Dick Sipp
Posted: Thu Feb 19, 2009 1:41 pm Post subject: Nose Wheels |
To add a little more to the nose wheel discussion: I asked Rob at Grove for his opinion of the various "fixes" available.
In his opinion the problem on the 10 and the other models in his opinion stems from the fact that the bearing seal is rubber rather than
felt. This creates, again, in his opinion excessive wheel spin up drag which can lead to a for and aft shimmy condition. He believes the 10 gear assy
is a better designed gear than the others with the solidly mounted gear leg. He said while the spinning spacer issue can be stopped by any
method of securing the spacer, screw whatever, the other deficiency in the stock design he feels is the fact that the axle bolt is unsupported and subjected
to bending loads rather than the bolt being supported by a collar or spacer and thus putting the bolt under a shear load only.
I did not have any of the issues with the stock parts in the first hundred hours, but will change to the Grove wheel and axle assy anyway.
Dick Sipp
N110DV
bart.van.ruth(at)wxs.nl Guest
Posted: Fri Feb 20, 2009 12:41 pm Post subject: Nose Wheels |
I followed the discussions about the fixes of the nose wheel bearing problem.
The fix I chose is to mount a bushing between the inner rings of the bearings and make sure that the shaft is a little short.
That way the axial preload of the central bolt is clamping all inner bushing and rings tightly together so that they do not rotate.
Of course I had to test mount and measure the amount of play in the bearings carefully and adjust the length of the bushing accordingly.
This way I will not have any wear and successively a lot of bearing play witch leads to shimmy.
Speaking of shimmy, I also replaced the standard Belleville washer springs bye much thinner ones. The deflection on the standard springs is so little that even a minimum wear will drastically reduce the friction value. The ones I chose deflect at least 5 times more and will not effect the friction bye much if some wear starts to appear.
I also added bushing to the main gear wheels so that I can put some real torque on the main nuts and secure the wheel a little better in spite of the flimsy backup bushing in the rear felt seal.
Bart van Ruth
PH-USN RV-10 wiring
