jim(at)CombsFive.Com Guest
Posted: Sat Feb 28, 2009 8:35 am Post subject: Phase I Log book wording? |
We are almost done with our Phase I time. Can someone point me to the exact wording or phrases that should be put into the logs?Thanks, Jim CN312F - Flying Phase I (38.2 Hours) One VERY FUN airplane to fly!FYI - There is an RV Fly-In at the Madison Richmond Airport (I39) next Saturday March 7th. If anyone is close by come on. It's usually a 9 to 4 event and we get quite a few aircraft (100+). To date there has not been a -10 there. There will be at least one this year!Do Not Archive [quote][b]
rene(at)felker.com Guest
Posted: Sat Feb 28, 2009 8:46 am Post subject: Phase I Log book wording? |
They should be in your operating limitations.
Here are mine..
Phase 1 All test flights at a minimum must be conducted DAY VFR to the scope and detail of Advisory Circular 90-89 (Amateur-built Aircraft and Ultralight Flight Testing Handbook). Following satisfactory completion of the required number of flight hours in the flight test area, the pilot shall certify in the records that the aircraft has been shown to comply with § 91.319(b). Compliance with § 91.319(b) shall be recorded in the aircraft records with the following or a similarly worded statement:
"I certify that the prescribed flight test hours have been completed and the aircraft is controllable throughout its normal range of speeds and throughout all maneuvers to be executed, has no hazardous operating characteristics or design features, and is safe for operation. The following aircraft operating data has been demonstrated during the flight testing: speeds, Vso ______, Vx ______, and Vy ______, and the weight______ and CG location______ at which they were obtained".
Rene'
801-721-6080
Posted: Sat Feb 28, 2009 8:51 am Post subject: Phase I Log book wording? |
Excellent!Thanks, Jim C ------------------------------------They should be in your operating limitations.Rene'801-721-6080 [quote][b]
dlm46007(at)cox.net Guest
Posted: Sat Feb 28, 2009 9:46 am Post subject: Phase I Log book wording? |
see you operating limitations for the wording...
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of jim(at)CombsFive.Com
Sent: Saturday, February 28, 2009 9:35 AM
Subject: Phase I Log book wording?
Thanks, Jim C
