kearney
Posted: Sun Mar 01, 2009 8:05 pm Post subject: Countersinking Fiberglass |
Hi
After a bit of a force break from building, I managed to put a few hours in
today. I have a Tony Sustare center console that I am fitting and am
wondering about countersinking holes in fibreglass.
The center console fits over the tunnel cover which is held in place with
flush head screws. I am wondering as to the best way to counter sink the
screws. My Cherokee has countersunk washers to hold some of the fibreglass
tail cone etc in place. Should I be using something similar on the
fibreglass console?
Inquiring minds need to know...
Les Kearney
#40643 - lots of assembly required
Dave(at)AirCraftersLLC.co Guest
Posted: Sun Mar 01, 2009 9:27 pm Post subject: Countersinking Fiberglass |
Les,
You will want to stay with flush scews there. It's a tight fit as-is and
protruding screws will just make it worse.
If the glass is thick enough you can countersink it. Metal countersink
cutters get dull really fast on fiberglass, but these work great:
http://www.averytools.com/c-104-permagrit-countersinks.aspx
If the material is too thin to countersink without enlarging the hole, then
countersunk washers will help. Countersink far enough that the head of the
screw is flush, then use the washer to essentially enlarge the head of the
screw. That'll help spread out the load and keep the fiberglass in good
shape for a long time.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
drfred(at)suddenlinkmail. Guest
Posted: Mon Mar 02, 2009 6:05 am Post subject: Countersinking Fiberglass |
Les.
I have the same console. I used round head screws to keep with similar
screws on the panel. "theme" thing I guess. Anyway, I don't think it
would be a problem to hold the front part of the console on with just
countersunk flush screws. However, you need to think about the center
console. As much as I try and help some people into the airplane in the
correct manner, a lot of weight sometimes gets put on the center arm
rest. People with poor mobility sometimes just cant do what is needed
to get in and out of the plane. It puts a lot of stress on that center
arm rest. So counter sinking and putting the counter sunk washers might
be a good idea on the center arm rest. Just depends on the look that
you want along the bottom edge.
Fred Williams
Les Kearney wrote:
Hi
fibreglass console?
Les Kearney
Bldgrv10450(at)comcast.ne Guest
Posted: Mon Mar 02, 2009 10:02 am Post subject: Countersinking Fiberglass |
Fred,
How well does your overhead vent set-up work?
Paul Grimstad
