scoobytrash(at)hotmail.co Guest
Posted: Thu Mar 30, 2006 5:13 am Post subject: Solid State gyros. WAS: Trutrak |
I've been an RC modeler for years and the pizo gyros have been around for
quite
awhile now although I have never personally used them. I checked with tower
hobbies and they have a number of gyros from futaba (one of the oldest RC
brands around):
http://tinyurl.com/pz432 - single axis pizo gyro, 1oz, $140
http://tinyurl.com/l9n7o - single axis gyro with ctlr and
servo(47oz-in) $380
For some reason, all the dual axis pizo gyros seem to be discontinued and
they seem
to be moving toward single axis units. The servo included above is
obviously too weak
for real aircraft although you can buy a monster servo with 180 oz-in of
torque
for about $80 which is getting pretty close to usable. Interesting
possibilities, one
could assemble a pretty much off the shelf auto-pilot with RC parts for
under $500.
Scooby
Posted: Thu Mar 30, 2006 9:06 am Post subject: Solid State gyros. WAS: Trutrak |
Hi Scooby, Mark Michel and everyone,
That is what I was getting at. The parts are
relatively cheap, can drive an indicator as is, or
thru a big servo, be an autopilot, yaw dampener, or
wing leveler. Not something I would trust IFR, but
something that could get me out of it if I bumbled in.
No problem for night backup and maybe something to
hold the plane in turbulence while you read a map.
Maybe something just right to add stability to those
older model Fox's with the little tails. Easier and
lighter than a refit to a bigger tail.
Michel might be right. TruTrack might be doing just
this???? For a price.....
So Mark, how does that sound to you? Doable?
One of the neatest things I have seen is a Canadian
system that paints a light across the cockpit and
levels it to the horizon. It improved IFR scan by 80%
because the whole cockpit was your periferal horizon
and you scanned the other instruments more easily.
Now I have this lazer picture hangar that draws a
bright red line........ Just an idea.
Kurt S.
--- scooby harrington <scoobytrash(at)hotmail.com> wrote:
| Quote: | I've been an RC modeler for years ........
...... Interesting possibilities, one
| Quote: | could assemble a pretty much off the shelf
auto-pilot with RC parts for under $500.
Scooby
mscotter
Joined: 15 Jan 2006 Posts: 49 Location: Winston-Salem, NC
Posted: Thu Mar 30, 2006 12:01 pm Post subject: Solid State gyros. WAS: Trutrak |
Doable? Yeah, certainly. If you wanted a simple singe axis wing-leveler, I would think you could take one of the big servos on the market and hook it to an aileron trim tab. The control pulse that is typical of most rc transmitters is fairly well documented on the web, I bet you could replicate that with a small electronic circuit. Then you'd have to play with the gain a little to get the gyro tuned to this 'system' and you should be up and running. I doubt you even really need that great a gyro - the dynamics of our man-carrying aircraft are much slower than the smaller rc stuff. I would NOT want to be in an aircraft that could flip and tumble as fast as my rc aircraft!
I'm kind of surprised nobody else out there has done this already. Anyway, I think the aileron trim tab idea might also be good because if there was a problem you could still overpower it and keep control of the aircraft.
Mark Scott
Elkton, MD USA
-------------- Original message --------------
From: kurt schrader <smokey_bear_40220(at)yahoo.com>
Doable? Yeah, certainly. If you wanted a simple singe axis wing-leveler, I would think you could take one of the big servos on the market and hook it to an aileron trim tab. The control pulse that is typical of most rc transmitters is fairly well documented on the web, I bet you could replicate that with a small electronic circuit. Then you'd have to play with the gain a little to get the gyro tuned to this 'system' and you should be up and running. I doubt you even really need that greata gyro - the dynamics of our man-carrying aircraft are much slower than the smaller rc stuff. I would NOT want to be in an aircraft that could flip and tumble as fast as my rc aircraft!
Mark Scott
Elkton, MD USA
-- Kitfox-List message posted by: kurt schrader <SMOKEY_BEAR_40220(at)YAHOO.COM>
_________________ Mark Scott
Winston-Salem, NC |
