Deems Davis
Posted: Mon Feb 23, 2009 5:18 pm Post subject: N519PJ Weigh -In |
Well today, I got up enough courage to put in12 qts if mineral oil and
push N519PJ up on the scales. I figured with the 'mods' that she might
be a bit on the portly side, sort of expected something in the
neighborhood of 1700lbs. The only thing she lacks is some carpet.
Well, the number turned out to be 1772 ! A bit more than I was
expecting, but I remembered that we had 40 + lbs of air in each tire,
...... so I let out 15 lbs out of each tire, so she should only weigh
1737 now. (that makes me feel slightly better), I'm not sure how many
lbs I have in the O2 tank, but when I get a guage on it, I figure there
should be 1000lbs or more, so I'll just bleed off enough to get her down
to her fighting weight.
Deems #406
it's all done, ......gonna light the fire soon.
http://deemsrv10.com/
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Mon Feb 23, 2009 5:35 pm Post subject: N519PJ Weigh -In |
Deems,
I feel somewhat relieved that my 1769 lbs. (WITH carpet) has been
bested! However, if your 1772 is with paint, I may still own the most
portly 540 powered -10. I have not weighed mine since paint, but the
paint shop told me that they estimated 25-30 lbs.
Best regards,
David Maib
40559
and push N519PJ up on the scales. I figured with the 'mods' that she
might be a bit on the portly side, sort of expected something in the
tire, ....... so I let out 15 lbs out of each tire, so she should
only weigh 1737 now. (that makes me feel slightly better), I'm not
sure how many lbs I have in the O2 tank, but when I get a guage on
it, I figure there should be 1000lbs or more, so I'll just bleed off
enough to get her down to her fighting weight.
Deems #406
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
robin1(at)mrmoisture.com Guest
Posted: Mon Feb 23, 2009 5:36 pm Post subject: N519PJ Weigh -In |
Deems,
You can consider "9PJ" to have one of the largest payloads of
any 3 place RV built to date.
BTW I am right there with you ~1700# before paint, interior.
Looking forward to your start. That engine/exhaust combination
is quite motivating.
Robin
jeff(at)westcottpress.com Guest
Posted: Mon Feb 23, 2009 5:37 pm Post subject: N519PJ Weigh -In |
Can you take any weight out of the pilot?
On Feb 23, 2009, at 5:14 PM, Deems Davis wrote:
she might be a bit on the portly side, sort of expected something
in the neighborhood of 1700lbs. The only thing she lacks is some
carpet. Well, the number turned out to be 1772 ! A bit more than I
was expecting, but I remembered that we had 40 + lbs of air in each
off enough to get her down to her fighting weight.
Deems #406
dmaib@me.com
ricksked(at)embarqmail.co Guest
dlm46007(at)cox.net Guest
Posted: Mon Feb 23, 2009 6:13 pm Post subject: N519PJ Weigh -In |
A couple of weeks ago I was called a Cirrus by the RYN tower but I did not
qualify. I wasn't heavy enough. The DVT tower is going to begin mistaking
you for an SR22.
Tim Olson
Kelly McMullen
Posted: Mon Feb 23, 2009 7:13 pm Post subject: N519PJ Weigh -In |
I suspect Tim has had far more ATC personnel refer to his plane as a Cirrus, due to the tail number. These days not many ATC are pilots, and you could probably tell them you were a Lancair or Cessna 400 or Comanche, and they wouldn't know the difference.
On Mon, Feb 23, 2009 at 7:29 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote] --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
Now THERE you go....when you're flying into North Las Vegas, just
call in as "Cirrus NXXXX".....they'd never recognize the subtle
differences, and then you wouldn't have to worry about banning
experimentals.
David McNeill wrote:
[quote] --> RV10-List message posted by: "David McNeill" <dlm46007(at)cox.net (dlm46007(at)cox.net)>
you for an SR22.
