SilPruf window removal
Dave(at)AirCraftersLLC.co
PostPosted: Sun Feb 15, 2009 7:29 pm    Post subject: SilPruf window removal Reply with quote
A few people have asked about removing a window that was installed with SilPruf.
The weatherman said this would be a good time to take the plane down for a few days, so I decided to replace our sun-damaged window.
I pulled a little plug of sealant out of the groove on the outside. I was able to pretty easily put a piece of .020 safety wire through the sealant from the inside and fish it out from the outside. Then I just pulled the wire around the perimeter of the window. It took 10 minutes to get the window out.
I cleaned up the old sealant with a scraper and some Scotchbrite, and installed the new window like the others.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
www.AirCraftersLLC.com
 Filesize:  84.27 KB
 Viewed:  18678 Time(s)
 Filesize:  102.26 KB
 Filesize:  48.17 KB
 Filesize:  59.34 KB
carl.froehlich(at)cox.net
PostPosted: Mon Feb 16, 2009 7:17 am    Post subject: SilPruf window removal Reply with quote
Dave,
Did you use this on the windshield as well? Any photos?
Carl Froehlich
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Dave Saylor
Sent: Sunday, February 15, 2009 10:24 PM
Subject: SilPruf window removal
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
jdriggs49(at)msn.com
PostPosted: Mon Feb 16, 2009 7:50 am    Post subject: SilPruf window removal Reply with quote
Any suggestions as to where to buy this stuff? Their web site wasn't very helpful. Thanks C Dan
Subject: RE: SilPruf window removal
Date: Mon C 16 Feb 2009 10:15:40 -0500
.ExternalClass p.EC_MsoNormal C .ExternalClass li.EC_MsoNormal C .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman' C'serif';} .ExternalClass a:link C .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited C .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:'Times New Roman' C'serif';color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Dave C
Carl Froehlich
Sent: Sunday C February 15 C 2009 10:24 PM
The weatherman said this would be a good time to take the plane down for a few days C so I decided to replace our sun-damaged window.
I cleaned up the old sealant with a scraper and some Scotchbrite C and installed the new window like the others.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville C CA
831-722-9141
831-750-0284 CL
ttp://www.matronics.com/Navigator?RV10-List
ronics.com
ww.matronics.com/contribution
See how Windows connects the people C informa/MRT/go/msnnkwxp1020093175mrt/direct/01/' target='_new'>See Now
PostPosted: Mon Feb 16, 2009 8:53 am    Post subject: SilPruf window removal Reply with quote
I didn't use it on the windshield because of the time involved in molding a joggle into the lower section. It could be done, but it would be a lot of work. I might consider it if I ever had to remove the windshield.
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Monday, February 16, 2009 7:16 AM
Dave,
Carl Froehlich
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
I get if from these guys:
http://www.halowry.com/
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Danny Riggs
Sent: Monday, February 16, 2009 7:45 AM
Any suggestions as to where to buy this stuff? Their web site wasn't very helpful. Thanks, Dan
Date: Mon, 16 Feb 2009 10:15:40 -0500
.ExternalClass p.EC_MsoNormal, .ExternalClass li.EC_MsoNormal, .ExternalClass div.EC_MsoNormal {margin-bottom:.0001pt;font-size:12.0pt;font-family:'Times New Roman','serif';} .ExternalClass a:link, .ExternalClass span.EC_MsoHyperlink {color:blue;text-decoration:underline;} .ExternalClass a:visited, .ExternalClass span.EC_MsoHyperlinkFollowed {color:purple;text-decoration:underline;} .ExternalClass span.EC_EmailStyle17 {font-family:'Times New Roman','serif';color:blue;font-weight:normal;font-style:normal;text-decoration:none none;} .ExternalClass .EC_MsoChpDefault {font-size:10.0pt;} (at)page Section1 {size:8.5in 11.0in;} .ExternalClass div.EC_Section1 {page:Section1;}
Dave,
Carl Froehlich
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville, CA
831-722-9141
831-750-0284 CL
ronics.com
See how Windows connects the people, informa/MRT/go/msnnkwxp1020093175mrt/direct/01/' target='_new'>See Now [quote]
PostPosted: Mon Feb 16, 2009 10:06 am    Post subject: SilPruf window removal Reply with quote
Thanks!
Date: Mon C 16 Feb 2009 08:52:53 -0800
.ExternalClass .EC_hmmessage P {padding:0px;} .ExternalClass body.EC_hmmessage {font-size:10pt;font-family:Verdana;} I get if from these guys:
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville C CA
831-722-9141
831-750-0284 CL
Sent: Monday C February 16 C 2009 7:45 AM
Dave C
Carl Froehlich
Dave Saylor
AirCrafters LLC
140 Aviation Way
Watsonville C CA
831-722-9141
831-750-0284 CL
ronics.com
ronics.com
Windows Live™: E-mail. Chat. Share. Get more ways to connect. Check it out. [quote][b]
Lenny Iszak
PostPosted: Mon Feb 16, 2009 10:15 am    Post subject: Re: SilPruf window removal Reply with quote
I just bought some on Amazon.com.
