jpspencer(at)cableone.net Guest
Posted: Sun Feb 15, 2009 5:12 pm Post subject: options to fix horizontal stabilizer |
I agree with whoever it was that said you ought to call Zenith. I had a problem in the HS mount area and because it is such a critical area, and there is a history of failure there, I called them and they were most accomodating in evaluating the fix I proposed. They requested pics of the problem and spent a little time looking at it, then got right back to me with an email oking what I wanted to do, which I still have a copy of. Very helpful folks on that problem. I feel like that is an area us shadetree folks ought to have the pros look at, if there is any doubt at all.
Good luck
Joe
stepinwolf
Posted: Tue Feb 17, 2009 4:43 am Post subject: Re: options to fix horizontal stabilizer |
| jpspencer(at)cableone.net wrote: | then they got right back to me with an email oking what I wanted to do, which I still have a copy of. Very helpful folks on that problem. Good luck
Joe
Joe,
Since quite a few others might be in the same situation, do you think it might be helpful to other builders to post the response that Zenith sent you.
regards
Bob
_________________ Long wing + vga's, = lo & slo |
john.marzulli(at)gmail.co Guest
Posted: Tue Feb 17, 2009 8:18 am Post subject: options to fix horizontal stabilizer |
I called Zenith a few days ago and their answer was the one I was expecting: Open up the stabilizer and move the mounts out. Since the existing holes need to be filled, the mounts may need to be moved out slightly more than 10mm so the radius clears the rivet heads and shim slightly between the two mounts.
John Marzulli
http://www.GenevieveMarzulli.org/
http://marzulli.smugmug.com/
http://701Builder.blogspot.com/
http://www.JohnMarzulli.net/
On Tue, Feb 17, 2009 at 4:43 AM, stepinwolf <robert.pelland(at)cgocable.ca (robert.pelland(at)cgocable.ca)> wrote:
[quote] --> Zenith701801-List message posted by: "stepinwolf" <robert.pelland(at)cgocable.ca (robert.pelland(at)cgocable.ca)>
> Joe
Joe,
regards
Bob
Live each day, as if it was your last
http://forums.matronics.com/viewtopic.php?p=230634#230634
801-List" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
MS -
e -
brothapig(at)hotmail.com Guest
Posted: Tue Feb 17, 2009 11:03 am Post subject: options to fix horizontal stabilizer |
You say the holes need to be filled with rivets? Why would an unfilled hole be less desirable than a filled hole? I can't believe that it would cause a higher stress concentration C and it's covered with the H.S. skin C so it is not aesthetic. Just wondering.
Date: Tue C 17 Feb 2009 08:13:55 -0800
Subject: Re: Re: options to fix horizontal stabilizer
I called Zenith a few days ago and their answer was the one I was expecting: Open up the stabilizer and move the mounts out. Since the existing holes need to be filled C the mounts may need to be moved out slightly more than 10mm so the radius clears the rivet heads and shim slightly between the two mounts.
Thanks C
John Marzulli
On Tue C Feb 17 C 2009 at 4:43 AM C stepinwolf <robert.pelland(at)cgocable.ca (robert.pelland(at)cgocable.ca)> wrote:
[quote]--> Zenith701801-List message posted by: "stepinwolf" <robert.pelland(at)cgocable.ca (robert.pelland(at)cgocable.ca)>
| Quote: | then they got right back to me with an email oking what I wanted to do C which I still have a copy of. Very helpful folks on that problem. Good luck
Joe
Joe C
Since quite a few others might be in the same situation C do you think it might be helpful to other builders to post the response that Zenith sent you.
regards
Bob
Live each day C as if it was your last
MS -
e -
-Matt Dralle C List Admin.
-List">http://www.matronics.com/Navigator?Zenith701801-List
ronics.com
Posted: Tue Feb 17, 2009 11:11 am Post subject: options to fix horizontal stabilizer |
The holes that I am talking about filling are the ones in the spar.
John Marzulli
On Tue, Feb 17, 2009 at 10:58 AM, Ryan Vechinski <brothapig(at)hotmail.com (brothapig(at)hotmail.com)> wrote:
[quote] You say the holes need to be filled with rivets? Why would an unfilled hole be less desirable than a filled hole? I can't believe that it would cause a higher stress concentration, and it's covered with the H.S. skin, so it is not aesthetic. Just wondering.
Date: Tue, 17 Feb 2009 08:13:55 -0800
From: john.marzulli(at)gmail.com (john.marzulli(at)gmail.com)
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
John Marzulli
