution_-
 http://ww Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-
= - The Kitfox-List Email:-( Features Navigator to Archive Search & Download, 7-Day
> http://www.matronics.:-( -
MATRONICS WEB FORUMS -->
List Contribution:-( http://www.matronics.com/contribution _-
72.79 KB |
14192 Time(s) |
29.67 KB |
14192 Time(s) |
38.1 KB |
14192 Time(s) |
Lynn Matteson
Posted: Tue Mar 03, 2009 5:47 am Post subject: Ski Size |
The photos and text came through loud and clear, Ron, and thanks.
His skis are similar to my old ones, in that they let the tire
penetrate (in my opinion) too far, and he has the "cheese slicer"
effect going for (against) him. I can't imagine this arrangement
weighing 60 lbs, either, but it DOES include a nosewheel ski, which I
don't have the equivalent of for my tailwheel....haven't found the
need for it yet.
No need for skis around here...Lower Michigan....as the ground is
clear of snow, but it's 3 degrees F. above zero, clear as a bell and
wind-less, and I'm gonna go fly some lakes!
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 2, 2009, at 10:23 PM, R.D.(Ron) Leclerc wrote:
| Quote: | Let me know if this works...
Ron
<kau03y1ven8r4w7ebnlt>
<76a4ovan2d8qbizff2h3>
<38fieofllxwituveings>
N369LM |
akflyer
Posted: Tue Mar 03, 2009 9:58 am Post subject: Re: Ski Size |
[quote="patreilly43(at)hotmail.co"]Lynn Matteson, Looking at snowboards to convert to skis. What length and sq ' or " footprint do I need?
Pat Reilly
Mod 3 582 Rebuild
Rockford,IL
ohh caa caa... here we go again lol... What are the average snow depths? mine have 780 sq. in. and I would not want any less for the snow I fly off of most of the time. I had them in knee deep powder and they performed great. Only sunk in about 4 inches or so. Now to make a tail ski and I will be golden.
Snakeman
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
Float Flyr
Posted: Tue Mar 03, 2009 1:10 pm Post subject: Ski Size |
Lynn:
We had 11C ~ 51F temps here today. Ceiling was minimal with several rain
showers. We lost over a foot of snow today but more to go yet.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Lynn Matteson
Posted: Tue Mar 03, 2009 2:02 pm Post subject: Ski Size |
I don't think those are carpet.....they look like paver blocks to me,
Pat. Look closer and you'll see that where the diamond pattern is,
there is no ski attached to the hanging brackets. And these aren't
Ron's skis....he was just posting the link.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 3, 2009, at 10:01 AM, patrick reilly wrote:
| Quote: | Ron, Yes, photos are great. It looks like you put carpeet on the
tops of the skis. There is a diamond pattern on thetop of the ski.
What is that?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
Date: Mon, 2 Mar 2009 21:23:37 -0600
Subject: RE: Ski Size
Ron
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
 at zenith."
 pressed into."
995817052/pic/l
 ist
 Hi Pat-
 Lynn Matteson
 Sensenich 62x46
 Status: flying
 Pat Reilly
 Mod 3 582 Rebuild
 Rockford,IL
 _-
contribution_-
_-
List Contribution
N369LM |
Posted: Tue Mar 03, 2009 2:34 pm Post subject: Ski Size |
Len C We don't have knee deep powder. Never! As a matter of fact we don't have powder period. I'm shooting for 600 sq " per ski. But thanks for info.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | Subject: Re: Ski Size
Date: Tue C 3 Mar 2009 09:58:48 -0800
--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
[quote="patreilly43(at)hotmail.co"]Lynn Matteson C Looking at snowboards to convert to skis. What length and sq ' or " footprint do I need?