Lenny
PostPosted: Mon Feb 16, 2009 11:59 am    Post subject: SilPruf window removal Reply with quote
Is this stuff paintable? Dan
Subject: Re: SilPruf window removal
Date: Mon C 16 Feb 2009 10:15:41 -0800
--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com>
Lenny
http://forums.matronics.com/viewtopic.php?p=230536#230536
&gt===
See how Windows connects the people C information C and fun that are part of your life. See Now
PostPosted: Mon Feb 16, 2009 7:10 pm    Post subject: SilPruf window removal Reply with quote
The instructions say no.
Sent: Monday, February 16, 2009 11:57 AM
Subject: RE: Re: SilPruf window removal
Subject: RV10-List: Re: SilPruf window removal
Date: Mon, 16 Feb 2009 10:15:41 -0800
Lenny
See how Windows connects the people, information, and fun that are part of your life. See Now [quote]
Lenny Iszak
PostPosted: Mon Feb 16, 2009 8:28 pm    Post subject: Re: SilPruf window removal Reply with quote
Dan,
Here's the Amazon link for Silpruf:
http://www.amazon.com/s/qid=1234844526/ref=sr_nr_seeall_2?ie=UTF8&rs=&keywords=silpruf&rh=i:aps,k:silpruf,i:tools
or you can get it here http://www.dkhardware.com/product-3620-scs2003-black-ge-silpruf-silicone-sealant.html for a couple dollars cheaper. I just trust Amazon a little more...
Lenny
PostPosted: Tue Feb 17, 2009 8:40 am    Post subject: SilPruf window removal Reply with quote
Thanks for the link. I am doing the windows as soon as I get this stuff in.
One more question..... there is a flange about 3/4" wide that the plexiglass will sit on where the Silpruf will be bedded. Since the Silpruf is white (I presume) what do you do about the white ring that will be left around each pane where the Silpruf will show thru? If it's clear then the pink canopy will show thru. Do you paint the fiberglass first to eliminate this? I'm just trying to visualize the procedure before applying the $18 per tube stuff.   Thanks again C Dan
Date: Mon C 16 Feb 2009 20:28:19 -0800
Dan C
http://www.amazon.com/s/qid=1234844526/ref=sr_nr_seeall_2?ie=UTF8&rs=&keywords=silpruf&rh=i:aps Ck:silpruf Ci:tools
Lenny
http://forums.matronics.com/viewtopic.php?p=230611#230611
Archive Search & Download C 7-Day Browse C Chat C FAQ C
&gt==
Get more out of the Web. Learn 10 hidden secrets of Windows Live. Learn Now
Lenny Iszak
PostPosted: Tue Feb 17, 2009 9:02 am    Post subject: Re: SilPruf window removal Reply with quote
Dan,
You can get the silpruf in white, black, gray and bronze. I'm planning on using the black one like Dave did.
Before gluing the window in, you apply a very light coat on the glass where the window flange goes, and it will give it a uniform black color. Let that dry for a day and then you glue in the window.
I think it's worth getting the videotape from Airlinktech.
Looks like they sell the silpruf too, but they only have white and gray:
http://mall.igfarm.com/store/merchant.mv?Screen=CTGY&Store_Code=airlinktech&Category_Code=Supplies
I need to mention that i hate VHS. I needed to borrow a VHS player and then the tape was stuck, so i had to open it up and straighten out the guts inside before it would start playing...
Check out Dave's writeup about this at:
http://forums.matronics.com/viewtopic.php?t=39388
For what it's worth, Cirrus uses the aluminum color silicone on their windows.
Lenny
drfred(at)suddenlinkmail.
PostPosted: Tue Feb 17, 2009 9:29 am    Post subject: SilPruf window removal Reply with quote
Danny;
I bought the black. It is not paintable. If I had to do it again,
paint a small ring of black at the edge where the silpruf meets the
fiberglass. It would help the painters get a crisper line . I really
like the way the windows came out. I think it makes for a very nice
installation. If you are going to paint before you fly, you could leave
out the last fillet until _after_ final paint. That way, you could get
the silpruf to cover the paint as it wraps over the edge of the
fiberglass. It would look really slick then.
Dr Fred.
stuff in.
procedure before applying the $18 per tube stuff. Thanks again, Dan
> From: lenard(at)rapiddecision.com
> Date: Mon, 16 Feb 2009 20:28:19 -0800
> To: rv10-list(at)matronics.com
> Dan,
> Lenny
> http://forums.matronics.com/viewtopic.php?p 30611#230611
Archive Search & Download, 7-Day Browse, Chat, FAQ,
Learn Now
<http://windowslive.com/connect/post/jamiethomson.spaces.live.com-Blog-cns%21550F681DAD532637%215295.entry?ocid=TXT_TAGLM_WL_getmore_092008>
