Wing Rib OOPS
william(at)gbta.net
PostPosted: Wed Feb 18, 2009 8:54 pm    Post subject: Wing Rib OOPS Reply with quote
Page 14-3 step 5. Tonight I was riveting the W-1025B-R Flap hinge rib and W-1025A Flap hinge bracket to one of the W-1011-L inboard wing ribs and my rivet gun slipped. Bottom line is that I "smilied" the flap hinge rib a little bit below one of the rivets. I'll attach pictures for details. Is there enough strength in the rest of the rib/rivets to leave it alone or do I need to fix it??? If I need to fix it could I cut a doubler to go over the damaged hole and to the rivets surrounding the damaged hole???
Also, while I'm at it, I'm only building the left wing so far as I go. When I go back to the right wing are all of the wing ribs the same as the instructions say for the left wing or do I put a -R rib where a -L rib is shown in the instructions? I know--clear as mud, right?. I remember some discussion about this subject a few years ago and don't remember the answers.
Bill[img]cid:B43068800C4848038AEF6681624BAC24(at)Britton[/img][img]cid:9CC312335DAE4A52B19C7DBD0D47BBB3(at)Britton[/img]
 Filesize:  605.15 KB
 Viewed:  6155 Time(s)
 Filesize:  489.82 KB
Tim Olson
PostPosted: Wed Feb 18, 2009 10:18 pm    Post subject: Wing Rib OOPS Reply with quote
Bill,
That doesn't look too bad, I'd probably just leave it, unless you see
that it really went deep into that rib. But it really doesn't look
worth worrying about. If you did do a doubler, you'd want to do one
that covered a bunch more area, so you'd probably end up removing
at least a couple more rivets.
For building those wings, you may find it goes quicker to do them
together if you have space. Plus, you can compare parts and make
sure that both sides look like their respective drawings. Just
pay attention to how the ribs are placed in the drawings and you'll
do fine there too.
the damaged hole???
Bill
msausen
PostPosted: Thu Feb 19, 2009 7:10 am    Post subject: Wing Rib OOPS Reply with quote
Nothing to see here people, move along. J
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill and Tami Britton
Sent: Wednesday, February 18, 2009 11:23 PM
Subject: Wing Rib OOPS
Bill
Andy Turner
PostPosted: Thu Feb 19, 2009 8:04 am    Post subject: Re: Wing Rib OOPS Reply with quote
If only my mistakes were so minor. Very Happy Think of the ribs as those that face inward and those that face outward. Same for both wings.
Andy Turner
dvanwinkle(at)royell.org
PostPosted: Thu Feb 19, 2009 8:22 am    Post subject: Wing Rib OOPS Reply with quote
Bill
In answer to your last question, unless there is a specific reason for a
design difference in the other wing, standard aircraft drawing convention is
"Left Hand Shown, Right Hand Opposite", or saying it another way, the wings
are mirror images of each other. Any differences should be shown as separate
detail drawings. A perfect example of that is the flap actuator only in
the right wing of the Cessna single engine fleet .
Dean Van Winkle
Retired Aeronautical Engineer
RV-9A Slow Builder
william(at)gbta.net
PostPosted: Thu Feb 19, 2009 9:17 am    Post subject: Wing Rib OOPS Reply with quote
Thanks to everyone!!!
Bill
