Joined: 28 Mar 2008 Posts: 1973 Location: Riley TWP Michigan
Posted: Sun Mar 01, 2009 7:23 am Post subject: Polyfuses |
On page 50 of the April 2009 issue of Kitplanes Magazine, Bob Fritz installs Polyfuses in his Jabiru. He said that Polyfuses are used to protect electric window motors in cars. Have Polyfuses been proven in the field to be reliable? If so, can we or should we be using them in our airplanes? The endurance bus would be an ideal application for Polyfuses. They would protect the wiring by limiting the current. If they open, they will automatically reset upon removal of the overload condition. Bob Fritz put LEDs in parallel with the Polyfuses to indicate an overload condition. Advantages of the Polyfuse are light weight, low cost, do not take up panel space, and require no pilot action to reset. What do you think?
Joe
_________________ Joe Gores |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sun Mar 01, 2009 8:15 am Post subject: Polyfuses |
The EXP BUS uses polyfuses. The unit is my RV-6A has been problem
free/working successfully for five years.
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Sun Mar 01, 2009 12:57 pm Post subject: Polyfuses |
At 10:13 AM 3/1/2009, you wrote:
<densing(at)carolina.rr.com>
Dale Ensing
peter(at)sportingaero.com Guest
Posted: Sun Mar 01, 2009 3:03 pm Post subject: Polyfuses |
My EXPBUS had been problem free for 7 years but is now giving occasional
very short duration (momentary) power cuts. Really tricky to figure exactly
what is going on. I thinking of ripping it out and installing a regular fuse
block. Will also be much easier to add electrical items in the future.
Peter
RV-6A ~600 hours
marcausman
Posted: Thu Mar 05, 2009 12:12 pm Post subject: Re: Polyfuses |
Technically there's nothing wrong with polyfuses. But I am not a fan of using them in an aviation application because you cannot control them directly like you can an electronic (solid state) circuit breaker or old-style circuit breaker. At least when a fuse blows the circuit stays off.
_________________ Marc Ausman
http://www.verticalpower.com "Move up to a modern electrical system"
RV-7 IO-390 Flying |
Posted: Thu Mar 05, 2009 12:46 pm Post subject: Polyfuses |
At 02:12 PM 3/5/2009, you wrote:
circuit stays off.
Sure. We (the TC guys) never had an arugment
with the ability of the polyfuse to perform
as advertised. Our problem was delivering to
traditional design goals of which you mentioned
two, control and non-self re-setting. The other
problem was that the parts are not bolt-in, wire
up and play. You have to install them on some
manufactured assembly that incorporates an
etched circuit board for mounting the parts.
Even if we popped for the custom assembly, the
TOTAL cost of acquisition/ownership wasn't
that much better than what we were already
doing. The breaker as a mil-qualified bolt-in-
and-play parts require no special attention
to mix and match as needed. A customized assembly
has to be designed, qualified and becomes very
hard to change once approved for the airframe.
( -Thomas Paine 1776- )
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Mon Mar 09, 2009 7:35 pm Post subject: Polyfuses |
So here's a thought then for a potentially suitable application for these little monsters where there is some $value$. Ignoring the fact that these are surface mount creatures and a suitable and robust mounting mechanism would be needed, what about a scenario where you have a rear mounted battery and need to protect a wire in which a fuse would not be useable. Say if a device has a low power requirement but for some reason has a crowbar circuit in it like maybe a Lightspeed ignition.
Like I said before, I'm not keen on using a relay as that is nothing more than a workaround in my mind and introduces a whole new failure mode plus a bunch of additional wiring. The self resetting nature of the Polyfuse wouldn't be a big deal as I would still want a master switch on each LSE. Checklist item would be the best solution to addressing when to reset a "blown" ignition. More importantly it would allow the crowbarred (is that a word) ignition to be reset without the need to access a inaccessible fuse/breaker or use a relay to shoe horn a breaker into an accessible location.
So can someone tell me why this would not work to address the recent revelations around LSE's? I still would rather use a fuse or breaker but it seems to be as good or better than some of the other alternatives (big wire, relay).
Posted: Wed Mar 11, 2009 7:15 pm Post subject: Polyfuses |
At 10:30 PM 3/9/2009, you wrote:
Sausen)" <rvbuilder(at)sausen.net>
I think I'm lost. How would the polyfuse facilitate
an alternative to big wires and/or relays? I don't
recall a conversation about relays except for heavy
duty alternate feed paths for the e-bus.
I'm not seeing your point about a polyfuse being
more attractive than a fuse or breaker in the
same slot. Can you enlighten me?
msausen
Posted: Thu Mar 12, 2009 5:00 am Post subject: Polyfuses |
Let me see if I can refresh your memory. Because of the undocumented crowbar "feature" in the LSE ignitions that came to light recently, you had suggested using a relay to provide power to an unprotected wire in the case of a rear mounted battery.
The concern was that the LSE could cause a trip/blow in an OV situation however the ignition would be fine and require a reset. In a rear mounted battery the only way to accommodate this need to reset was to put a breaker up on the panel but this left an unprotected line from the battery to the CB. You suggested a standard relay would be the best way to address this and I didn't like the additional complexity in addition to replacing one potential failure mode with another.