A&P/IA, EAA Tech Counselor
KCHD |
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Mon Feb 23, 2009 7:42 pm Post subject: N519PJ Weigh -In |
Geeze, you can tell which ones are the American built RV-10's. HA! I can make fun.... for now.
Michael
woxofswa
Posted: Tue Feb 24, 2009 8:27 am Post subject: Re: N519PJ Weigh -In |
Deems,
I hope you are better at building than math and science. Any fifth grader knows that since the mains are at the same %MAC, you can only deduct half of the amount of the pounds that you remove from them. I hate to tell you this, but you are 15lbs heavier than you think.
The good news is that you can easily compensate for that extra 15 by putting just your pilot credentials, EAA card, and AMEX card on board and leaving your wallet at home.
Congrats on finishing.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Deems Davis
Posted: Tue Feb 24, 2009 8:36 am Post subject: N519PJ Weigh -In |
Deems
woxofswa wrote:
Deems,
The good news is that you easily compensate for that extra 15 by putting just your EAA card and your favorite AMEX card on board and leaving your wallet at home.
Myron Nelson
Mesa, AZ
Emp completed, legacy build fuse in progress
http://forums.matronics.com/viewtopic.php?p 31818#231818
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Tue Feb 24, 2009 9:03 pm Post subject: Re: N519PJ Weigh -In |
Deem's and I had been emailing last week because both our 10's were set to be weighed... mine last Sat, and Deems' yesterday. Anyway, since he made his public, I guess I should, in case someone is tracking this info. Weigh in included all upholstery, all carpet, balanced wheel pants, and the following painted; interior, wheel pants, gear leg fairings, and hs/vs fairing.
N414DM Left=639, Right=627, Nose=369....... Total = 1635
Mine was weighed prior to our meeting of the SacRvators (Sacramento).
As you can see, sorry about the large pics, we had over 25 RV's fly in and about 60 people, as quite a few reside at the Lincoln airport already, no need to fly in. I guess I did a decent job because I was only made aware of one potential problem, and it's fixed already.
How about the 3 10's lined up?
Don McDonald
#40636
103.81 KB |
12317 Time(s) |
119.44 KB |
12316 Time(s) |
245.51 KB |
12316 Time(s) |
204.3 KB |
12316 Time(s) |
_________________ Don A. McDonald
40636 |
Tim Olson
Posted: Wed Feb 25, 2009 7:03 am Post subject: N519PJ Weigh -In |
Very cool Don,
Everyone should make note of Don's last photo...he weighed
the plane with the scales on the rear wheels blocked up
a couple extra inches. You want to make sure to do your
weight and balance with the airplane level in both
directions, and the fore/aft level line is along
the longerons that run along the aircraft under the door
area. If you don't have the rear wheels elevated above
the nose, your C.G. measure will be off quite a bit.
partner14 wrote:
Don McDonald
#40636
Don A. McDonald
40636
http://forums.matronics.com/viewtopic.php?p 31965#231965
http://forums.matronics.com//files/img_2797cc_395.jpg
http://forums.matronics.com//files/img_2792c_125.jpg
http://forums.matronics.com//files/img_2762c_171.jpg
http://forums.matronics.com//files/p2210036c_110.jpg
jdriggs49(at)msn.com Guest
Posted: Wed Feb 25, 2009 7:33 am Post subject: N519PJ Weigh -In |
Tim C
If I understand this correctly C the level should be put on the longerons that form the door sills? Is that correct? Thanks
| Quote: | Date: Wed C 25 Feb 2009 08:58:19 -0600
Subject: Re: Re: N519PJ Weigh -In
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
Very cool Don C
directions C and the fore/aft level line is along
the nose C your C.G. measure will be off quite a bit.
partner14 wrote:
> --> RV10-List message posted by: "partner14" <building_partner(at)yahoo.com>
> Deem's and I had been emailing last week because both our 10's were set to be weighed... mine last Sat C and Deems' yesterday. Anyway C since he made his public C I guess I should C in case someone is tracking this info. Weigh in included all upholstery C all carpet C balanced wheel pants C and the following painted; interior C wheel pants C gear leg fairings C and hs/vs fairing.