Pat Reilly
Mod 3 582 Rebuild
Rockford CIL
> [b]
Snakeman
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
582 IVO IFA
Full Lotus 1260
hander outer of humorless darwin awards
http://forums.matronics.com/viewtopic.php?p=232974#232974
&g============
Lynn Matteson
Posted: Tue Mar 03, 2009 3:46 pm Post subject: Ski Size |
When I was digging into ski sizes, it *seemed* that all the skis that
I measured were built under the assumption of about 1-2 pounds of
airplane weight per square inch of ski. That's a wild --- guess, but
again, deep powdery snow requires more flotation/area, and hard-
packed snow needs less area, at least from what I've been able to
gather.
Lynn Matteson
Jabiru 2200, #2062, 610 hrs
Sensenich 62x46
Status: flying
On Mar 3, 2009, at 5:33 PM, patrick reilly wrote:
| Quote: | Len, We don't have knee deep powder. Never! As a matter of fact we
thanks for info.
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
N369LM |
Posted: Wed Mar 04, 2009 6:42 am Post subject: Ski Size |
Lynn C Don't know if you are a skier C but that applies to downhill skiing also. Powder skies are much wider than carving skies.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
| Quote: | From: lynnmatt(at)jps.net
Subject: Re: Kitfox-List: Re: Ski Size
Date: Tue C 3 Mar 2009 18:45:33 -0500
--> Kitfox-List message posted by: Lynn Matteson <lynnmatt(at)jps.net>
When I was digging into ski sizes C it *seemed* that all the skis that
airplane weight per square inch of ski. That's a wild --- guess C but
again C deep powdery snow requires more flotation/area C and hard-
packed snow needs less area C at least from what I've been able to
gather.
Lynn Matteson
Kitfox IV Speedster C taildragger
Jabiru 2200 C #2062 C 610 hrs
Sensenich 62x46
Status: flying
> thanks for info.
> Pat Reilly
> Mod 3 582 Rebuil= Archive Search & Download C 7-Day Browse C Chat C FAQ C
&g====
Lynn Matteson
Posted: Wed Mar 04, 2009 11:42 am Post subject: Ski Size |
I haven't skied in 20 years, and haven't kept up with that sport, but
what you say sounds right.
Lynn Matteson
Sensenich 62x46
Status: flying
On Mar 4, 2009, at 9:40 AM, patrick reilly wrote:
| Quote: | Lynn, Don't know if you are a skier, but that applies to downhill
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> Subject: Re: Re: Ski Size
> Date: Tue, 3 Mar 2009 18:45:33 -0500
> To: kitfox-list(at)matronics.com
that
> gather.
> Lynn Matteson
> Kitfox IV Speedster, taildragger
> Sensenich 62x46
> Electroair direct-fire ignition system
> Status: flying
> > thanks for info.
> > Pat Reilly
> > Mod 3 582 Rebuil= Archive Search & Download, 7-Day Browse,
Chat, FAQ,
&g====
contribution_-
N369LM |
dashwood
Joined: 24 Jan 2009 Posts: 73 Location: sw ontario canada
Posted: Wed Mar 04, 2009 7:13 pm Post subject: Re: Ski Size |
hello lynn: its odd that you guys are talking about my skis. i got some of my inspiration from looking at the picture posts of yours. The originals idea came from robert nelson in the zenair .com posts of skis. http://www.zenithair.com/stolch701/7-photo81.html library #81...His are of the blue 701 at the top and about 2/3 down the list. I emailed him for info and he supplied me with some spec and more pics. .some others on the site show a guy standing on his skies so i got some relative sizes from that. I was just winging it as to the sizes. I just now did some calculations and came up with just under 2lb /sq in at full load. The pictures are just after traversing a 6' deep snowdrift. The plane sank about 8" but was able to hold the nw higher with rpm and backstick. I walked back through the same drift and sank past my knees. My size 12'vs couldnt hold up the 200lb hulk.there is a fair amout to cheese slicing and the wheels protrude about 2". the home field is grass with many short hops to pavement so i wanted both.
yes the other pic is of the nw ski under construction detailing the machined pivot separate from the nw axle....including pavers in the hanger
ruebd(at)skymail.csus.edu Guest
Posted: Thu Mar 05, 2009 8:30 am Post subject: Ski Size |
Everyone knows size matters!