It seems to me that a Polyfuse would address the need to reset a nuisance trip and allow the protection to stay back by the battery without needing to add relays (more wires, additional failure points, and additional switches) or big fuses/fat wires to get a CB up within arm's reach.
Michael
Posted: Thu Mar 12, 2009 4:12 pm Post subject: Polyfuses |
At 07:56 AM 3/12/2009, you wrote:
Is the crowbar feature for real? Somebody else mentioned that
they thought this was a mis-understanding of some variety.
You LSE customers should be curious/concerned about this . . .
which one is going to call/write LSE and find out?
| Quote: | The concern was that the LSE could cause a trip/blow in an OV
| Quote: | It seems to me that a Polyfuse would address the need to reset a
Okay, I remember. Yeah, the polyfuse looks attractive
for this. You might even consider a switch-breaker for
the panel mounted control . . . or even just a switch.
The wire-protection issue is covered with the polyfuse.
Now . . . about that robust mounting. Let me think about
this a bit. We could use the same technique for the
NTC inrush limiters too. They have the same mounting
challenge.
I've got to place an order with Digikey tomorrow for
some project parts. I'll get both NTC and PTC devices
coming and see if we can figure out a way to make these
things suitable for the aircraft installation.
msausen
Posted: Thu Mar 12, 2009 5:05 pm Post subject: Polyfuses |
The source of the information got it directly from Klaus so I think we can at least assume it's correct for this exercise. I agree on the switch at the panel. I probably won't have a key switch so my intention is to use a normal switch for power control. Thanks for looking into this, let us know if you come up with anything on the mounting.
Michael
Posted: Fri Mar 13, 2009 7:11 am Post subject: Polyfuses |
At 07:56 PM 3/12/2009, you wrote:
Michael
Okay. Can't do better than that. Let's explore the polyfuse thing
closer. Maybe we can find a "real" use for these puppies
after all . . .
fvalarm(at)rapidnet.net Guest
Posted: Fri Mar 13, 2009 9:19 am Post subject: Polyfuses |
When "trying to think of a good situation to use polyfuses" I don't know for
sure but seem to recall that once tripped they will not reset until the
TOTAL load is removed (switched off) presumably to let the polyfuse cool
down. Can anyone confirm this? If this is true, it is important to
consider when designing an application. You don't want to automatically
lose another powered device because of a fault in another (same as with a
breaker supplying power to more than one device). Nor do you want another
non-switchable load, or another load which is not known, on the same
polyfuse. This would make it impossible to eliminate the complete load on
the polyfuse, preventing it from being reset. Am I wrong?
I have never used polyfuses but the above is based on what I have read here
and on other lists. I still prefer a single traditional breaker (requires
manual reset) or fuse (requires manual replacement) for EACH load on the
airplane. Considering also, that they are easy to integrate into an airframe
and maintain, what's wrong with traditional circuit protection?
Bevan
retasker(at)optonline.net Guest
Posted: Fri Mar 13, 2009 10:12 am Post subject: Polyfuses |
You are correct in your description. Nothing wrong with either fuses or
breakers, but the individual in question has a somewhat unique situation
for which a polyfuse would provide a possibly better solution. I
believe he plans to use a separate polyfuse for each load in question.
Dick
B Tomm wrote:
Bevan
Posted: Fri Mar 13, 2009 1:05 pm Post subject: Polyfuses |
At 12:13 PM 3/13/2009, you wrote:
Correct. The devices I've ordered for a first pass look will
go into a "tripped" state at about 150 mA of continuous current
or about 2 watts of internal heat being dissipated.
| Quote: | If this is true, it is important to
You are correct. As shown in the proposed system integration drawings, one
and only one system tied to the protection module and it needs
some means by which the circuit can be broken (switch). Of course,
you would want a switch on any ignition system anyhow.
| Quote: | I have never used polyfuses but the above is based on what I have read here
Nothing. In this case, we're interested in feeding from an
always-hot source (battery bus) to favor an electrically
dependent engine. Always-hot feeders like to be protected
as close the source as practical. Hence some manner of
remotely mounted circuit breaker is attractive - ESPECIALLY
if your battery is back in the tail. Here we discover a
unique set of design goals that look with more favor
upon the much misunderstood and oft misapplied polyfuse.
It's even more attractive given that I have some standard
product enclosures . . .
http://aeroelectric.com/Pictures/Products/A09_Package.jpg
. . . that reduce the cost of getting these little critters
boxed up and bolted to the airplane.
I'm getting private email from folks wanting to order
this thing which is gratifying but premature. Let's
make sure we have done a good thing first. After sifting
the sands of design for polyfuses for over 20 years,
it WOULD be pretty cool to find a place where they
smoothly fit into a cost effective and well considered
design aboard an aircraft.
Posted: Sun Mar 15, 2009 9:37 am Post subject: Polyfuses |
At 04:03 PM 3/13/2009, you wrote:
<snip>
After pondering this project for a few days, I've
distilled the magnitude of the effort down considerably.