> N414DM Left=639 C Right=627 C Nose=369....... Total = 1635
> As you can see C sorry about the large pics C we had over 25 RV's fly in and about 60 people C as quite a few reside at the Lincoln airport already C no need to fly in. I guess I did a decent job because I was only made aware of one potential problem C and it's fixed already.
> Don McDonald
> #40636
> Don A. McDonald
> 40636
> http://forums.matronics.com/viewtopic.php?p=231965#231965
Windows Live™: Discover 10 secrets about the new Windows Live. View post.
Tim Olson
Posted: Wed Feb 25, 2009 8:35 am Post subject: N519PJ Weigh -In |
I think the longerons that run the full length are a little
lower, aren't they? I may be wrong, but yeah, they're not
far from the door sil. I do think that the door sil is
parallel to them though, but I never measured it to
be sure. I just used a long level along that rivet
line for the longeron. And the same long level across both
door sils for the horizontal.
You'd be surprised how huge a difference it makes if you
don't have things leveled though.
Danny Riggs wrote:
| Quote: | Tim,
If I understand this correctly, the level should be put on the longerons
> Date: Wed, 25 Feb 2009 08:58:19 -0600
> From: Tim(at)MyRV10.com
> To: rv10-list(at)matronics.com
> Very cool Don,
> Tim Olson - RV-10 N104CD - Flying
> > Don McDonald
> > #40636
> > Don A. McDonald
> > 40636
> > Read this topic online here:
post.
<http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!550F681DAD532637!7540.entry?ocid=TXT_TAGLM_WL_t2_ugc_post_022009>
jdriggs49(at)MSN.COM Guest
Posted: Wed Feb 25, 2009 10:02 am Post subject: N519PJ Weigh -In |
That makes sense. Thanks C Dan
[quote] Date: Wed C 25 Feb 2009 10:30:28 -0600
lower C aren't they? I may be wrong C but yeah C they're not
parallel to them though C but I never measured it to
Danny Riggs wrote:
> Tim C
> > Very cool Don C
> > > Don McDonald
> > > #40636
> > > Don A. McDonald
> > > 40636
> post.
_-=============================================
_=====
It’s the same Hotmail®. If by “same” you mean up to 70% faster. Get your account now.
jim(at)CombsFive.Com Guest
Posted: Wed Feb 25, 2009 11:00 am Post subject: N519PJ Weigh -In |
Use the bottom of the door opening as the level reference. That is what the plans tell you to use for leveling the airframe.Jim C> --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>> > I think the longerons that run the full length are a little> lower, aren't they? I may be wrong, but yeah, they're not> far from the door sil. I do think that the door sil is> parallel to them though, but I never measured it to> be sure. I just used a long level along that rivet> line for the longeron. And the same long level across both> door sils for the horizontal.> > You'd be surprised how huge a difference it makes if you> don't have things leveled though.> > Tim Olson - RV-10 N104CD - Flying> > > > Danny Riggs wrote:>> Tim,>> If I understand this correctly, the level should be put on the longerons>> that form the door sills? Is that correct? Thanks>>>> > Date: Wed, 25 Feb 2009 08:58:19 -0600>> >From: Tim(at)MyRV10.com>> > To: rv10-list(at)matronics.com>> > Subject: Re: RV10-List: Re: N519PJ Weigh -In>> >>> > --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>>> >>> > Very cool Don,>> >>> > Everyone should make note of Don's last photo...he weighed>> > the plane with the scales on the rear wheels blocked up>> > a couple extra inches. You want to make sure to do your>> > weight and balance with the airplane level in both>> > directions, and the fore/aft level line is along>> > the longerons that run along the aircraft under the door>> > area. If you don't have the rear wheels elevated above>> > the nose, your C.G. measure will be off quite a bit.