Compression tester
Roger Lee
PostPosted: Wed Feb 25, 2009 6:19 pm    Post subject: Compression tester Reply with quote
Hi All,
This is not an original idea, but I thought I would share it. I made a couple of these this weekend. It is a spark plug hollowed out with a 1/4" pipe inserted into the end and welded. An "O" ring goes on the plug end. This makes doing the compression test faster and easier.
Compression Tester End.pdf
 Filename:  Compression Tester End.pdf
 Filesize:  1.42 MB
 Downloaded:  571 Time(s)
Compression Tester.pdf
Compression tester
 Filename:  Compression Tester.pdf
 Filesize:  2.06 MB
 Downloaded:  531 Time(s)
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
Float Flyr
PostPosted: Wed Feb 25, 2009 6:50 pm    Post subject: Compression tester Reply with quote
Now that idea deserves some consideration!
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
