kearney
Posted: Mon Mar 02, 2009 7:24 am Post subject: Countersinking Fiberglas |
Hi Fred
Thanks for the info especially about people putting weight on the console.
Too much weight could cause problems. Not being sure as to the structural
requirements, I have left the tunnel cover in place and put the console over
that. If need be, I could put a small insert between the tunnel cover and
the bottom of the storage compartment so any weight on the console is
transferred to the tunnel cover and not down the side panels to the screws.
I hope that makes sense...
Did you get Tony's panel as well and if so, how did you handle installation
or the radio stack etc?
Cheers
Les
drfred(at)suddenlinkmail. Guest
Posted: Mon Mar 02, 2009 8:24 pm Post subject: Countersinking Fiberglas |
Les;
I up loaded some panel pics. I hope it will help some. I did use the
accuracy avionics panel. If you will look closely at the rear panel
picture dated 5/13/08 you can see the aluminum rails that I used to
mount the stack. If you look under the stack you see a couple of boards
that the panel is resting on. These are two layers of MDF that I cut to
the exact size of the radio stack. I then inserted them through the
opening of my center cut out and used them as the parallel and
reference to get the two aluminum rails in place. I don't specifically
remember how I attached the rails, but I remember trimming them to just
fit flush and up behind the fiberglass of the panel and epoxying them in
place. If I remember correctly, I used the corner screw holes to help
hold the rails in place. I also put plate nuts on the rails to hold
the exterior screws.
http://picasaweb.google.com/drfredparis/PanelPics?feat=directlink
Then, Tony's directions on taping the frames together lets you drill
into the sides of the aluminum angles and drill and tap for the screws
that hold the radio frames to the panel. If you don't have a copy of
Tony's directions, let me know and I can dig mine up for you.
Regarding the weight on the screws issue. I really just wanted you to
be aware of what I have seen. There are a lot of screws across there to
hold the weight. Also, for me, I covered the panel and console with a
layer of carbon fiber. That should be worth about 4 layers of
fiberglass. I know I have put a lot of weight on the console when I
have been panel diving to fix small issues and hook things up.
Also, I don't think I would have put the center console in if I had a
choice again. It is very difficult to work around and limits access to
the tunnel for maintenance.
I looks good and is functional. It also takes up some lateral knee room
on long flights.
Fred
kearney
Posted: Mon Mar 02, 2009 8:51 pm Post subject: Countersinking Fiberglas |
Hi Fred
Thanks for the PIX. I think I have an idea as to how you made things work.
If you have a copy of Tony's instructions that would be great. Unfortunately
I wasn't able to get a copy or speak to Tony about how things should go
together...
Cheers
Les
robin1(at)mrmoisture.com Guest
rv(at)thelefflers.com Guest
Posted: Tue Mar 03, 2009 3:43 am Post subject: Countersinking Fiberglas |
Les,
You may want to give Eric a call. Eric used to work at Accuracy and
Redmond Air has continued manufacturing of the fiberglass parts that
Accuracy used to sell.
Bob
Eric McDonald
Avionics Technician
Redmond Air LLC
Redmond, Oregon
eric(at)redmondair.com
Phone: 541-923-1355
Fax: 541-923-4181
Full Service FBO CRS#: Q9RR266Y
steveg(at)redmondair.com Guest
Posted: Tue Mar 03, 2009 7:21 am Post subject: Countersinking Fiberglas |
I have attached the mounting instructions for the panel and console. I hopw
they come through.
Steve
Mounting_Instructions_for_RV10_Panel_and_Center_Console.pdf |
686.66 KB |
1058 Time(s) |
Posted: Wed Mar 04, 2009 11:03 am Post subject: Countersinking Fiberglas |
Les,
If you are still looking for information on installing the radios see the
attached file.
Steve
Radio_Stack_Mounting_Rails.pdf |
97.49 KB |
392 Time(s) |
kearney
Posted: Thu Mar 05, 2009 4:39 pm Post subject: Countersinking Fiberglas |
Steve / Dr Fred
Thanks for all the info on the AA panel & console. They are invaluable given
that I am a FG neophyte.
Cheers
Les Kearney
#40643