The "magic" parts we're adapting to our design goals
are really inexpensive. It just doesn't make sense
to wrap a lot of materials and labor costs around
their utilization. I've got some ideas for a do-it-
yerself packaging scheme. I still need to do some
temperature testing in the chamber to make sure we
don't have thermal performance issues with either
operation of the polyfuse or failure of the packaging
technique.
Bottom line is that if the present idea works, these
will be really easy to use for the purposes identified
in earlier postings to this thread.
bcondrey
Posted: Sun Mar 15, 2009 10:00 am Post subject: Re: Polyfuses |
I reported this "feature" on this forum although there might also have been others. I got the information directly from Klaus at LSE via a telephone call. Another individual that I personally know called Klaus to advise him of this thread and behavior was confirmed to him.
I think the polyfuse approach is a great solution and look forward to Bob N's testing. Assuming that all turns out well I'll be ordering also.
Bob
RV-10 N442PM (flying)
Radioflyer
Posted: Mon Mar 16, 2009 6:37 am Post subject: Re: Polyfuses |
I'm late into this discussion, but have been wondering how to implement the polyfuses since I first read about them in Jim Weir's article and Blue Mountain's wiring guide. They are very attractive to me due to their compact size, inexpensiveness, and solid state reliability. Everyone agrees they perform as advertised. But, as others have stated, the packaging issue makes their use somewhat problematic, especially if you're interested in taking them offline, bypassing their auto-reset feature.
What I would like to see is a polyfuse mounted into an ATC fuse shell, preferably one of those ATC types that have the LED already built in to indicate a fault. By so doing, you could use the readily available ATC fuse blocks, thereby retaining the option to simply pull the Polyfuse out when you need to. For my first attempt, I was going to try a little surgery on an ATC fuse package and epoxy a Polyfuse to it..., but I have not yet taken the chance to play with this. My guess is that it may be only a matter of time before some Taiwanese manufacturer starts putting polyfuses in the ATC fuse format.
--Jose
longg(at)pjm.com Guest
Posted: Mon Mar 16, 2009 8:03 am Post subject: Polyfuses |
Jose,
Would you bet your life on a floppy adaptation on your Lightspeed
ignition? Perhaps yours is just cursory interest. I'm sure you can jam
pennies in there if you like. There's no reason that would not work.
Right now I am using Bob's proposed schematic which adds two in-line 30
amp fuses in front of two 5 amp breakers. He also considered two relays
in place of the 30 amp ATC's.
I guess my deal is how am I going to get at those 30 amp in-line fuses
and still keep my eye on flying the airplane. I suppose if you blow two
30 amp fuses behind the two five amp breakers suggested by LSA, you're
already in deep doo-doo.
I wanted to ask Bob why the 30 amp fuse? Couldn't we get-a-way with
something lighter, say 20 amp?
Glenn
Posted: Tue Mar 17, 2009 6:13 pm Post subject: Polyfuses |
At 11:01 AM 3/16/2009, you wrote:
Jose,
No . . . well . . . depends. When you compare the various
time-to-trip curves for over-current protection, there's
a often overlooked consideration - response time.
Magnetic breakers and electronic breakers can be exceedingly
fast. Most thermal devices are tailored to a design goal.
For example, you can get 5A fast blow fuses and 5A slow blow
fuses. Thermal breakers as a class of circuit protector
are generally VERY slow compared to a fuse of the same ratings.
So, hook a 5A breaker in series with a 5A fuse and hit
the feeder with a short. The fuse opens every time. Keep
increasing the fuse size and you'll find that it probably
takes a 20A fuse to out-muscle a 5A breaker. So for good
headroom in the design, we make the upstream protection MUCH
more robust than the downstream protection.
This is why ANL limiters are exceedingly robust. They are
intended to be part of a distribution system wherein
no single downstream feeder protection can trip an
upstream feeder protection . . . even if the upstream
feeder is running say 100% of system average. See:
http://aeroelectric.com/Mfgr_Data/Fuses_and_Current_Limiters/Bussman/ANL_Specs.pdf
Note that the "rating" for a current limiter
includes enough headroom that it can be loaded to
100% of rating and still stand off a downstream
breaker or fuse trip.
I'm working and accident right now wherein redundant
feeders to a common bus were protected with fuses
and not current limiters with an unfortunate outcome.
This is IMPORTANT. This is why my 5A crowbar breaker
feed is protected upstream with a fusible link.
The breaker will always open before the fusible link.
| Quote: | What I would like to see is a polyfuse mounted into an ATC fuse shell,
Read the discussions on my website about the downside for
having self resetting circuit protection. The Polyfuse is
not a drop-in replacement for fuses or breakers. The
design task I'm working right now goes to a very specific
application of the Polyfuse. Similarly, fusible links
are not to be used in place of breakers or fuses without
sifting all the simple ideas and making sure design
goals are being met.
Polyfuses ARE used in automobiles. Seat adjuster motors
and widow riser motors are commonly protected with Polyfuses.
But you can be sure that if there were good value in
using them everywhere, the car guys would have ditched
the fuse block a long time ago. They ARE NOT directly
interchangeable technologies.
