z601(at)anemicaardvark.co Guest
Posted: Thu Feb 12, 2009 8:18 am Post subject: Wing locker questions |
I've searched the archives without luck, and also queried Zenith. Meanwhile,
I'd like to ask the list my questions, to see if I get one answer that I
consider better than the others. I found Zenith's drawings and the pictorial
a bit lacking in detail, specifically:
1) Are the springs for the Dzus fasteners intended to be held in place with an
A4 rivet?
2) If so, should the rivet be set flush, using a dimpling die or similar to
provide a countersink on the Dzus plate?
3) The Dzus fasteners provided do not appear to be captive. That means they
are likely to fall out when removed. Has anyone come up with a fix for this?
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
psm(at)att.net Guest
Posted: Thu Feb 12, 2009 8:48 am Post subject: Wing locker questions |
Hi Jim,
It has been a couple of years since I dealt with these issues, so I
hope my memory isn't too faulty.
I like to use "A" (soft aluminum) solid rivets for things like the
Dzus springs and also for nutplates. They are very easy to set and
sufficiently strong to hold these devices in place. Some times I set
them with a small hammer and backplate. Other times I use a small
press I have mounted on one of my work benches. Keep in mind the
only load the rivets see in normal use is holding the part in place
when it is not in use.
I use a standard countersink to set the factory head flush with the
aluminium sheet on which the rivet is mounted. It doesn't really
matter if the countersink is exactly the right size. If it is too
small a little filing will remove the soft aluminum that is sticking
out. If it is a little too big then there might be a little movement
in the attached part.
There are special capture springs for the Dzus parts. I got some
from Aircraft spruce. They are little round spring steel wires that
fit into the groove on the Dzus connector.
Have fun,
Paul
XL getting close
At 08:21 AM 2/12/2009, you wrote:
place with an
A4 rivet?
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu Feb 12, 2009 8:55 am Post subject: Re: Wing locker questions |
Jim,
Yes, an A4 rivet will hold the Dzus springs in place. The plans did not call out for flush riveting and I set them like normal. I used a locking washer like those used on car trim fasteners. I picked them up at Lowes in the hardware department.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
rsteele(at)rjsit.com Guest
Posted: Thu Feb 12, 2009 9:04 am Post subject: Wing locker questions |
I followed what was on the Wings DVD from Homebuilt Help. Just as you
said, A4s, and not countersunk. When fit together this doesn't seem to
present a problem. You can get clips for the fasteners, but I've also
heard of using O rings. I've done neither at this point.
Ron
Posted: Thu Feb 12, 2009 9:34 am Post subject: Wing locker questions |
I believe some have used tight-fitting washers made from milk jugs to retain
the Dzus fasteners.
-- Craig
agbeyer(at)sbcglobal.net Guest
Posted: Thu Feb 12, 2009 11:06 am Post subject: Wing locker questions |
Ron had said that he has heard of using "O" rings on the fasteners to hold them in place. I did use "O" rings on my HDS. They have been in place for 4 years and work great. If you use the Clips the holes have to be the right size so the clips will not slip through the hole. I made the holes larger than standard so the fastener aligns easyer with the hole in the wing skin, and then slipped the "O" ring over the fastener.
AL from Oshkosh
From: "rsteele(at)rjsit.com" <rsteele(at)rjsit.com>
Sent: Thursday, February 12, 2009 11:04:36 AM
Subject: RE: Wing locker questions
--> Zenith601-List message posted by: <rsteele(at)rjsit.com (rsteele(at)rjsit.com)>
Ron
Posted: Thu Feb 12, 2009 1:25 pm Post subject: Wing locker questions |
Hi Jim,
I made up some templates to get consistency and also dimplers to handle
the rivets as well as Dzus guides.
The Dzus will hang up on the hole at the back relief for the retaining
washers, so the radius hole is good to do
also. See link for tools and install results. Cowling page, but any
installation is near the same for Dzus.
http://www.macsmachine.com/images/cowling/full/Dzustools.gif
http://www.macsmachine.com/images/cowling/full/Dzusdimples.gif
http://www.macsmachine.com/images/cowling/full/Dzusspring.gif
http://www.macsmachine.com/images/cowling/full/cowlnose2.gif
Hope this is useful, A4 Rivets yes. Flush, yes.
You can order a fist full of plastic washers that will hold the Dzus
fastener in place from
Aircraft Spruce as Half Grommets, GP type, usually GP5B, which are
thermoplastic, $0.06 ea.
They work as well as the aluminum types and can also be removed with a
small nose plier if necessary.
Jim Belcher wrote:
A4 rivet?
Ron Lendon
tonyplane(at)bellsouth.ne Guest
Posted: Thu Feb 12, 2009 6:02 pm Post subject: Wing locker questions |
I used "O" rings on the Duez fasteners to keep them attached. I did buy
some "holders", I believe they are plastic type washers, but have never
installed them as the O rings have been holding for over 3 1/2 years.
Tony Graziano
XL/Jab3300; N493TG; 468 hrs
Posted: Sat Feb 14, 2009 9:03 am Post subject: Wing locker questions |
Thanks to everyone for their suggetions on installation of the wing locker.
I've collected what I feel is a compromise between the best mix, the actual
needs I have, airworthiness, etc etc. I might have done it without you guys
and gals, but it would have taken a lot longer, and wouldn't have been nearly
as good.
I still haven't received a response from Zenith. I'm somewhat disappointed in
their lack of design detail.
Those who can, do. Those who can't, sue.
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Do not archive.
Jim B Belcher
A&P/IA
Posted: Mon Feb 16, 2009 12:23 pm Post subject: Wing locker questions |
A question for the list: has anyone (else) experienced a problem with the
pre-drilled holes for nose rib#3 in the right nose skin? The angle to which
rib 3 was pre-installed on the main spar, which seems to me to fix the
location of rib 3, and hence, the hole locations in the nose skin.
The holes in my nose skin are 17mm to the left of where it appears they should
be. It's easy to fix ... but I wonder if I've done something wrong, or if
perhaps the tooling is wrong at Zenith. If the latter, they probably need to
know.
Do not archive.
Jim B Belcher
A&P/IA
