riddon(at)sent.com Guest
Posted: Sun Feb 08, 2009 5:33 am Post subject: Dooor strut repositioning. |
I have recently bought the kit from Europa to reposition the gas strut to cure the bulging at the top rear corner of the doors. It seems a little OTT as it requires me to glue on a complete back section to the door frame just to install the lug. I wondered if I might be able to fabricate a small aluminium lug and rivet it onto the existing frame instead to take the lower fixing for the gas strut? Any suggestions?
Richard Iddon G-RIXS
Brian Davies
Posted: Sun Feb 08, 2009 5:46 am Post subject: Dooor strut repositioning. |
Hi Richard,
I thought the same and used about four inches of the section and cut most of it down to blend it in. It has been fine so far.
Brian Davies G-DDBD
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Richard Iddon
Sent: 08 February 2009 13:32
Subject: Dooor strut repositioning.
Quote: |
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
| No virus found in this incoming message. Checked by AVG - www.avg.com 270.10.19/1938 - Release Date: 02/06/09 17:28:00 [quote][b]
budyerly(at)msn.com Guest
Posted: Sun Feb 08, 2009 9:14 am Post subject: Dooor strut repositioning. |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Richard,
Go to my website under accessories and tips. My solution is there. It's been working for years. When Andy Draper looked at my mod, he tried to make it perfect. It is unfortunate that it is perfectly heavy, much heavier and harder to finish when complete...
Getting the geometry right is the key. I make a piece of aluminum that is the length of a almost completely compressed strut ( 8 inches or so) and use it as a guide. I am very big on jigs and fixtures which many are not. Getting the clearances right takes some time. It takes me about 3 hours to do the whole mod using super glue vice 5 minute... Don't use superglue if the glass is in, just incase you get sloppy, which is easy to do
Some are confused about the top hole for the ball stud, but it is easier than I have stated in my instructions. Mark a line down the center of the angle in the upper door recess. Measure out and down one inch. Make a hole.
Bud Yerly
www.customflightcreations.com
