Wing Skin Build Sequence
leinad
PostPosted: Sat Feb 28, 2009 3:11 pm    Post subject: Wing Skin Build Sequence Reply with quote
Does anyone know if it's OK to drill the bottom skin to ribs before drilling the top skins to ribs? Because of my limited space and the order I had my wing skins stacked it would save me some time. Has anyone actually done them in this order?
Dan 601xl Dempsey
sky_ranger161
PostPosted: Sat Feb 28, 2009 4:17 pm    Post subject: Wing Skin Build Sequence Reply with quote
Hi Dan,
As long as the wing skeleton is leveled and jigged in place as Zenith recommends I don't think it makes a bit of difference. Mine turned out beautifully and I didn't follow any particular order. Hope this helps.
Debo Cox
Scratchbuilt XL/Corvair
www.mykitlog.com/debo
Ron Lendon
PostPosted: Sat Feb 28, 2009 5:56 pm    Post subject: Re: Wing Skin Build Sequence Reply with quote
Dan,
I agree with what Debo says. Keep it level length wise and get the angle right. Fixture the position.
At that point I had two tables and made both right and left skins at the same time. That way I only had to layout one and pilot drill through two sheets. Having the structure set right next to the skins layout table made transferring the measurements to the skins easy.
I know you have limited space but you could lean a couple sheets of plywood against a wall, and cleco the two aluminum sheets to the plywood for the layout and pilot drilling of the skins. Think leanto, or a-frame.
Picts here for ideas :
http://mykitlog.com/users/display_log.php?user=rlendon&project=113&category=1683&log=55753&row=114
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
