Mike Whisky
Posted: Tue Feb 17, 2009 11:29 am Post subject: How many push pull contol cables (cabin heat type) |
I took the time to really get my workshop cleaned up and while working through my "to be used" parts I came across a 4th push pull cable (cabin heat type). I will have two for cabin heat (rear & front) one for alternative air for the airbox. So why is there a forth since it came with the kit?
Am I missing something here?
Michael
_________________ RV-10 builder (flying)
#511 |
rene(at)felker.com Guest
Posted: Tue Feb 17, 2009 11:39 am Post subject: How many push pull contol cables (cabin heat type) |
Carb heat for o-540's ?
Rene' Felker
RV-10 N423CF Flying
801-721-6080
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Feb 17, 2009 11:45 am Post subject: Re: How many push pull contol cables (cabin heat type) |
I have it also. If you installed the air cut off door in the front of the air box, then you would use it.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
Mike Whisky
Posted: Tue Feb 17, 2009 11:49 am Post subject: Re: How many push pull contol cables (cabin heat type) |
Ok great thanks guys, that will come as a spare one since I have an IO-540.
Cheers
Michael
#511 |
Posted: Tue Feb 17, 2009 12:18 pm Post subject: How many push pull contol cables (cabin heat type) |
Also, I used mine for air control to the "new" oil cooler I just put in.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
rv10free2fly(at)yahoo.com Guest
Posted: Tue Feb 17, 2009 1:39 pm Post subject: How many push pull contol cables (cabin heat type) |
Any pictures of the "new oil cooler" installation please Rene?
Patrick Pulis
RV-10 #40299 VH-XPP
Adelaide, South Australia
Sent: Wednesday, 18 February, 2009 6:45:04 AM
Subject: RE: Re: How many push pull contol cables (cabin heat type)
--> RV10-List message posted by: "Rene Felker" <rene(at)felker.com (rene(at)felker.com)>
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Tue Feb 17, 2009 1:50 pm Post subject: How many push pull contol cables (cabin heat type) |
I don’t have any pictures, but the new cooler is the one Alex sells and I put a butterfly valve on the back of the baffling in order to control the airflow. I can’t remember who I bought the butterfly valve from…..I will have to look that up at home.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Pulis
Sent: Tuesday, February 17, 2009 2:36 PM
Subject: Re: Re: How many push pull contol cables (cabin heat type)
Patrick Pulis
RV-10 #40299 VH-XPP
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Tue Feb 17, 2009 3:34 pm Post subject: How many push pull contol cables (cabin heat type) |
Rene, how much was the cooler and did you need to replace both the Vans supplied oil cooler and the mounting box?
Any chance of a contact for Alex please.
Patrick Pulis
RV-10 #40299 VH-XPP
Sent: Wednesday, 18 February, 2009 8:19:36 AM
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Patrick Pulis
RV-10 #40299 VH-XPP
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Posted: Tue Feb 17, 2009 9:05 pm Post subject: How many push pull contol cables (cabin heat type) |
Got the oil cooler here
http://www.aviationtechproducts.com/html/engine__parts.html
$427
I have not flown with it yet, so I don’t know if it will help my oil heat problem. In the summer I have to restrict climbs due to oil heat……we will see this year.
Not wanting the oil to be to cold, I put in this air controller, also have not flown with it in order to check the effectiveness….
http://www.nonstopaviation.com/rv10-controller-cooler-p-14566.html
Rene'
801-721-6080
Posted: Tue Feb 17, 2009 10:03 pm Post subject: How many push pull contol cables (cabin heat type) |
Many thanks Rene.
Pat
Sent: Wednesday, 18 February, 2009 3:33:56 PM
$427
Rene'
801-721-6080
Posted: Wed Feb 18, 2009 5:56 am Post subject: How many push pull contol cables (cabin heat type) |
That oil cooler gives probably about 15-20 degrees cooler oil compared to the standard Van's cooler. I would consider that a must have if you are in a hot environment. If you are between heat and cold, then you might want to go with the valve so you can let your oil warm up when it's cold. It works really well. When open, it doesn't look like it will restrict airflow much at all, but closing it will let your oil warm up when it's cold. For those who don't put in the carb heat/alternate air door, you can use the cable that comes with the FWF kit to work this valve.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Feb 18, 2009, at 12:03 AM, Rene wrote:
[quote]Got the oil cooler here
$427
Rene'
801-721-6080
Posted: Wed Feb 18, 2009 1:41 pm Post subject: How many push pull contol cables (cabin heat type) |
Many thanks Jesse.
Pat
South Oz
Sent: Thursday, 19 February, 2009 12:25:01 AM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
Make Yahoo!7 your homepage and win a trip to the Quiksilver Pro. [url=http://au.rd.yahoo.com/homepage/mailtagline/*http://au.docs.yahoo.com/homepageset/?p1=other&p2=au&p3=tagline]Find out more[/url]. [quote][b]
Posted: Sun Feb 22, 2009 12:11 pm Post subject: How many push pull contol cables (cabin heat type) |
Here is a picture of the new cooler….looks just like the old cooler and the air controller….
Rene'
801-721-6080
168.4 KB |
8207 Time(s) |
Posted: Sun Feb 22, 2009 1:34 pm Post subject: How many push pull contol cables (cabin heat type) |
Rene', the replaceent cooler just bolts on to the same place as the original Vans cooler?
Pat
Sent: Monday, 23 February, 2009 6:39:47 AM
Rene'
801-721-6080
Posted: Sun Feb 22, 2009 2:14 pm Post subject: How many push pull contol cables (cabin heat type) |
Yep, it is the same form factor, just has more fins inside. I will not know until this summer how much it helped the oil temp.
It only took about 10 minutes to change it out. If anyone wants a stock cooler cheap….I got one.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Sent: Sunday, February 22, 2009 2:26 PM
Pat
Rene'
801-721-6080
Posted: Sun Feb 22, 2009 3:45 pm Post subject: How many push pull contol cables (cabin heat type) |
Thanks Rene'
Sent: Monday, 23 February, 2009 8:43:02 AM
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Pat
Subject: RE: RV10-List: Re: How many push pull contol cables (cabin heat type)
Rene'
801-721-6080