>> >>> > Tim Olson - RV-10 N104CD - Flying>> >>> >>> >>> > partner14 wrote:>> > > --> RV10-List message posted by: "partner14">> <building_partner(at)yahoo.com>>> > >>> > > Deem's and I had been emailing last week because both our 10's were>> set to be weighed... mine last Sat, and Deems' yesterday. Anyway, since>> he made his public, I guess I should, in case someone is tracking this>> info. Weigh in included all upholstery, all carpet, balanced wheel>> pants, and the following painted; interior, wheel pants, gear leg>> fairings, and hs/vs fairing.>> > > N414DM Left=639, Right=627, Nose=369....... Total = 1635>> > >>> > > Mine was weighed prior to our meeting of the SacRvators>> (Sacramento).>> > > As you can see, sorry about the large pics, we had over 25 RV's fly>> in and about 60 people, as quite a few reside at the Lincoln airport>> already, no need to fly in. I guess I did a decent job because I was>> only made aware of one potential problem, and it's fixed already.>> > > How about the 3 10's lined up?>> > >>> > > Don McDonald>> > > #40636>> > >>> > > -------->> > > Don A. McDonald>> > > 40636>> > >>> > >>> > >>> > >>> > > Read this topic online here:>> > >>> > > http://forums.matronics.com/viewtopic.php?p 31965#231965>> > >>> > >>> > >>> > >>> > > Attachments:>> > >>> > > http://forums.matronics.com//files/img_2797cc_395.jpg>> > > http://forums.matronics.com//files/img_2792c_125.jpg>> > > http://forums.matronics.com//files/img_2762c_171.jpg>> > > http://forums.matronics.com//files/p2210036c_110.jpg>> > >>> > >>> &======================>> >============>> >>> >>> >>>>> ------------------------------------------------------------------------>> Windows Live™: Discover 10 secrets about the new Windows Live. View>> post.>> <http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns!550F681DAD532637!7540.entry?ocid=TXT_TAGLM_WL_t2_ugc_post_022009>>>>>>> *>>>>>> *> > > > http://www.matronics.com/contribution> > > > [quote][b]
Tim Olson
Posted: Wed Feb 25, 2009 12:24 pm Post subject: N519PJ Weigh -In |
Thanks Jim/Larry,
I do think that the longeron and door sil are probably both
identical in angle, so this may be a horse-a-piece kind of
deal. I don't think you'd see any difference, but....
Straight from the RV-10 Weight and Balance section, provided
by Vans:
"Leveling Datum - A point or surface on the airframe where a
level can be placed to determine when the aircraft is in a
level position for weighing. For the RV-10 the Level Datum
line is the fuselage longeron at the door opening"
So, you guys may well be correct, and probably are, that the
door sil works, but the official word in the RV-10 W&B
procedure section from Van's specifies the longeron.
If anyone is near their plane, maybe you could take a sec
to verify if the door sil is completely parallel to the
longeron or not. I bet it is.
jim(at)CombsFive.Com wrote:
| Quote: | Use the bottom of the door opening as the level reference. That is what
Jim C
> Danny Riggs wrote:
>> Tim,
>> > Very cool Don,
>> (Sacramento).
>> > > Don McDonald
>> > > #40636
>> > > Don A. McDonald
>> > > 40636
>> post.
LarryRosen
Posted: Wed Feb 25, 2009 1:13 pm Post subject: N519PJ Weigh -In |
The door sill sits directly on top of the longeron. It gives a
convenient place to set the level.
Yes a horse-a-piece kind of deal.
Larry
Tim Olson wrote:
Thanks Jim/Larry,
by Vans:
> Jim C
> > Danny Riggs wrote:
> >> Tim,
> longerons
> >> > Very cool Don,
> 10's were
> since
> this
> >> (Sacramento).
> RV's fly
> >> > > Don McDonald
> >> > > #40636
> >> > > Don A. McDonald
> >> > > 40636
> >> post.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
